Relay for rock lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ntc19, Oct 11, 2017.
  1. Oct 11, 2017 at 9:49 AM
    Ntc19
    Ntc19 [OP] Active Member
    i have rock lights that i wanna set up to a relay the relay only has a positive but it needs both positive and negative anyone have any solutions or advice
  2. Dec 23, 2021 at 12:15 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not sure what you are asking, a relay typically has 4 or 5 pins. 2 pins are control pins (typically pins 85 and 86 on a standard relay) one needs power and the other needs a ground to turn the relay on. The other 2 are the load you are powering (typically pin 87) and 12v fused power from the battery (typically pin 30).
    On a 5 pin relay 87a is the normally closed contacts.
  3. Dec 23, 2021 at 4:37 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Perfect explanation above. OP, if you still have questions, please clarify.
    reallifedog likes this.
  4. Dec 25, 2021 at 5:29 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    A relay is just a switch that can be activated by applying power a coil in the relay. In the pic above, pin 86 and pin 85 are connected to the coil. Supplying power to the coil will cause the switch to close, connecting pin 30 and 87.
    As shown in the pic above, you would use a relay to control the supply of power to the accessory you want to control. So pin 87 would supply 'positive' power to your accessory. For your 'negative', you just connect your accesory directly to ground / negative. There is no need to switch the ground. So the accesory positive gets connected to the relay (pin 87) and the accessory negative / ground gets connected directly to negative / ground (no relay needed for negative / ground)
    XSplicer62 likes this.
  5. Dec 26, 2021 at 12:25 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    When using a relay that has 87a and I don't need it; I put the 12v on terminal 87 and the load on 30. This way 87a isn't live, open to a possible short, when everything is off.
    Dm93 likes this.
