Relentless fab 2005+ Tacoma skid plate install guide
Discussion in 'Relentless Fabrication' started by RelentlessFab, May 10, 2012.
  1. May 12, 2012 at 9:24 PM
    whiteboy
    whiteboy Well-Known Member
    Cody
    Glendale, AZ
    '06 TRD sport
    Kings, alcans, 33's blah blah read my build thread in sig
    Yeah I know what you're talking about. I realized when I got there that I can't see shit because of the washers haha. I'm going to unbolt it tomorrow and move it around to see if that helps.
  2. May 12, 2012 at 9:30 PM
    whiteboy
    Cody
    Glendale, AZ
    '06 TRD sport
    Ok well I'm uploading a picture whenever it pops into my email. Basically my mid skid is pushed flush with my cross member but the tcase looks to hang just a little bit lower.
  3. May 12, 2012 at 9:36 PM
    whiteboy
    Cody
    Glendale, AZ
    '06 TRD sport
  4. May 17, 2012 at 12:41 AM
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    In the process of building an IFS skid...it's amazing the amount of tweaking I've had to do to ensure proper fitment! About 10hrs in at this point. Props to Relentless for mass producing these skids!
  5. May 24, 2012 at 4:45 PM
    Garftore
    Garftore Well-Known Member
    Sam
    Oahu, Hawaii
    '11 T|X, BLACK
    OME 9000s/ TrimPacker/ 886s/ N182s/ Dakars+AALs+Shims, LR UCAs, BakFlip F1 Bed Cover, AMP MotoXtender, FrontBed OEM Tiedowns, PopLock RearCam Tailgate Latch, RFab Steel Bumpers (Front-Full BrushGuard + mounted Warn x8500i, Rear-OEM style) & Welded Kickout Rails, 16" TRD Wheels, 1.25" SpiderTrax, 285/75 Toyo MTs, Chopped Body Mounts.
    Will the plates fit with a 1" front diff drop? If not, can mods or spacer blocks make it work?
  6. May 24, 2012 at 5:20 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    yes it'll fit with the diff drop
    http://www.tacomaworld.com/forum/re...lates-gb-sale-3-15-4-15-a-42.html#post5107220
  7. Jun 22, 2012 at 10:51 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    From personal experience, ratchet wrenches are highly recommended. When you have the mid skid and tcase skid on, it's pretty hard to get to the 4 cross member bolts that hold both those skids on.
  8. Jul 3, 2012 at 6:14 PM
    george2pak
    george2pak Well-Known Member
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    Brute Force Fab front& rear bumper with winch, sliders, skid plates by Relentless, tires 285/75/16" , wheels by SCS , CB Stryker SR497 etc
    Do I have to remove those bars in order to instal the IFS skid?
  9. Jul 3, 2012 at 6:15 PM
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    yessir! and then reuse 4 of the bolts from it for the forward mounts of the IFS skid.
  10. Jul 3, 2012 at 9:44 PM
    george2pak
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    I'll give it a try tommorow.
  11. Jul 17, 2012 at 9:00 PM
    george2pak
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    Did you solved this issue? I have the same problem?
  12. Jul 17, 2012 at 9:37 PM
    RelentlessFab
    Eric
    Sparks, NV
    Hmm shouldnt be having that issue, thats why it has that existing notch in the side plate.
    You could probably just loosen the front bolts and drop the front of the skid down a 1/8-1/4" and the issue would be gone. Or grind it a tiny bit if you dont want to adjust the skid down at all.
  13. Jul 31, 2012 at 9:23 PM
    george2pak
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    Some pictures. I don't see no notch. Should I grind like in the picture?
  14. Jul 31, 2012 at 9:27 PM
    RelentlessFab
    Eric
    Sparks, NV
    The little step down at the front of the skid is the notch I mentioned. Just grinding a tad like your drawing is probably your best solution George
  15. Jul 31, 2012 at 9:41 PM
    #35
    george2pak
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    Thank you!
  16. Jan 13, 2013 at 11:25 AM
    #36
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    I am glad this post is here. I was about to bolt my IFS Skid on and was wondering if the front "U" channel braces would be removed or WTF, so I searched and found this nice DIY Guide. Thanks guys!
    By the way, I painted mine with Eastwood Extreme Chassis black and primer was their Extrem chassis black primer. Look good (satin black) and has held up well on my sliders. doesn't scrape off even on rocks.
    TW rocks!
  17. Jan 13, 2013 at 11:36 AM
    #37
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    That Taco looks familiar.
    Looking forward to installing them & leaving them on soon.
  18. Jan 13, 2013 at 3:54 PM
    #38
    Desert Drifter
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Front (IFS) skidplate went on super easy and how the hell can they call the stock thing it replaces a skidplate?
    So should I buy the middle skidplate to protect more of my truck?
  19. Jan 13, 2013 at 3:59 PM
    #39
    RelentlessFab
    Eric
    Sparks, NV
    Bet you are Randy! :)
    LOL, I know right? They're stamped sheetmetal probably no thicker than the trucks fenders.... and we all know how easy those dent!
    If you want to protect more of the bottom of your truck, next skid after the IFS I would add is the Tcase skid. It is the most likely to get hit in a break-over situation, and will also protect the exhaust cross-over from being crushed. The transmission is somewhat less vulnerable.
  20. Jan 13, 2013 at 4:12 PM
    #40
    whiteboy
    Cody
    Glendale, AZ
    '06 TRD sport
    Just get the full set already. You'll end up doing it eventually.
