Related to multiple instances of cranking to start?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kgw, Apr 16, 2017.
  1. Apr 16, 2017 at 5:23 PM
    kgw
    kgw [OP] Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    I've noticed that when my v6 is warm and needs at least 2 cranks, usually 3, to start, I can hear an electronic noise, like a electric component charging up...A whine that starts low-toned and progresses to a high tone over a 3 seconds or so. Normal or abnormal?
  2. Apr 18, 2017 at 11:00 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    90% of the time when this happens it turns out the injectors are leaking down and the trouble is 2 fold, one, its flooded, or two, it lost fuel line pressure so it needs to build up fuel pressure before starting because the fuel pump only runs while the engine is being cranked or is running. it could also be a combination of both situations at the same time.
    get the truck warmed up then pull a plug and use bore scope to check if that injector is leaking, continue and repeat for all 6 cylinders until you check them all. you need to be quick because the leak/dripping may only go on for a minute or two at the most
  3. Apr 18, 2017 at 9:49 PM
    kgw
    kgw
    SoCal
    99 PreRunner
    Don't say that!!
    :anonymous: trying to avoid taking the plenum off again...
  4. Apr 19, 2017 at 12:09 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    3 cranks! That's nothing!
