Reliable gear shop in CT
Discussion in 'North East' started by Jpiskura, Nov 21, 2019.
  1. Nov 21, 2019 at 6:34 PM
    Jpiskura
    Jpiskura [OP] Well-Known Member
    Hello, I am looking for some help with my gear install and I cannot seem to come up with anyone in my area. I am in the New Haven area in Connecticut, any help would be appreciated!!! Thanks so much!!
  2. Nov 21, 2019 at 6:36 PM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
  3. Nov 22, 2019 at 4:59 AM
    Jpiskura
  4. Nov 22, 2019 at 10:53 AM
    Jpiskura
    I guess I should clarify, I was looking for a shop.. I used to have a shop close to me when I had my Jeep and it seems that offroad shops around here have gone the way of the dodo....
  5. Nov 22, 2019 at 11:01 AM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    That's kind of what I have gathered from here over the past few years,there are a few in the state but most of them are $$$. A lot of the people will suggest someone in the state who can help you for any projects. That forum is a great place to ask for a local shop for a job like that.
    Adding @Cativelense
    Cativelense likes this.
  6. Nov 22, 2019 at 11:10 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    i dont have first hand experience with this place, but here is just a lead for you on a shop in danbury https://www.evb.cc/
    did you already buy the gears? and now just want to have them installed into your clamshell?
  7. Nov 22, 2019 at 11:18 AM
    uurx
    '12 t|x pro
    also might be worth contacting ECGS and asking if they have any recommended installs in the CT area, they have very good customer service
    SR-71A likes this.
  8. Nov 22, 2019 at 11:21 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    EVB here in Danbury.
  9. Nov 22, 2019 at 11:26 AM
    Jpiskura
    Honestly I have given EVB two chances to return phone calls, and emails and I have gotten NOTHING from them back. A buddy went there to have some gears put into his tundra and they have been jerking him around since February... I will NOT be going to EVB for anything strictly on their shitty "customer service." Thank you for the recommendation tho… Danbury is a quick half hr ride for me so that place would be ideal if they would ANSWER PHONE CALLS.
    NatesTaco718 and uurx like this.
  10. Nov 22, 2019 at 11:27 AM
    Jpiskura
    I might ask ECGS when I place the order for my gears... I was hoping to just do a whole third member from them.. I have no problem doing it, but I don't have a big enough garage to tear apart my entire truck to do the front and rear at the same time...
    uurx[QUOTED] likes this.
  11. Nov 22, 2019 at 11:28 AM
    Cativelense
    Nuno
    CT
    OUCH
    That sucks. Sorry, I don't really know of any others. And I only know of that one because @KeithB mentioned it for something I asked about a while back, and they are right around the corner from where I work.
  12. Nov 22, 2019 at 4:36 PM
    Jpiskura
    Again thank you for the input!
    Cativelense[QUOTED] likes this.
  13. Dec 3, 2019 at 12:52 PM
    amag413
    amag413 Well-Known Member
    Aaron
    Philly
    2014 Black Tacoma TRD Sport | Double Cab SB
    JD Fab 2.25 kit, Homemade flatbed, Four Wheel Camper
    Main line overland in Bow NH does re-gears. they do great work.
  14. Dec 4, 2019 at 6:15 AM
    Jpiskura
    Awesome thank you!
  15. Jan 14, 2020 at 5:46 AM
    Danactive
    Danactive Instagram: xxdanactivexx
    Dan
    Upstate New York
    2016 MGM TRD Sport 4x4 DCSB
    Check Out My Build Thread :)
    just curious if you're buying from ECGS why not just go there and have them do the full install? I'm driving down in a few months from NY to have them do my gears since i don't really know of any trust worthy east coast shops... a few days to do it but well worth it from what i've been told.
  16. Jan 15, 2020 at 8:20 AM
    Jpiskura
    I am going to be going through ECGS but not sure I can justify to the wife scooting away from her and the little dude for a long weekend especially when I could just rent a car and have the job done at home.. IF I really wanted too....
