reh5108's 4 Banging SHITBOX tUrBo 4x4 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Reh5108, Mar 12, 2014.
  1. Feb 5, 2021 at 3:09 PM
    #1341
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    That's was the door switch not being depressed all the way.
  2. Feb 5, 2021 at 3:23 PM
    #1342
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Mine does the same thing when you open the passenger door. Have to play with the door switch to get it to stay on
  3. Feb 5, 2021 at 3:44 PM
    #1343
    Reh5108
    Idaho
    I just happened to have a box of 1/4 ounce wheel weight sitting on the bench so I stuck one of those on the door. Problem solved!
  4. Feb 5, 2021 at 6:05 PM
    #1344
    Reh5108
    Idaho
    Anyone think this fit wouldn't be acceptable for a production run? PXL_20210206_015929969.jpg PXL_20210206_015914091.jpg PXL_20210206_014434272.jpg PXL_20210206_014418273.jpg
  5. Feb 5, 2021 at 6:42 PM
    #1345
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Looks pretty good. I'd personally want the front side to have a bit more gap on the long lip to do more of a valley weld.
    Reh5108[OP] likes this.
  6. Feb 5, 2021 at 8:58 PM
    #1346
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    X2. But I think welding w/ gas you'd be able to get close with Ryan's template
  7. Feb 5, 2021 at 9:16 PM
    #1347
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Dang, that looks great. Nice work.
  8. Feb 6, 2021 at 4:48 AM
    #1348
    Reh5108
    Idaho
    Appreciate the feedback fellas. That should be a simple correction to the drawing. I'm curious to see how similar one truck will be from another. I'll extend the cab side on top of the frame down about a 16th of an inch too. Would prefer to have the weld on the frame instead of the original bucket.
    Thanks!
    I'll make those changes and can just have it shipped to your house. Unless you're just looking for a reason to get out of the city.
    m3bassman[QUOTED] likes this.
  9. Feb 6, 2021 at 7:20 AM
    #1349
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    Those gussets are looking good ryan. If you were up for it, I would post up a group buy and see what kind of traction you get. After working with Brett on his a little I feel like those have a lot less fitment issues unlike the TC gussets.
    Reh5108[QUOTED][OP] likes this.
  10. Feb 6, 2021 at 7:49 AM
    #1350
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Lower it and swap in a multi-mode tcase!
    I actually think that would make for a sweet daily.
    Yeah, those damn TC coil bucket gussets took hours to get fit up right.
  11. Feb 6, 2021 at 10:32 AM
    #1351
    Reh5108
    Idaho
    I likely will once I get another truck done. Just want to confirm fitment before taking peoples money. I'm not sure this will be able to be installed if someone already has the TC gussets on. I suppose if the UCA stubs holes were cut to make a slot it could be slid in there instead of bent about 45* on a bench and install bolts and bend it the rest of the way.
    It would.
    Has anyone seen any failures to warrant the need for the TC gussets?
  12. Feb 6, 2021 at 11:09 AM
    #1352
    Blackdawg
    Monte
    Wyoming/St. Louis
    Shhhh. That's my plan with my SX single cab!
    Plus turbo..
    Not really. But I think the idea was originally to keep the coil bucket from bending inward. I'm sure it helps with that. Double shearing the UCA isn't all bad.
    Also I'd be down for a set as well. I'm sure you'll have no problems selling these in large batches.
  13. Feb 6, 2021 at 11:13 AM
    #1353
    Reh5108
    Idaho
    What kind of mpg do you get in the SX? Both my trucks are averaging 16. Hoping to find something better for daily duty.
  14. Feb 6, 2021 at 11:47 AM
    #1354
    Blackdawg
    Monte
    Wyoming/St. Louis
    Over 20. It's 1100 lighter. Makes a difference. With Igor I get around 16-17 average on my commute. 18.5 gal tank would last a week.
    On the little truck the 16.5 gal tanks lasts over a week on the same commute.
    Plus it's a hoot to drive. I really like it. Hoping I can do the tcase swap when I do the clutch but still trying to figure out drive shaft stuff.
  15. Feb 6, 2021 at 12:30 PM
    #1355
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I have the TC gussets but would like to add a set of these.
  16. Feb 6, 2021 at 1:32 PM
    #1356
    Squeaky Penguin
    Brett
    I put them on before I knew about the cracking issues.
    I think they should help the entire coilbucket from flexing inwards, which should help. They're definitely not hurting anything.
    I still think a crossbrace would be the best solution.
    Going to make them a little harder to fit, but should be doable.
    Digiratus[QUOTED] likes this.
  17. Feb 6, 2021 at 2:07 PM
    #1357
    Digiratus
    Roaming the PNW
    The RedHead
    This is encouraging.
    @Reh5108 Ryan, mark me down for a set when you get to the point of production.
  18. Feb 6, 2021 at 4:43 PM
    #1358
    Reh5108
    Idaho
    Well the T100 might be the bigger shitbox... I think the fuel pump died. I have spark and it cranks over just fine, just doesn't fire.
  19. Feb 6, 2021 at 4:52 PM
    #1359
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha yeah that sucks. My SX did that too. But is old and a looooot of miles so understandable.
  20. Feb 6, 2021 at 5:08 PM
    #1360
    Reh5108
    Idaho
    350k on the body. Wouldn't be surprised if it it's the original pump. Hopefully I can get it pulled into the shop tomorrow at work and do a little more troubleshooting. Naturally I just filled the tank. I did crack the line to the fuel filter and cranked. Expected fuel to squirt out but it was just a slow drip.
