Reloading BS thread
Discussion in 'Guns & Hunting' started by 95 taco, Jan 4, 2013.
  1. Feb 28, 2014 at 7:15 PM
    #381
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    Ok, I'll make sure I
    Using AR data, I am gonna have to clean and sort my brass first, so it may be a while before I start loadin
  2. Mar 8, 2014 at 8:18 PM
    #382
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
  3. Mar 10, 2014 at 6:31 AM
    #383
    nomad_archer
    nomad_archer Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    Hornady is one of the few the publishes 5.56 specific loads. If you AR is stamped to run .223/5.56 than you can run either but you need to make sure you are using a .223 load in your .223 brass and 5.56 load in your 5.56 brass. If the .556 is mil surplus brass you will have to remove the crimp in the primer pocket before seating the new primer.
    You can use the .223 dies for loading 5.56 since the outside case dimensions and bullet dimensions are the same. The difference as stated before is that 5.56 brass has thicker case walls.
  4. Mar 16, 2014 at 6:22 PM
    #384
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    I tried the "flipping the bullet seat die over" method and don't see how that could work. I put it back together and decided to get a separate die to crimp. I have the Hornady Lock-n-Load system, so I don't want to adjust every time.
    I finally got my crimp die for the .44. It's amazing what .002" difference makes. The cases all fit flawlessly now.
    Now I just gotta get to the range and test :D.
    Thanks to all who provided advice!
  5. Mar 17, 2014 at 8:05 AM
    #385
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Yeah its not the bullet seating stem, its the expander that you flip over to be used as a crimp. That is my fault, I think I said it was the seating die that does dual purpose. My mistake, its the expander die. If u take it apart u will see immediatly. Good luck, stay safe.
  6. Mar 17, 2014 at 1:24 PM
    #386
    CowboyTaco
    North Georgia
    11 TRD Sport
    Oh well, that's alright. The instructions that came with them didn't say anything about the expander being used as a crimp. I now have the new die and don't have to worry about readjusting each time.
  7. Mar 17, 2014 at 6:03 PM
    #387
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Ugh - can I pay you to come over and set mine up? I've had the AP progressive for months and haven't opened the box.
  8. Mar 18, 2014 at 3:36 AM
    #388
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    A strait wall cartridge die should be easy. The 44 mag, just lower the press arm all the way and turn the die down till it touches ur shell holder plus another 1/8th turn. You want to feel a little cam over with a case in.
  9. Mar 18, 2014 at 3:55 PM
    #389
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Cowboy, did you get a carbide die set or just plain steel? I know you "don't" have to use lube on straight wall pistol cases but when you get into 44-50 caliber the resistance can add up over time. I discovered with my 45 Colt cases that if I take the case and hold it at an angle and just roll it over my lube pad to place maybe 1/16" worth of lube at the top it makes the sizing pressure drop to almost nothing! The phrase hot butter comes to mind....It doesn't take very long to wipe that little bit of lube off and to me it is worth it because it lowers the sizing pressure on the handle dramatically.
  10. Mar 18, 2014 at 7:41 PM
    #390
    crazyengineer
    patrick
    Bristol, TN
    Has anyone every reloaded Berlin primed brass with berdan primers?
    I just got ahold of a Swiss k31 straight pull rifle in 7.5x55. I can get really good ammo for around 50-60 cents per round but they are brass cased berdan primed (good quality brass and not corrosive just berdan primed) and I think I have found a source for berdan primers for like 160 for 5000. I can get an rcbs berdan decapper
  11. Mar 19, 2014 at 8:03 AM
    #391
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Google it up. I always thought berdan primed ammo was not reloadable.
  12. Mar 19, 2014 at 4:28 PM
    #392
    CowboyTaco
    North Georgia
    11 TRD Sport
  13. Mar 19, 2014 at 5:41 PM
    #393
    crazyengineer
    patrick
    Bristol, TN
    I have been, that is why I asked. It is seeming like once you get them decapped and have berdan primers it seems like you run it the same, I'm just not certain and figured I'd ask
  14. Mar 19, 2014 at 6:07 PM
    #394
    CowboyTaco
    North Georgia
    11 TRD Sport
    Luckily everything I have is boxer primed.
    let us know if you are able to successfully do it.
  15. Mar 19, 2014 at 6:12 PM
    #395
    CowboyTaco
    North Georgia
    11 TRD Sport
  16. Mar 20, 2014 at 3:40 AM
    #396
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Dont berdan primed cases have 2 flash holes? How do uou align the primer to the holes?
  17. Mar 20, 2014 at 4:59 AM
    #397
    crazyengineer
    patrick
    Bristol, TN
    They also have the anvil built into the casing, nothing to align
  18. Mar 20, 2014 at 6:24 AM
    #398
    CowboyTaco
    North Georgia
    11 TRD Sport
    Sorry I missed this before. I have the single stage press. I actually waited a few months before setting mine up too. I don't know why I was intimidated by it. Just get it out and you'll be surprised at how simple everything is to setup.
  19. Mar 20, 2014 at 6:25 AM
    #399
    CowboyTaco
    North Georgia
    11 TRD Sport
    I thought you had to drill them to be able to reload?
  20. Mar 20, 2014 at 6:54 AM
    #400
    Polymerhead
    Missouri
    I know decapppers are available, but I don't know how to reload them. Considering the number of cheapskate reloaders out there, I'd think that if it was easy or economical, more would be doing it.
