reh5108's 4 Banging SHITBOX tUrBo 4x4 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Reh5108, Mar 12, 2014.
  1. Feb 6, 2021 at 5:13 PM
    #1361
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yeah sounds about right for mine too. Was the OG pump. Shouldn't take you long to fix it. Be a bit of a pain with the full tank but I think you can syphon it out with that year of tank, can't remember what year yours is..But i had to do that to mine. Didn't take long.
  2. Feb 6, 2021 at 9:05 PM
    #1362
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I'll put a set on as well, when there's one available ;). These new limit straps finally have me worried about speed. Because speed causes cracks.
    Reh5108[OP] likes this.
  3. Feb 7, 2021 at 6:45 AM
    #1363
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    It's a 97. Not sure if it has the screen blocking the tank.
  4. Feb 7, 2021 at 7:09 AM
    #1364
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    Totally understand wanting fine tune the product. This thread shows you have a good amount of interest.
    Reh5108[QUOTED][OP] likes this.
  5. Feb 7, 2021 at 7:48 AM
    #1365
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Bad ass and totally acceptable with a MIG welder. I've filled larger gaps with a TIG and it wasn't too hard, considering. I am with the other gents. Make it happen!
  6. Feb 7, 2021 at 9:41 AM
    #1366
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah you should be able to syphon it just fine.
  7. Feb 7, 2021 at 12:04 PM
    #1367
    Reh5108
    Idaho
    Well got the tank out and pulled the pump out and connected it directly to the battery and tested it. It worked fine. Put it back in the tank and the truck fired right up. The most fun part is that both of the strap bolts broke that hold the tank up. Time to drill some bolts! Easier removal than a Tacoma if things went smoothly.
  8. Feb 7, 2021 at 2:40 PM
    #1368
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I'm not sure I could trust it (the pump) after that.
    turbodb likes this.
  9. Feb 7, 2021 at 3:52 PM
    #1369
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah if I'd have done the effort to pull it I'd have just replaced it.
  10. Feb 7, 2021 at 5:47 PM
    #1370
    Reh5108
    Idaho
    I agree but I didn't have a new one to replace it with, just my spare for the Tacoma. It's a lot easier to drop the T100 tank. Once the filler neck is disconnected the whole think dops low enough to pull the sending unit out.
    It'll probably leave me stranded in a worse place next time...
  11. Feb 8, 2021 at 9:23 AM
    #1371
    dbcorvairracer
    dbcorvairracer Well-Known Member
    1999 Supercharged Taco
    TRD Supercharger, 7th Injector, Light bar, Recaro heated seats
    Put me down for a set
  12. Feb 9, 2021 at 8:50 PM
    #1372
    Reh5108
    Idaho
    Well, didn't take long for the fuel delivery to quit in the T100 again. Kind of thinking I may have water freezing up and blocking the fuel line. Seems odd both times this has happened the truck ran just fine when parked.
  13. Feb 10, 2021 at 5:59 AM
    #1373
    Night Eagle
    Leo
    2014 TDR Off Road
    Is it a loose connection on the pump?
  14. Feb 10, 2021 at 8:03 AM
    #1374
    Reh5108
    Idaho
    Connections looked fine. I would think I'd feel it stumble when I was driving it on bumpy roads if it was a connection issue.
  15. Feb 10, 2021 at 8:09 AM
    #1375
    Night Eagle
    Leo
    2014 TDR Off Road
    Ya you would think so but when we had to pull the pump on your taco it ended up not being fully plugged in and you intermittent issues there. Just a thought. :notsure:
  16. Feb 10, 2021 at 8:23 AM
    #1376
    Reh5108
    Idaho
    It stumbled once before it picked up again and I made it another mile. This has happened on the T100 while its been parked, so nothing is moving causing a connection to shake. Why I don't think it's a bad connection.
  17. Feb 10, 2021 at 8:57 PM
    #1377
    Reh5108
    Idaho
    Got the driver side bucket finished up today and took the Tacoma for drive. Feels like it pulls a bit better without this shitty flex pipe restricting things. I was able to pull the small pass in 4th and still accelerate usually I'm just barely maintaining speed.
    I was able to weld two of the three side on the engine bay side without removing anything but a couple vacuum hoses.
    Forgot to weld the brake line bracket back on before painting...
    New wideband sensor isn't pegging lean under WOT anymore and I think I've got all the exhaust leaks sealed up. P0420 code begone! :fingerscrossed:
  18. Feb 11, 2021 at 4:44 AM
    #1378
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good lord that is horrendous! Hard to believe that it was designed in such a fashion.
    The gusset looks fantastic.
  19. Feb 11, 2021 at 7:39 AM
    #1379
    Night Eagle
    Leo
    2014 TDR Off Road
    That flex pipe just has a little bit of restriction to it.
  20. Feb 11, 2021 at 7:38 PM
    #1380
    Reh5108
    Idaho
    Ended up being the fuel pump. Not sure why it decided to work when I pulled it the first time. Doesn't work now.
