Reimbursement from Toyota, how long and how difficult?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingston73, Dec 18, 2017.
  1. Dec 18, 2017 at 8:06 AM
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Many of you by now know there's another "extended warranty" campaign for the driveshaft/ujoint vibration issue that the 2nd gens have had. I've had 2 separate repairs done over the past few years to fix this, 1 by a dealer and 1 by an independent shop. I called and talked to toyota customer service and faxed all my required paper work to them.
    Just today I received an email saying they'd received everything and would now need 45 days to review and respond.
    So my question is, is this typical? If you've ever asked toyota for money back for anything how long did it take from request to finally getting paid?
  2. Dec 19, 2017 at 9:02 PM
    JSB10
    JSB10 Well-Known Member
    2005 Tacoma
    Hi
    I had the leaf springs replaced out of my own pocket and later on found out about the recall. Just like you I sent in my paperwork and in around one month I had a check for the exact amount I had paid. Hopefully it will go well for you. Good luck!!
    scottalot and kingston73[OP] like this.
  3. Dec 20, 2017 at 8:44 AM
    JohnnyRed
    JohnnyRed Well-Known Member
    Northern Kentucky
    2008 DCLB TRD Sport
    I'm in the process of submitting a claim for the leaf spring recall too. I haven't sent it in yet, but I'm hoping I have success like JSB10.
    @JSB10 - Do you happen to have any scans of what you submitted? Did you submit by fax or some other method?
  4. Dec 20, 2017 at 8:57 AM
    JSB10
    2005 Tacoma
    Hi JohnnyRed I went to my mechanic who did the work and he gave me a copy of the bill showing total cost of his labor, Toyota also asked for part numbers for the new leaf springs which came from the Toyota dealership, and I had to provide a copy of the Check from my bank. All this I mailed in and received a check for what I had paid. Very pleased how Toyota responded. I am currently waiting for a frame replacement in the coming weeks for my 05 Tacoma. Hopefully this goes well too. I think you shouldn't have any problem from Toyota for reimbursement I would just check back with them if it takes too long. Good luck!!
  5. Dec 20, 2017 at 11:15 AM
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    Thanks!
    I saw that some people's requests were denied and I suspect it's because they didn't have a clear "Condition-Cause-Remedy" statement on their invoice. Or at least that's what I think based on what Toyota asked me to send in.
    My main challenge may be that I had a shop build a spring pack, instead of replacing them with off the shelf parts. Also, that my truck came from Canada, but I'm working with Toyota US.
    I have the receipt, bank statement, and title ready to fax in. Hope it all goes well!
    JSB10 likes this.
  6. Dec 26, 2017 at 8:50 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    When I had one of my rear leafs break I called and asked about it. The recall on the leaf springs was a massive amount of vehicles and when I called Toyota they said that I may or may not get reimbursed. I just stuck it out and waited for them to replace it under recall.
    If the scope of the recall for this is smaller than the one for the leaf springs, I would imagine that it would be easier to get reimbursed for. If they're anything like dealing with my local Toyota dealer you may have to be firm with them, but it'll get done. Good luck OP.
  7. Dec 26, 2017 at 11:02 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I replaced the rear springs on my truck about a year before the recall came out. Cracked drivers side leaf.
    Ordered a set of heavy duty springs from wheeler's, installed them, and all was well.
    After the recall came out I sent in for reimbursement. I sent the original receipt from wheeler's with my order, name, address, but that was not good enough for toyota.
    They wanted proof of payment and all I had was the receipt. Normally that would be good enough but not with them. It went back and forth for awhile and then they declined me.
    About $400 with shipping. Gone. Still a little bitter about it. Fuckers.
  8. Feb 20, 2018 at 1:10 PM
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    Just got my reimbursement today for the leaf spring recall. I sent it in on 12/29, so it took them quite a while to process it.
    I first contacted them via e-mail, then faxed the documents to them. I submitted a copy of:
    -Repair Invoice (with clear Condition Cause Remedy statement)
    -Statement from my bank showing that the payment was taken out of my account
    -Title showing I owned the truck
    $494.11 back for me to put to use on new mods. I'm thinking 4Runner brake swap...
    JSB10 likes this.
