Related to a GMC Acadia
Discussion in 'Off-Topic Discussion' started by kris77, Feb 6, 2012.
  1. Feb 6, 2012 at 5:48 AM
    kris77
    kris77 [OP] Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    Hey guys,
    I know its not toyota or tacoma related, but you guys are pretty smart.
    My wife has a 2011 GMC Adacia. The key gets stuck in the ignition 6 out of 10 times you drive it. The relay that releases the key is going bad or shorting out somehow. Until I can get it in to the dealership, I need a way to release the key so my battery wont die. If i beat on the steering column for about 10 mins it finally kicks in and releases the key.
    Any ideas?
  2. Feb 6, 2012 at 5:50 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Is it when the wheel is turned all the way to one side and when you shut it off it engages the steering column lock??
  3. Feb 6, 2012 at 5:53 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Will it help to move the gearshift back to Drive and then to Park again? Since the gearshift has to be in Park in order for the key to come out, maybe it is that contact point that is not working right, and wiggling the gearshift a little in-and-out park might cause the relay/solenoid to make contact.
  4. Feb 6, 2012 at 6:04 AM
    kris77
    West Virginia
    No, you can actually hear the selenoid/relay whatever it is engage or disengage, not sure which when you shift into park on a normal day.
    On days when the key gets stuck, you cannot hear that "Click" in the steering column.
    Yeah, they will repair it, but not until next tuesday. Thats 8 days of me getting pissed everytime i drive it.
  5. Feb 6, 2012 at 9:23 AM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    The Acadias came out just as I was leaving GM so I'm not positive on this but....
    Stick your head under the steering column and look UP at the plastic under the ignition cylinder. There is usually a small diameter hole that you can stick a pin or pen cap up into that will allow you to rotate the key backwards.
