Relentless Fab T-Case Skid plate fitment issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 23, 2013.
  1. Jun 23, 2013 at 8:55 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It's an insanely tight fit, like the specs of it were off when they designed it or the specs of my truck is off, one or the two.
    Either way, I have a couple questions, I can put it up but it refuses to line up with the 4 bolts in the front (For the record I am NOT running the IFS skid which is the second piece of the setup, nor the front skid plate). It's super close but the fit is so tight, if I do manage to get the plate lined up to all 4 holes, the plate will not line up in the rear on one side, but the other side has plenty of give on it's side. Was the plate designed to be mounted and fit perfectly with the rest of the setup or can it be installed independently and work without the rest of the other plates?
    I hope that all made sense.
  2. Jun 23, 2013 at 9:03 PM
    motionridr8
    motionridr8 Well-Known Member
    Drew
    Greenville, SC
    2012 Tacoma 4x4 DCSB
    5100's/886's/JBA UCAs, ICON RXT Rears, US Offroad Winch Front Bumper, BAMF Rear Bumper, 235/85r16 Skinnies
    hmm. interested in this since I was going to buy a full set for my DCSB... pics?
  3. Jun 23, 2013 at 9:39 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not at the moment, I was too busy cursing and attempting fitment after fitment.. I gave up for the night after stripping two of the long bolts up front which holds onto the crossmember in the front of the T-case.
    On a small sidenote though I did take some actual measurements of the 2 bolts on the drivers and the 2 on the passenger side and I found they are similar in measurement which ended up being something like 3 7/8" apart from eyelet to eyelet of the bolts, the measurements from the skid plate (after I widened the holes a little, which I shouldn't have to really do) is pretty close to those measurements as well, so I am not seeing the problem is. I am thinking maybe the actual metal on the back of the skid plate's walls (the part where you need to drill the holes on your frame at) is out of tolerance and are too wide for the frame, therefore causing the actual issues.
    The plate was so tight to put in on the rear when I was attempting to test fit it, that I actually had to bang on the plate with a hammer for it to fit in between the frame which I would imagine I shouldn't have to do either.
  4. Jun 23, 2013 at 9:41 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Have you contacted Eric ?
  5. Jun 23, 2013 at 9:50 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not yet. I purchased the plate from a member on here a while back and I have been to busy to put it on since then. Even if he could do something for me though I'm sure it would be somewhat of a long drawn process due to shipping to me and shipping back and all.
  6. Jun 23, 2013 at 9:51 PM
    OZ-T
    Peter North
    British Columbia
    Just meant he may have some insight into why it is not fitting for you
  7. Jun 23, 2013 at 9:53 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ah! I just thought of why you said that after I posted it. Lol.
    Just to make sure, Eric is Relentless Fabrication right?
  8. Jun 23, 2013 at 9:57 PM
    MikeyTG
    MikeyTG Oh Herro
    Oahu
  9. Jun 23, 2013 at 9:57 PM
    OZ-T
    Peter North
    British Columbia
  10. Jun 23, 2013 at 10:00 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Thank you very much! I will contact him and get back to this thread for the member who was thinking of picking up a set so he knows whats going on, and just in case anyone ever has an issue like this one day.
  11. Jun 23, 2013 at 10:20 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    V6 exhaust crossover maybe?
  12. Jun 23, 2013 at 10:21 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I was thinking the same thing but I do not see the plate hitting anywhere. The plates have a specific cutout to avoid contact with the crossover.
  13. Jun 23, 2013 at 10:22 PM
    OZ-T
    Peter North
    British Columbia
  14. Jun 23, 2013 at 10:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Here is what the plate looks like, it's actually the picture from the same guy who sold it to me.
    The cutout for the crossover pipe of the V6 is to the lower left. The walls which hit and interfere if I line up the 4 mounting points up front are at the lower left and lower right.
    That's actually the same set of directions that I read earlier before I attempted to install it just to make sure there wasn't something special I needed to do.
  15. Jun 23, 2013 at 11:21 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    The holes on the front are CNC plasma cut. That shouldn't be your issue. It sounds like it's the legs. Eric measures the legs and plate width to account for frame width and leave some wiggle room. Sounds like the frame braces are too wide or your frame is different from others'. Give the shop a call in the morning, if you can measure between the two L plates, that'd be helpful. Not the bottom part with the hole but between the pieces that fit next to the frame on the inside.
    It could be your frame is tighter than most or it could be the legs are too long. I'm going to assume the member who sold it to you didn't have any issues or he wouldn't have gotten the holes drilled or sold it to you without letting you know?
    Mine fits perfect for what it's worth, but it was the first :p. I know this isn't a common issue regardless. He's pretty careful to measure the width of each one after it's all welded. They are different lengths on each side though oddly enough. Might also be helpful to measure from tip to tip on each leg -- inside of plate to outside of skid.
    Shop Phone
    (775) 200-0544
  16. Jun 23, 2013 at 11:34 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Interesting information.. Yeah the right side (passenger side) has some wiggle room, it's the left side (drivers) which is insanely tight to the point where if I do not use a hammer to bang it in, it won't even get close to going, it's actually slightly longer tell you the truth. The previous member only had the rear mounted he said for some reason, maybe he was having the same issue too?
  17. Jun 24, 2013 at 12:07 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Yeah, call in the morning, and give them some measurements. I showed Kolt this thread so he has a heads up.
  18. Jun 24, 2013 at 12:24 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Shooting for 40 1/8th" I believe.
  19. Jun 24, 2013 at 12:51 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    overall length from wall to wall?
  20. Jun 24, 2013 at 1:31 AM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    X2 on calling Eric he is extremely helpful and makes a good product and stands behind it
