Relay Block with OEM Switches
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rebel_Scum84, Jul 29, 2023.
  1. Jul 29, 2023 at 5:11 PM
    Rebel_Scum84
    Rebel_Scum84 [OP] New Member
    2022 Tacoma SR5
    I'm pretty much a novice but done quite a bit of wiring basics for my LED lights. I would like to know, if it's possible, to make a relay block and use my current wiring harness and OEM switches for my 2022 SR5. I don't plan on adding too many things with is why I don't really need a accessory panel, but would like to clean up the wires under my hood.
  2. Jul 29, 2023 at 8:17 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i don't believe most of the oem switches wiring goes to under the hood.
    i also wouldn't trust it for very much power.
    and it depends on which switches you're considering using.
  3. Jul 29, 2023 at 8:32 PM
    Rebel_Scum84
    2022 Tacoma SR5
    I had installed a light bar and sport bar lights using wiring harnesses that I use some OEM style switches I bought from Caliraised. I'll probably install one more set of ditch lights but might be difficult installing more wiring harnesses. I just like the look of using the OEM style switches.
  4. Jul 30, 2023 at 8:02 AM
    soundman98
    NW Indiana
    sorry, don't know what wiring you're currently using, which makes a difference.
    there's plenty of oem style switches that can be made to work. it's the part of "using the wiring i have" that is not likely a possibility.
