Relay for locker solenoid?
Discussion in 'Technical Chat' started by Naveronski, Jul 29, 2022.
  1. Jul 29, 2022 at 3:29 PM
    Naveronski
    Naveronski [OP] Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    For my lockers, I bought this switch:
    https://www.ch4x4.com/product/ch4x4-dual-push-switch-for-toyota-front-rear-lock-symbol/
    But, the solenoids for my lockers are only 5w.
    https://www.amazon.com/ARB-180103-Replacement-Solenoid/dp/B00042JHT4
    So using a calculator, https://www.thecalculatorsite.com/conversions/common/watts-amps.php
    12v 5w = 0.416667 amps
    Meaning the solenoids are waaaay under 3 amps, and should be fine without using relays.
    ...right?
  2. Jul 30, 2022 at 1:16 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    You should be fine. ARB does not run the solenoids through a relay but they do use a higher rated switch. I would run this circuit through a 5A fuse.
    I think I figured one time the solenoids can pull almost 1 amp. That might've come from measuring the resistance and assuming 14V or something. I don't remember.
    Naveronski[OP] likes this.
  3. Jul 30, 2022 at 1:18 PM
    Naveronski
    Fort Worth
    Good idea on the low amperage fuse, I can use that to ensure I don’t burn the switch.
    ShimStack[QUOTED] likes this.
  4. May 15, 2023 at 6:42 AM
    Naveronski
    Fort Worth
    Update: I've been using this with no issue since installation.
    Benson X and mic_sierra like this.
