Relay holder
Discussion in 'Technical Chat' started by 2ski4life7, Mar 16, 2022.
  1. Mar 16, 2022 at 2:32 PM
    2ski4life7
    2ski4life7 [OP] Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Do you guys know of a good relay mount/holder?
    I have a blue sea but realize some items I should use a relay. This would be in the back of my truck as I have a battery there and setup for camping with my wedge.
    any decent ones for multiple relays that I could mount. Most I’ve seen are meant for the engine bay.
  2. Mar 16, 2022 at 2:43 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    How many relays are you looking to mount? There are many options out there.
  3. Mar 16, 2022 at 2:46 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I have one of these, haven’t installed yet.
    seems to be decent quality
    12V Auto Waterproof Fuse Relay Box Block [6 Bosch Style Relay Holder] [6 ATC/ATO Fuse Holder] Universal Relay Block Box for 12V Automotive Vehicles Cars Marine Boat Light Equipment https://www.amazon.com/dp/B07MR64XK1?_encoding=UTF8
  4. Mar 16, 2022 at 3:11 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
  5. Mar 16, 2022 at 11:17 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    You don’t buy a holder for a relay, you purchase a system that houses multiple relays and generally has the base wiring built in and includes the mount, very similar to an OE fuse box. A holder like that won’t be too hard to find, but if you aren’t particular an easy route is to find an old vehicle fuse/relay panel and mount it and trace the wires to use. If you are electrically savvy it would look like a pro install with little effort.
    Bivouac likes this.
  6. Mar 17, 2022 at 7:42 AM
    MR5X5
    MR5X5 Well-Known Member
    If you go this route, or any route for that matter, use a good copper wire and pay close attention to your crimping quality, particularly for high amperage circuits. A poor crimp will lead to resistance that will result in high localized heat and melted components. Ask me how I know....
  7. Mar 17, 2022 at 7:44 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    for anything above 5 amps or so I like to solder and heat shrink. The heat generated by the losses go up exponentially with current.
    Bivouac likes this.
