Reinforcment for a Camper Shell
Discussion in 'Tonneau Covers, Caps and Shells' started by RustedTacos, Apr 27, 2021.
  1. Apr 27, 2021 at 12:19 PM
    RustedTacos
    RustedTacos [OP] Active Member
    Newbie here - I'm wondering what kinds of reinforcement are recommended for adding a camper shell and preparing to carry more weight on the truck. Is it recommended to somehow reinforce the shocks, springs, or other changes to prepare to place more weight on the truck? Also I have about a 2-3" lift on the truck. Does this affect anything I should be aware of? Thanks!
  2. Apr 27, 2021 at 12:32 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just how much Extra weight are you planning to carry ? All the time 1000 to 1500 pounds ??
    You need some idea of what the added weight is and with your lift how the truck sits and handles.
    Then go about adding extra spring capacity if needed All kinds of different options you can explore.
  3. Apr 27, 2021 at 12:50 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    Bed stiffeners.
    vtown and RustedTacos[OP] like this.
  4. Apr 28, 2021 at 12:21 PM
    RustedTacos
    I'd say I need to be able to carry 1000-1500 pounds on long trips.
  5. Apr 28, 2021 at 12:23 PM
    RustedTacos
    OK thanks - what kind of bed stiffeners do you recommend?
  6. Apr 28, 2021 at 12:26 PM
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    bed stiffeners for the cap, I don't have them and my cap is definitely spreading the top of the tailgate open. That kind of weight for long trips tells me you either need heavier springs if the load is always there, or airbags if it's variable. She's gonna squat hard with the stockers and shoot your headlights into the sky.
    RustedTacos[OP] likes this.
  7. Apr 28, 2021 at 12:47 PM
    RustedTacos
    ok thanks - is there a certain brand of bed stiffeners to get? Can I buy them off of Amazon? Are they easy to install?
  8. Apr 28, 2021 at 12:58 PM
    vtown
    CT
    I see several brands on Amazon staring at $100 ish. Since I don’t have them, I can’t recommend, but there’s threads here if you search. Think I’ve seen total chaos recommended.
    Sounds easy to install. Heard you put a ratchet strap around the bed to suck it in than bolt them down.
  9. Apr 28, 2021 at 7:43 PM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    I went with the Total Chaos bed stiffeners. They're definitely not the cheapest, though -- ended up costing me $225 including shipping. I like them because they go up higher than most others, and also don't interfere with the OEM bed mat.
    Here's what they look like:
