reh5108's 4 Banging SHITBOX tUrBo 4x4 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Reh5108, Mar 12, 2014.
  1. May 7, 2019 at 6:09 PM
    #941
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
  2. May 7, 2019 at 8:43 PM
    #942
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    I am stashing metal scrap for air box 2.0 when you are ready.
    Reh5108[OP] likes this.
  3. May 8, 2019 at 10:31 AM
    #943
    Reh5108
    Idaho
    I need to figure out the stalling issue before spending more time making another. Other than it not being square this one should be fine for awhile. The filter doesn't block the inlet as I initially thought it would.
  4. May 8, 2019 at 11:27 AM
    #944
    Night Eagle
    Leo
    2014 TDR Off Road
    The metal I am stashing is thicker gauge stuff so you should be better off. Just let me know when you are ready.
  5. May 13, 2019 at 2:46 PM
    #945
    Reh5108
    Idaho
    Think I solved my stall issue that the new airbox caused. Installed a RKX hybrid valve, 75% recirculating 25% to atmosphere. I don't like the atmosphere vent facing up, just begging to catch dirt but I don't see a good way to avoid it.
    20190513_151723 by Ryan Heintzelman - Flickr2BBcode
    :burnrubber:PPSSHHHH
    Littles and jubei like this.
  6. May 13, 2019 at 5:35 PM
    #946
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    We need some vidyahs of the twistle!!
    jubei and Littles like this.
  7. May 13, 2019 at 6:21 PM
    #947
    Reh5108
    Idaho
    Here's 75% to atmosphere. It still stalled the truck so swapped to 25% atmosphere. 25% is almost hard to hear in the cab.
    https://youtu.be/EfAhmIt7IWc
    Wulf, Night Eagle and Littles like this.
  8. May 13, 2019 at 6:29 PM
    #948
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    :thumbsup: Any high pitch whistle under load going up hills? My old f350 sounded like a a big rig towing up long hills
  9. May 13, 2019 at 6:57 PM
    #949
    Reh5108
    Idaho
    I can hear the turbo whine but it's not very noticeable. Not sure if a video will pick it up or not.
  10. May 14, 2019 at 1:07 PM
    #950
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Gotcha. Screw it as long as it helps getting your truck down the road better who really cares about the noises
  11. May 14, 2019 at 5:05 PM
    #951
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Just add a sub. Works wonders
    Wheelspinner[QUOTED] likes this.
  12. May 18, 2019 at 9:37 PM
    #952
    Reh5108
    Idaho
    Torspd and jubei like this.
  13. Jun 9, 2019 at 4:52 PM
    #953
    Reh5108
    Idaho
    Just got home from a 2500 mile round trip to Idaho for an interview. Truck did pretty well. I noticed I was getting some odd tire wear on the way home and discovered a bad upper bj. I said F it and drove the rest of the way home. That tire already has some sidewall damage and should be covered under Discounts protection plan. Could have very easily replaced it on the side of the road if I had too. Just did both of them in less than an hour.
    Turbo did great too. Not sure how I haven't noticed any detonation yet. I'd imagine pulling some of the long hills with only 13:1 afr things would get pretty hot in the cylinder. @Speedytech7 you questioned what my timing was under this condition and it's between 15-17. I need to be over 4k rpm for it to richen up to 12 or lower.
    I do have a small exhaust leak somewhere. I'm hoping it's not a crack in the manifold. I think my best tank of gas was 19 and worse was 17. Not too bad for doing 75-80 mph.
    I discovered a crack in the rear of the Wildernest. The hybrid GFC/Wildernest may come to fruition this winter.
    jubei, Squeaky Penguin and Dalandser like this.
  14. Jun 9, 2019 at 5:43 PM
    #954
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Your computer is certainly noticing detonation if it's hovering around 16 degrees of advance. But all things considered for a 13AFR (bad news bears) could be a lot worse. You need something to richen it up a bit. Boost up hills around 2800 to 3750 with my truck got me 19-23 degrees of advance and that's when it wasn't pinging. When it was pinging it would back down to 12-15
    Reh5108[QUOTED][OP] likes this.
  15. Jun 9, 2019 at 5:43 PM
    #955
    Reh5108
    Idaho
    I did discover my winch isn't working. Fortunately it was when I went to move a tree off the trail and not get unstuck from something.
  16. Jun 9, 2019 at 5:57 PM
    #956
    Reh5108
    Idaho
    Will the computer see a ping event and learn from that so as to not encounter that situation again? Or does it need to detect it and then retard the timing?
    It is retarding timing to the point it no longer detects ping correct?
  17. Jun 9, 2019 at 6:04 PM
    #957
    Speedytech7
    I wrote a huge post on this one time. But according to the Toyota EFI manual from that generation. The computers only moethod of fighting ping is to reduce ignition timing, and it jumps down to a known safe number, like 10 degrees commonly, and begins counting up by a half degree every second until it records a minor ping event then it stops counting until a major ping is detected then this whole cycle starts again. It's a bit more complicated than that because it has multiple safetys and fallbacks depending on what fuel cell it is referencing on the map. But that basic understanding will help you get it to count up again cause all you really need to do is let off the gas to make it reference timing for low load and then get back on the gas slowly. The computer is designed to meet emissions and doesn't understand that you're increasing cylinder pressure, it thinks there's so much airflow because you decreased in elevation. It doesn't know that increasing fuel could decrease knock too. Basically every instinct that computer has built in is absolutely wrong for boost. This is why we always have to fight back with piggybacks or standalones
    jubei and Reh5108[QUOTED][OP] like this.
  18. Jun 9, 2019 at 7:17 PM
    #958
    Reh5108
    Idaho
    Do you have an electronic copy of the EFI manual by chance?
  19. Jun 9, 2019 at 7:19 PM
    #959
    Speedytech7
    Yer in luck! I do
    Some of it is out of date, but 90% is relevant
    Wulf, Torspd and Reh5108[QUOTED][OP] like this.
  20. Jun 9, 2019 at 7:22 PM
    #960
    Reh5108
    Idaho
    Awesome! Thanks!
