Relentless Fabrication Rock Sliders for Double Cab
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by paquu, Dec 30, 2024.
  1. Dec 30, 2024 at 11:53 AM
    paquu
    paquu [OP] Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    These are Relentless Fabrication weld-on steel rock sliders for a 1st gen (1995-2004) toyota tacoma double cab.
    Looking to sell locally in the Rhode Island area. $600. PM me for additional details.
    I purchased these from relentless fabrication for my 2002 tacoma double cab years ago (Relentless fabrication no longer sells these, and they arent on their site). I primed them, bedlined them, and put them in storage (they could use a rinse). I never got around to installing them, so the mounting surfaces are still fresh for welding. The last image is an example of these kind of rock sliders installed on a 2nd gen tacoma (Its not my truck). I recently sold my truck and no longer need these.
    Below is a copy/paste product description...
    "Key Features:
    USA sourced 2x2” square x.120” steel tube inner structure and 1.75” x.120" DOM round outer tube structure.
    oversized 3/16” thick CNC cut gussets and frame plates.
    Outer rail sits at a 15deg up angle as standard.
    Weld on mounting Only
    Installation is weld-on. Line up the appropriate side slider to the frame, position it between the wheel wells in the desired location and mark where the mounting pads line up on the frame. Sand off the paint from the frame in those locations and on the edges of the slider mounting pads. Once clean and ready to weld, hold up the slider with about 1/2inch clearance between the top of the standoff tubes and the pinch weld along the bottom of the cab, then tack in place and fully weld around plates. Paint the bare metal after it has cooled. If you want the slider to sit higher, the pinch weld can be marked where each slider leg is positioned and the pinch weld can be cut vertically and folded back. If this method is done, maintain the previously mentioned 1/2inch clearance around the legs, front, back and top.
  2. Jan 6, 2025 at 7:49 PM
    paquu
    RI
    42" LED bar
    Bump
  3. Jan 12, 2025 at 1:34 PM
    paquu
    RI
    42" LED bar
    Bump
  4. Jan 23, 2025 at 1:49 PM
    paquu
    RI
    42" LED bar
    Bump
  5. Jan 25, 2025 at 2:59 PM
    Madjik_Man
    Colorado Front Range
    If you weren't 2000 miles away these would be on my truck already.
    Area51Runner and paquu[OP] like this.
  6. Jan 28, 2025 at 4:50 PM
    paquu
    RI
    42" LED bar
    Bump
  7. Feb 9, 2025 at 12:28 PM
    paquu
    RI
    42" LED bar
    Bump
  8. Feb 15, 2025 at 2:05 PM
    paquu
    RI
    42" LED bar
    Bump
  9. Feb 23, 2025 at 10:29 AM
    paquu
    RI
    42" LED bar
    Bump
  10. Mar 12, 2025 at 2:31 PM
    paquu
    RI
    42" LED bar
  11. Apr 27, 2025 at 1:15 PM
    paquu
    RI
    42" LED bar
