Relentless Fab. '96-2004 Tacoma Rear plate bumper
Discussion in 'Relentless Fabrication' started by RelentlessFab, Mar 24, 2011.
  1. Mar 24, 2011 at 1:19 PM
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Hey everyone, here it is! The Relentless fab 1996-2004 Tacoma off-road rear plate bumper!
    UPDATE! As of June 2019 production of these bumpers has been discontinued. We do still offer our wrap around version for the 96-04 Tacoma's though: https://www.relentlessfabrication.c...ts/96-04-tacoma-wrap-around-rear-plate-bumper
    Key features:
    - Made from 3/16”, ¼”, and ¾” thick steel, CNC cut and bent, and MIG welded for unbeatable quality and rugged good looks with the strength to back them up.
    - Improved clearance over low hanging factory bumper and hitch.
    - Mounts through 1/4" steel mounting brackets, and uses 4 mounting points per side of frame. Compare this to our competitors using only 1-2 bolts per frame rail being held in shear!
    - Standard integrated 3/4" steel recovery points are through welded directly to the mounting plates for strength to handle all recovery situations! No surface welded 'recovery' points here!
    - Standard hi-lift jack lifting notches on every bumper
    - Standard cutouts for factory license plate lights to be reused
    - Each bumper is hand made to order to your exact specifications.
    - Approximately 75lbs base bumper weight.
    - Modified mounting for trucks with body lift is available. If a body lift is installed, please specify how much body lift is on your truck when ordering otherwise a bumper for a standard truck will be sent (0" body lift).
    Pricing:
    Base rear bumper with recovery points starts at $679 + shipping.
    Additional options available. Check out the bumper with additional details at Relentlessfabrication.com
    Installation:
    No vehicle modification is necessary to install. Simply remove the factory rear bumper and bolt the beefier Relentless rear plate bumper up with basic hand tools!
    **Factory tow hitch will NOT work with this bumper. I can integrate a hitch into the bumper, but since I cannot get it officially tested like the factory hitch, it comes unrated for capacity and full responsibility and liability is on you if you decide to tow with it. I'm sure you can understand where i am coming from, theres just a lot of liability there that I can't claim for on-road use. These are off-road bumpers.
    Please allow time for your bumper to be expertly crafted to your specs. We build as quick as possible, but quality like this takes some time. Great looks, unbeatable quality and solid design is found in every Relentless product. Complete customer satisfaction in our product is my goal!
    Sample pictures:
    Pictured is base bumper for a 3" body lifted application.
    Jason's rear with: 3" body lift mod, receiver hitch, custom backup light cutouts, and swing-out tire carrier option.
    Bumper with back up light recesses and hitch
  2. Mar 24, 2011 at 1:25 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    :ohsnap:
    Once again Eric you designed a sweet bumper!!!
  3. Mar 24, 2011 at 1:26 PM
    Rucas
    Rucas 1st gen
    Lucas
    Northern Colorado
    1st gen. 4x4
  4. Mar 24, 2011 at 1:31 PM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    Sick....do you have a front bumper to match the rear?
  5. Mar 24, 2011 at 1:35 PM
    RelentlessFab
    Eric
    Sparks, NV
    Thanks! :)
    :D
    Should have one done within a week. :)
  6. Mar 24, 2011 at 1:38 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    :yay:
  7. Mar 24, 2011 at 4:48 PM
    RelentlessFab
    Eric
    Sparks, NV
  8. Mar 24, 2011 at 4:59 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    Looks good.
  9. Mar 24, 2011 at 5:02 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
  10. Mar 24, 2011 at 5:14 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    :drool: Lookin real good!
  11. Mar 24, 2011 at 5:27 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    Dont think so, the ass of these trucks are way up anyway.
  12. Mar 24, 2011 at 7:15 PM
    t0mills
    t0mills Well-Known Member
    TRD, Gray Wire Mod, 3" Suspension lift, 3" Body Lift, 285/75 AT2s
    Nice!
    Make it wrap around the bed sides, add dual swing-outs (tire on one, jerry cans and hi-lift on other), and make a spot for a 8k lb winch, and I'll buy one!
  13. Mar 24, 2011 at 7:17 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    i like that bumper! the only thing is is that i would want one with a class 3 hitch as well, or would this just fit around the hitch i already have?
  14. Mar 24, 2011 at 7:20 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    sexiest rear bumper ive seen on a 1st gen :drool:
  15. Mar 24, 2011 at 7:57 PM
    RelentlessFab
    Eric
    Sparks, NV
    Weather broke just long enough this after noon to take a few new pics. Uploading them now so you guys can see it clearer.
    And thanks for all the positive responses!
    Tire carrier and winch mount WILL be available! :D
  16. Mar 25, 2011 at 8:46 PM
    RelentlessFab
    Eric
    Sparks, NV
    Updated the OP with pics in better weather. :)
    Front plate bumper is in development for those who would be interested in a complete package; front and rear, front and sliders, rear and slider, front rear and sliders, etc. I will have package discounts for orders of more than 1 armor product in a single order, plus you can take advantage of cheaper shipping as each additional armor piece adds only $20/ea to the Fastenal shipping rates listed above. :)
  17. Mar 26, 2011 at 8:38 AM
    TacoMatt02
    TacoMatt02 Well-Known Member
    South Carolina
    02 sr5 double cab
    Very nice work, any plans for a plate wrap around instead of tube?
  18. Mar 26, 2011 at 11:05 AM
    RelentlessFab
    Eric
    Sparks, NV
    It could be a possibility. I'd have to tweak the dimensions a little to make the sides stick out farther by about an inch to allow room for the plate wraps.
  19. Mar 26, 2011 at 6:07 PM
    t0mills
    Definitely hope this is an option!
    I'm interested to see what you come up with for a front bumper. Hopefully I'll be buying a pair from you soon.
    Also, good to see that you're offering options for bodylifted trucks. I know they're frowned upon, but my truck had one when I bought it, so I'm not going to bother removing it.
    Keep at it, and let me know when you're ready to start selling.
  20. Mar 28, 2011 at 8:46 PM
    RelentlessFab
    Eric
    Sparks, NV
    Sounds good. Same here, when we got the GF's truck(pictured) it had a 3" body lift installed from the previous owner. Not my favorite thing to have installed but I can live with it I suppose.
    As for when I'm ready for orders, I'll take orders for the standard bumper and options listed now but there is a decent lead time with all my other orders piled up right now.
