reh5108's 4 Banging SHITBOX tUrBo 4x4 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Reh5108, Mar 12, 2014.
  1. Mar 23, 2019 at 9:09 PM
    #901
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Yep. The driver side is always locked in though. It doesnt bind the passenger axle but still binds with the tcase a bit.
  2. Mar 23, 2019 at 9:10 PM
    #902
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Huh my truck didn't have one of those but it looks like it's just there to prevent cavitation. Piggy is a good idea. At 5psi though an FMU would probably work great and is cheapo. Easy to try out at least. Walbros always whine until they die in my experience. I've had eh experience with them.
  3. Mar 23, 2019 at 9:28 PM
    #903
    Reh5108
    Idaho
    I'll have to look into one of those. I have the FPR referencing only boost, from my understanding it operates in a 1:1 ratio. Trying to pace myself on adding more power and spending more money. I need Kings in the front soon! I haven't noticed the sound of the Walbro yet.
    Truck is around 60-70dB according to an app. It used to be around 80-90dB. I'm liking that.
    Speedytech7[QUOTED] likes this.
  4. Mar 24, 2019 at 2:10 PM
    #904
    Reh5108
    Idaho
  5. Mar 24, 2019 at 2:11 PM
    #905
    Speedytech7
    That's a unique failure
  6. Mar 24, 2019 at 3:22 PM
    #906
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    Kinda sounds like the previous owner over torqued it to start with.
  7. Mar 24, 2019 at 6:22 PM
    #907
    Reh5108
    Idaho
    I think it was my fault. The washer never seated up against the head of the plug. The more I tighten it the more I wedged it in the hole. Anyway the old transfer case cover is installed. The new case looked brand new inside. My original looked like poop. I didn't clean much but there was a slight amount of wear on the gears that the chain meshes with not much but enough to feel.
  8. Mar 24, 2019 at 6:26 PM
    #908
    Reh5108
    Idaho
    I don't think my fpr is working correctly. I used the hose with the union which should see boost. I disconnected it and just vented it to atmosphere and had no change in afr in OL.
  9. Mar 24, 2019 at 6:50 PM
    #909
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Let's see pics of the old tcase.
    And damn, this truck has got to stop fighting you at some point here.
    jubei likes this.
  10. Mar 24, 2019 at 7:32 PM
    #910
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Pretty soon it will be all new
  11. Mar 24, 2019 at 8:42 PM
    #911
    Reh5108
    Idaho
    Wishbone Runner, ToyRyd04 and jubei like this.
  12. Mar 25, 2019 at 3:00 AM
    #912
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Wow! That case looks awful.
    Were you using redline fluid? If not, that red tint is definitely from metal and on metal fretting.
  13. Mar 25, 2019 at 4:43 AM
    #913
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    There’s a lot of iron in the water out there:mudding:
  14. Mar 25, 2019 at 8:25 AM
    #914
    Reh5108
    Idaho
    Valvoline synthetic. I've neglected my fluid changes in both the transmission and tcase. Trans didn't look near as bad as the tcase fluid though. Was waiting on an opportunity to replace the adapter output seal to do the fluids since it was leaking. Unfortunately I didn't have one on hand to put in when I had them separated but there was a pretty deep groove worn into the input shaft where the seal is. No leaks from the new case yet...
  15. Mar 31, 2019 at 8:12 PM
    #915
    Reh5108
    Idaho
    It survived about a 1000 mile trip to Utah! About 200 of that being dirt miles. I think the only issues are that the wastegate nipple put a hole in my hard ac line, relocated that to a spare port closer to the turbo side after trying to tighten the MarMount bolt up to find a balance of vibration and motor movement. It's pretty tight now but the vibrations are bearable. Only really notice them at less than 750rpm. The one bolt holding my manifold bracket snapped, kind of expected it to. I need to extend the bracket to some bigger bolt holes down on the block a bit more.
    The turbo randomly started leaking again but I believe it has stopped. I think bouncing around on rocks and having the truck at odd angles restricts the return line. At least this is all I hope it is and not the seal again. I might try to find a bigger return line at some point.
    My old transfer case had definitely been slipping for quite some time, I just always attributed it to be the locker ratcheting. The locker is a much different sound.
    Trip report tomorrow hopefully...
  16. Apr 1, 2019 at 8:47 AM
    #916
    Squeaky Penguin
    Brett
    *after interstate exit fuel pump repair.
    rngr, Night Eagle, jubei and 2 others like this.
  17. Apr 1, 2019 at 9:24 AM
    #917
    cynicalrider
    cynicalrider #NFG
    Jersey
    Beards looking GNARLY Ryan :rofl:
    Reh5108[OP] likes this.
  18. Apr 1, 2019 at 10:11 PM
    #918
    Reh5108
    Idaho
    Started off the trip headed to Junction to meet up with @Night Eagle and @Squeaky Penguin. The truck made it over Berthoud pass and up Loveland Pass (long uphill pull) on I70 without a problem. Enjoying the added power from the turbo I was quite pleased at how things were going. About 2.5 hours into the trip the truck kicks out of cruise and stumbles but picks up again. I reset cruise and immediately after it dies. I coast to a stop between a guardrail and the whiteline after just having passed the previous exit. Not a fun place to be with cars whizzing past at 80mph. Fortunately the guard rail ended in about 50yds and I was able to put the truck in second gear and crank using the starter to propel the truck forward. I'd crank for 30 seconds and wait to let things cool down. I eventually made it to where I was past the rail and could start diagnosing my problem. I initially thought the truck was telling itself to shutoff because it would sputter and start to fire but then nothing. So it was getting fuel and spart for a second then nothing. I disconnected the FPR and had fuel in the rail. Checked the EFI fuse, swapped relays, checked resistance on the crank position sensor. Everything was checking out. I was at the point of giving up and called Brett and Leo and they decided to backtrack 45min to come see if they could give me a hand.
    I pulled the FPR again and noticed I had very little gas coming out compared to. It was becoming more evident that the pump wasn't pushing fuel. Once Brett and Leo arrived I had one of them crank while I checked to make sure I was getting voltage to the connector, I was. This left the only option to be the fuel pump not working. Brett fortunately had a spare tank so we decided to drop the tank. We pulled the pump and discovered that I hadn't locked in the connector to the pump and it wiggled loose. :facepalm: We put it back together all being confident it was fixed and we were good to go. Started cranking it over and nothing. Unbolted the FPR again and had fuel this time. So now I'm not getting spark. Pulled a plug and grounded it to confirm and nothing. About to give up and call for a tow Brett happened to notice that the crank position sensor wasn't plugged in. Apparently I forgot to plug it back in after testing :facepalm: Truck fired right up after that was connected.
    Finally on the road again after a 3hr delay. Being late and getting dark we settled on a campsite within eyesight of the interstate, not ideal.
    We headed towards the Copper Globe mine exploring different spurs and overlooks along the way. We noted a great campsite right on the edge, with an incredible view but being early in the day it would be for another trip.
    Once at the mine we discovered a "historic wood pile". I'm not sure if any of you have ever witnessed such a thing but it is one of beauty! :rofl:
    20190328_141635 by Ryan Heintzelman - Flickr2BBcode
    We also found some neat green and blue rocks, presumably copper.
    20190328_142647 by Ryan Heintzelman - Flickr2BBcode
    20190328_142816 by Ryan Heintzelman - Flickr2BBcode
    20190328_144021 by Ryan Heintzelman - Flickr2BBcode
    Next we headed to Eagle Canyon and towards camp to meet up with @Wishbone Runner
    20190328_164018 by Ryan Heintzelman - Flickr2BBcode
    Woke up, rather crawled out of the Nest as I got very little sleep from likely the windiest night I've ever camped in. We packed up and headed towards the Devil's Racetrack and Fix It pass. The only technical trails of the trip.
    20190329_113625 by Ryan Heintzelman - Flickr2BBcode
    20190329_113922 by Ryan Heintzelman - Flickr2BBcode
    20190329_114311 by Ryan Heintzelman - Flickr2BBcode
    20190329_115544 by Ryan Heintzelman - Flickr2BBcode
    20190329_115422 by Ryan Heintzelman - Flickr2BBcode
    https://youtu.be/QaTQs2LzkAc
    20190329_142322 by Ryan Heintzelman - Flickr2BBcode
    20190329_145920 by Ryan Heintzelman - Flickr2BBcode
    20190329_150137 by Ryan Heintzelman - Flickr2BBcode
    https://youtu.be/IOMrujm4Wvc
    https://youtu.be/BP3RPnh0Bdw
    We set up camp hoping to escape the wind along the banks of the San Rafael River. Finally a calm quite night.
    The next day the rest of the group did some hiking in Devil's Canyon. Not having a completely healed leg yet I decided to drive around and explore a bit more of the area by vehicle. I ended up getting snowed out of both spurs I explored before reaching there ends.
    20190330_155101 by Ryan Heintzelman - Flickr2BBcode
    After reconvening with the group we decided to head to the campsite on the edge of the cliff we found on day 2. Great choice!
    20190330_182548 by Ryan Heintzelman - Flickr2BBcode
    20190330_182658 by Ryan Heintzelman - Flickr2BBcode
    20190330_191200 by Ryan Heintzelman - Flickr2BBcode
    I did end up a little breezy here in the morning but it was definitely worth the views.
    Fortunately, nothing exciting to note on the drive home.
  19. Apr 2, 2019 at 4:25 AM
    #919
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Looks like an awesome trip. I hate doing it because I do this for 40+ hours a week at work but lately I’ve been putting in ear plugs when I camp and it’s super windy. Works great lol
  20. Apr 2, 2019 at 4:40 AM
    #920
    chuckers
    chuckers Well-Known Member
    Chuck!
    Sneads Ferry, NC
    2004 Tacoma 4 door TRD Off Road
    Just finished reading all this. Rad truck man. All the work that you did yourself is inspiring. I have a welder but Im not great at it. Need to get better.. haha
