Reloading BS thread
Discussion in 'Guns & Hunting' started by 95 taco, Jan 4, 2013.
  1. Feb 27, 2014 at 7:31 AM
    #361
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Yes, a brand new case fits in flawlessly.
    The description of the 3-die set that I have doesn't say anything about a crimp.
  2. Feb 27, 2014 at 7:41 AM
    #362
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    If it does not have a crimp die, then how do you remove the bell from the mouth of the case?
  3. Feb 27, 2014 at 8:06 AM
    #363
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Many Lee die sets use the bullet seating die ad the criplmp die as well. Remove the seating stem and flip it over, it is now a taper crimp.
  4. Feb 27, 2014 at 8:08 AM
    #364
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Cowboy: the Win 748 also has a lower burn temperature, so you might get a couple extra rounds fired before the bbl starts to get hot
  5. Feb 27, 2014 at 8:14 AM
    #365
    CowboyTaco
    North Georgia
    11 TRD Sport
    :confused:
    Any idea if the .44 special 3-die set does that? I'm assuming it would be in the slip of paper that came with the set. I'll have to check when I get home.
    I was just commenting to someone who suggested that powder to someone else a few pages back, but that's definitely good to know.
    On a different note, how's that new baby doing?
  6. Feb 27, 2014 at 10:25 AM
    #366
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Bell?
    Do you enlarge the case mouth to better accept the bullet before seating the bullet?
  7. Feb 27, 2014 at 10:36 AM
    #367
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Yes, only on sraight wall cartridges. Size, then bell, then seat, then crimp.
  8. Feb 27, 2014 at 10:39 AM
    #368
    TACO TX
    Kelly
    Denison ,Texas
    Yes Lee three die pistol sets crimp. I always set the die to not crimp and seat first, then screw out seater plug and crimp seperate. Makes for a much nicer cartridge. All .44 bullets will have a crimp groove. You want to seat bullet till case mouth is even or just above the groove.
  9. Feb 27, 2014 at 11:58 AM
    #369
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    the baby is doing great thank you for asking. And the 3 die sets should have the crimp feature also.
  10. Feb 27, 2014 at 12:11 PM
    #370
    CowboyTaco
    North Georgia
    11 TRD Sport
    Well that might save me $18 +tax!
    I'll look into that either tonight or sometime over the weekend. Now y'all have me excited thinking I have everything I need already. Much better feeling than feeling like I need to spend more money!
  11. Feb 27, 2014 at 3:22 PM
    #371
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    I think he left out the word "luck" after the word "good". Revolver rounds NEED to be crimped to hold the bullets in the case. If one slides forward some, you now have a locked up revolver.
  12. Feb 27, 2014 at 3:31 PM
    #372
    CowboyTaco
    North Georgia
    11 TRD Sport
    so for the lee dies, would taking the seater stem and flipping it over effect the die depth? I have thee Hornady Lock and Load press, so I'd like to avoid having the adjust the depth each time if I can avoid it.
  13. Feb 27, 2014 at 3:47 PM
    #373
    45longcolt
    DFW Area
    2020 Off Road
    That is where the LEE FCD comes in so you can keep the seat die adjusted to seat only, not crimp and seat at the same time.
  14. Feb 27, 2014 at 3:51 PM
    #374
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    Yep, I usually only taper crimp my .45 colt loads but then I usually only shoot light cowboy action loads that I am not too worried about moving from recoil (light recoil). I need to get a factory crimp for my heavier/magnum powered loads
    On that note, I finally got to chronograph some of my heavier loads (I should have factory crimped. Oh well). With a 300 grain jacketed soft point, 13.8 grains of blue dot, and a cci 350 large magnum pistol primer I am getting around 1050 fps average of 5 shots. I need to get a factory crimp die and load some h110 loads. The blue dot is a lot of fun though
    Disclaimer: check your book before using this data, I am loading for a ruger black hawk not a SAA
  15. Feb 27, 2014 at 4:16 PM
    #375
    45longcolt
    DFW Area
    2020 Off Road
    I got a BlackHawk and a RedHawk in 45 Colt. The Single action is convertible to 45 ACP. The RedHawk is a 4" and the Black Hawk is 7.5". The best velocity out of the 4" is 1138 FPS, 300 grain Cor-Bon hunting load. Below is the muzzleflash those rounds gave me. I use 2400 mainly, H110 for the hottest loads. Check out Belt Mountain Bullets, they have some brass ones with a tiny lead core for legality and weight purposes. They are expensive but I got a few of them for those hard pesky hogs we have now.
    https://dl.dropboxusercontent.com/u/10728824/GunStuff/640MBRH.bmp
  16. Feb 27, 2014 at 4:58 PM
    #376
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Heh. "but good" is a phrase that means something like "to a high degree."
    http://en.wiktionary.org/wiki/but_good
    Basically, if a bullet in another cylinder shifts out of the case due to recoil of the round in a fired cylinder, it can really lock up your revolver to the point where the cylinder won't rotate.
    Sorry for the old timey phrase. :laugh:
  17. Feb 27, 2014 at 5:48 PM
    #377
    crazyengineer
    patrick
    Bristol, TN
    that fireball...I...I....I need that lol.
    The hot load that I am using is just under max loads, and my brass is pretty much still falling out of the gun rather than sticking. I am gonna try to get 1800 fps out of a 180 grain JHP sooner or later...I need to get a chrony. I really need to start loading 5.56/.223 for my AR. I haven't loaded any rifle as of yet, I have a set of .223 dies, can I use them to reload 5.56 or .223? I have a lot of mixed brass that I am gonna be loading. I think that I am gonna separate the 5.56 and .223 brass, but beyond that I'm not too worried about it.
    I also have 250 pieces of primed and flared .45 colt brass that is just waiting to be loaded. They are getting loaded with 200 grain lead SWC and titegroup (which my powder measure likes)
  18. Feb 28, 2014 at 3:23 AM
    #378
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    If you're loading for the AR, seperate your brass by headstamp ( I mean 5.56 or 223). You will get different results out of them with the same load.
  19. Feb 28, 2014 at 5:27 AM
    #379
    crazyengineer
    patrick
    Bristol, TN
    That is what I was planning, but other than that do I need to worry about anything?
  20. Feb 28, 2014 at 7:19 AM
    #380
    TACO TX
    Kelly
    Denison ,Texas
    The reason you get different results is because .556 brass is generally thicker therefore you have less case capacity which causes higher pressures. Just be sure and stick to loads specific to AR-15's. Dont use data designed for bolt guns in .556 brass in your AR. Or you can decrease rifle data by 10%.
