Relentless Fab Bolt-On Rock Sliders
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RelentlessFabrication, Dec 5, 2018.
  1. Dec 5, 2018 at 2:05 PM
    RelentlessFabrication [OP] relentlessfabrication.com Vendor
    Sparks, NV
    UPDATE 2/27/19 - SLIDERS HAVE BEEN REMOVED FROM OUR SITE TO FOCUS ON REDUCING BUMPER LEAD TIMES. OUR APOLOGIES ABOUT THE INCONVENIENCE.
    One of the most vulnerable parts of your vehicle when going off-road is your rocker panels. Be it a rock, log, branch, or even just that dirt pile you’re driving over, anything hitting your lower rocker panels can cause some serious and unsightly damage before you even realize what is happening. Factory or aftermarket steps installed leave a false sense of security and before you know it a rock will push the steps in leading to more damage to the vehicle.
    What you need is some affordable protection available in versions that either bolts or welds directly to your vehicle’s frame! Relentless Fab rock rails will do the job through years of abuse and punishment, all while complementing your vehicle's looks. Not only will they fend off damage from trail obstacles, but they can also serve as a hi-lift jacking point anywhere along their length. Further, they can be used as steps to get in or out of the vehicle or to aid in accessing a roof rack.
    Relentless Fabrication - 2016+ Tacoma Bolt-On Rock Sliders
    Key Features:
    - USA 2x2” square .120” thick steel tube and 1.75” x.120" DOM round outer tube structure.
    - Oversized 3/16” thick gussets and CNC cut and formed 1-piece continuous frame plates.
    - Standard straight outers with 15* up angle, optional kick-outs or filler plates available.
    - Bolt-on design that lines up with all factory frame holes! Optional holes in the bottom of mounts for additional holes if the utmost strength desired, and some factory holes may need to be made larger for our oversize 1/2" hardware.
    -Powder Coated option is Matte Black Only
    - Sold as a pair of rails (driver and passenger sides, side specific).
    Starting at $639!
    www.relentlessfabrication.com
  2. Dec 5, 2018 at 2:10 PM
    Dr TMAC
    Dr TMAC Well-Known Member
    Taylor
    Houston, TX
    2017 Black Toyota Tacoma TRD OR 4X4 DCSB
    Since I need a slider that is also a step because my wife reminds me every time she hops in she wants me to put the predator steps back on... Is 15 degrees angled up a terrible step, or it will do?
  3. Dec 5, 2018 at 2:13 PM
    Quimby
    Quimby Well-Known Member
    NYC
    2017 TRD OR AC
    Does the bolton version work fine with a hi-lift?
  4. Dec 5, 2018 at 2:13 PM
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    It's not that bad. Have em on my truck and step up then sit down.
  5. Dec 5, 2018 at 4:58 PM
    Sparks, NV
    The 15-degree angle is very slight and shouldn't be a problem for most. The filler plate option is popular among those that need a little bit of a boost - it offers more of a stepping surface. We also offer the filler plate at the standard angle if you want maximum stepping surface.
  6. Dec 5, 2018 at 5:00 PM
    Sparks, NV
    Yes, you can use these as a jack-point anywhere along their length.
  7. Dec 6, 2018 at 8:13 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    If only that first option came as a weld on with filler plates! Just checked your site and didn't see it as an option.
  8. Dec 6, 2018 at 8:34 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    Is there an option for 2016+ Double Cab Long Bed?
  9. Dec 6, 2018 at 3:54 PM
    Sparks, NV
    We offer these as bolt-on only, sorry.
    It's still in the works :thumbsup:
    paleh0rse[QUOTED] likes this.
  10. Dec 6, 2018 at 9:02 PM
    paleh0rse
    Raleigh, NC
    Fair enough. Please post here once it's available!
  11. Dec 7, 2018 at 12:37 PM
    Sparks, NV
  12. Dec 11, 2018 at 1:28 PM
    Sparks, NV
  13. Dec 27, 2018 at 3:10 PM
    Sparks, NV
    We hope everyone enjoyed the holiday weekend! We are back in the shop today and tomorrow, then will be closed through New years day 1/1/19. You guys must have missed us because the shop phone has been ringing off the hook!
    : @alphathetaco always looking so cool ❄ with our #summit series bumper.
    https://www.instagram.com/p/Br6Hc0Gn-c3/
  14. Dec 27, 2018 at 4:23 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
  15. Dec 27, 2018 at 4:34 PM
    RizzoInOmaha
    RizzoInOmaha New Member
    Rizzo
    2003 Lexus IS300
    big turbo, 6spd swap, built motor
    They look great. I think they fit the flow of the Taco better then the factory OEM oval/tube style.
  16. Dec 29, 2018 at 11:41 AM
    Sparks, NV
  17. Dec 29, 2018 at 11:41 AM
    Sparks, NV
    Thanks! We appreciate the feedback :cool:
  18. Dec 29, 2018 at 12:16 PM
    thedriza
    thedriza Well-Known Member
    Portland, OR
    2017 Tacoma DCSB
    5.29 gears, OME HD lift, OVTune
    Couldn't one person just order bolt on sliders and then later on decide to weld them?
    Or is the install process different?
  19. Dec 30, 2018 at 4:04 PM
    Sparks, NV
    You definitely could install bolt-on sliders and later weld them on. Our 1-piece continuos frame plates could be welded directly to the frame if desired
  20. Feb 26, 2019 at 9:23 AM
    Tahoereeves
    Tahoereeves Well-Known Member
    Reno, NV
    2016 TRD OR
    Are the 3rd gen sliders still available? Just checked your website and they're not listed.
