Relay/fuse panel for 3rd gen tacomas with crawl control.
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by paranoid56, Dec 19, 2017.
  1. Apr 7, 2020 at 8:58 PM
    #201
    SigBoy
    SigBoy Well-Known Member
    2020 TRD Off-Road, Access Cab
    Blank with crawl control (v2) "sits higher for later year trucks".
  2. Apr 7, 2020 at 9:45 PM
    #202
    paranoid56
    paranoid56 [OP] Well-Known Member
    San Diego
    14 double cab taco
    I will make up one tomorrow for you :D
  3. Apr 8, 2020 at 4:10 AM
    #203
    txranger83
    txranger83 Well-Known Member
    Colby
    Republic of Texas
    2020 Tacoma TRD Off Road
    what do you recommend for a 2020 w/ crawl control. Looking for one with the cutouts for bussman and circuit breaker
  4. Apr 8, 2020 at 7:38 AM
    #204
    paranoid56
    San Diego
    14 double cab taco
    to be honest, i am getting lost and confused with all the new trucks lol. got a pic of the engine bay in that area?
    Skydvrr likes this.
  5. Apr 8, 2020 at 3:24 PM
    #205
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    You can make anything fit with a grinder.
    Yann[QUOTED] and SSG (03)TACOMA like this.
  6. Apr 8, 2020 at 4:51 PM
    #206
    txranger83
    Colby
    Republic of Texas
    yes sir. I posted some pics in this thread. Just a page or two back
  7. Apr 8, 2020 at 7:11 PM
    #207
    paranoid56
    San Diego
    14 double cab taco
  8. Apr 8, 2020 at 7:13 PM
    #208
    paranoid56
    San Diego
    14 double cab taco
    looking at those, the v2 high ones should fit that perfect.
  9. Apr 9, 2020 at 4:04 AM
    #209
    txranger83
    Colby
    Republic of Texas
    So how do I go about getting a v2 with cutouts for a circuit breaker and bussman
  10. Apr 10, 2020 at 7:23 PM
    #210
    paranoid56
    San Diego
    14 double cab taco
    i would need to know part numbers of those items and where you want them. The issue is i dont know how well it will fit as i dont have that truck. Ie the amount of space below it.
  11. May 27, 2020 at 10:28 AM
    #211
    reymataco
    reymataco Well-Known Member
    Denver, CO
    2020 DCLB Off Road Premium in Slowsand
    @paranoid56 I got one of your V2 brackets for the 2020 OR w/ Crawl Control late last year.
    It looks like it will fit ok with a little tweaking, as others have pointed out:
    1) It looks like the vertical piece of the bracket with the two holes, needs some manipulating of the attachment angle (120 degrees, not 90) in order for the plate to sit level.
    2) The back corner by the brake booster is a bit tight, might have to take the hack saw and cut out a little nib there.
    All in all, very easy to overcome those issues, thanks for making a great product!
    I will post pics when I have something to show.
    Any update on the passenger side bracket? I have a metric fuck ton of space on that side:
    Thanks!
  12. May 27, 2020 at 12:10 PM
    #212
    dlovell90
    dlovell90 New build 5/1/19
    Derrick
    Waukee, IA
    2016 Tacoma TRD Off Road
    Billie 5100s OME 888s Fallen Wildpeaks Mamba m25s Lots of cosmetics MESO everything
    ok so i am in the starting stages of seting up a fuse panel due to all the switches my truck is accumulating. i realy like this simple design and its much more cost effective then others out there.
    Here is my details:
    -I currently have a blue sea 6 fuse system.
    -I will be getting a circuit breaker as well (not sure which one. I want Blue Sea but they are tad on high side so im considering a bussman one)
    -Not sure what else I need. I know ill need 6 gauge wire lead and negative wire lead. Copper connectors. but i feel like i need more. So if anyone has a parts list to provide thatd be killer
    But my question (finally I know), will the bussman and fuse box cutout work with blue sea system? It looks like it will; but im not sure if I should just get the blank panel. I can drill my own holes. But I like the clean look of the cut out.
  13. May 27, 2020 at 9:55 PM
    #213
    paranoid56
    San Diego
    14 double cab taco
    I made two passenger side ones so far, but have yet to get any pics back. let me get a pic of the one i made
    I dont think they will work, each cut out is different, I would go with the blank. the material is aluminum so its easy to drill
  14. May 27, 2020 at 10:21 PM
    #214
    Tonche
    Tonche Well-Known Member
    Tony
    2018 Tacoma TRD OR ACLB
    Which one would I need to fit a ARB pump on a 2018? V1 or v2?
  15. May 28, 2020 at 5:54 AM
    #215
    dlovell90
    Derrick
    Waukee, IA
    ok so I ordered the busman circuit breaker. So that should fit in the slot. But for the fuse block; you’re saying the blue sea may not fit? I’m just asking because the photo On the site looks like a blue sea fuse block shape but I can’t tell. I primarily really like the cut kit design on the side of the block where it mounts lol but I can just do blank too if I need to. Won’t be hard to drill.
  16. May 28, 2020 at 8:55 AM
    #216
    paranoid56
    San Diego
    14 double cab taco
    i always try to go with the V1 if it fits the truck, the fact that each truck seems different, its hard to tell. I am assuming thats the single pump right?
    sorry, i ment that it wont fit the cutout. but on the blank it will fit fine.
  17. May 28, 2020 at 8:57 AM
    #217
    dlovell90
    Derrick
    Waukee, IA
    oh gotcha. Ok i will get that blank ordered.
    Second question; do you (or anyone) have a write up of how to install all of this. I have done all my other wiring but I havent found a simple write up on what I need done. Most have so much more stuff to them that it is irrelevant to me. I simply just want all 4 of my switches to not have 4 fuse relays and wires crowding my engine bay :rofl:im just not sure what else I still need to get.
  18. May 28, 2020 at 9:09 AM
    #218
    Tonche
    Tony
    Yes the single pump.
  19. May 28, 2020 at 9:09 AM
    #219
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    I picked up an older style tray from a member on here, and it fit very well. I will be posting a write-up eventually.
    Older Paranoid tray, fits a 2017 Sport MT.
    I wrapped my hose coming out of the clutch/master cylinder in some conduit (red) that I had for added protection and used a zip tie to keep it below the tray.
    I was able to fit a 6 circuit Blue Sea fuse block, a negative terminal buss, and 4 relay holder from @TinyTech626 forever ago! on the mount.
    Thanks!
  20. May 28, 2020 at 9:51 AM
    #220
    dlovell90
    Derrick
    Waukee, IA
    Im gonna need first dibs on when this write up posts lol I already see a few things that I dont have that it looks like I may need (like that relay box) and I like some of the cosmetics you did for organizing. Looks great
