Reloading BS thread
Discussion in 'Guns & Hunting' started by 95 taco, Jan 4, 2013.
  1. Sep 14, 2014 at 5:36 AM
    #521
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    What do y'all reccomend for accuracy reloading for 30-30. Any bullet choice, it will be for a contender
  2. Sep 14, 2014 at 9:42 AM
    #522
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Looks like TC uses a 1:14" twist rate in their 30-30 barrels, so I'd recommend a lightish Sierra Match King if you're looking for accuracy. 135 or 150 gr should stabilize well. Just don't loan it out to anyone using another 30-30. I don't know anything about 30-30 powder but I'm sure there's plenty of info online.
  3. Sep 14, 2014 at 11:36 AM
    #523
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Try a load using IMR 3031
  4. Sep 19, 2014 at 2:25 PM
    #524
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Got my powder coated bullets in. Now to just get them loaded up. Also bought a pound of Alliant's newer powder BE86 as well as a can of TiteWad.
  5. Oct 5, 2014 at 10:57 PM
    #525
    2000GTacoma
    Snow Hill NC
    Finally got my shot shell loads for my 45acp perfected. Load 13 in the magazine and empty it. Ended up not using gas checks for overshot wad. Used split shot for fishing in the 1/6oz. Works well and also adds basically a 38cal projectile as well. Makes for a mean close in load.
  6. Oct 12, 2014 at 6:43 PM
    #526
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Question: Do you guys clean your brass before you decap the fired primers or after or both before and after? I've been doing both before and after and wonder if it's overkill...
  7. Oct 12, 2014 at 8:04 PM
    #527
    Polymerhead
    Missouri
    I use walnut media and it's too big to do much cleaning of the pocket, but it's about right to fit into a small rifle pocket & clog up so I don't deprime before I tumble. I have friends who use stainless pins to tumble and they say they work great for cleaning primer pockets so they do deprime first. Tumbled 20 pieces of Lapua brass for reloading today and didn't deprime first. Just tumbled, deprimed, neck sized, primed & loaded. I won't bother with cleaning primer pockets until I've loaded new brass 4 or 5 times, but my reloads are only for training/plinking/hunting. No competition use.
  8. Oct 15, 2014 at 8:32 PM
    #528
    Polymerhead
    Missouri
    Picked up a Lee stand for my Hornady LNL. It's actually a very sturdy stand with an easy way to add weight. I started setting up my LNL finally tonight. I have the components to do 500 rounds of 300 BLK immediately - we'll see how it goes. I can already tell it will be much faster than the thousands of rounds I've loaded single stage.
  9. Oct 18, 2014 at 4:56 PM
    #529
    Polymerhead
    Missouri
    Took about 2 hours to set up and another 3 hours to get through my first 500 rounds with the LNL AP. My rhythm is a round about every 8 seconds when running, but I have to stop every 100 rounds to reload primers and every 300 rounds for more powder. I averaged 50-100 rounds per hour on the single stage, so this progressive press is already much faster!
  10. Nov 2, 2014 at 4:43 PM
    #530
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I do just because i dont like sizing dirty brass. You can buy a decapper die but the media doesnt clean the pocket anyhow so i dont bother. I do after sizing rifle brass also to clean the sizing lube.
  11. Nov 2, 2014 at 4:51 PM
    #531
    TACO TX
    Kelly
    Denison ,Texas
    I used 36gr's Hogdon BL-C2 and a Sierra 125gr spitzer pro hunter with a CCI match primer. I had a 24" custom shop barrel though. Very accurate, and very deadly on hog.
  12. Nov 2, 2014 at 7:21 PM
    #532
    2000GTacoma
    Snow Hill NC
    Got about 240 pounds of lead for bullets casting ready to go. Anyone have a Lee bullet sizer die for a press they want to get rid of?
  13. Nov 9, 2014 at 1:33 PM
    #533
    Polymerhead
    Missouri
    So this did not go well. My FN PBR XP is a 1:12" twist and the all-copper 150 gr bullets seem to be slightly too long to work well in my gun. I was getting ~5" groups at 150 yds, which will kill a deer but isn't anywhere near acceptable for this reloader.
    I decided to make a big change and step all the way down to 110 gr TTSX bullets. Speed is key with these bullets anyway, so I figure a light-for-caliber bullet is a great idea. I loaded up ladder groups using TAC powder and was amazed that the max loads fill the case halfway up the neck. After shooting them all, my gun liked them about equally at 100 yds. No signs of pressure so I loaded a bunch up using the max listed load (57 gr!) of TAC and went back to the range today for sight in.
    Set up for sight-in at 150 yds and the first shot was 3.5" high. These things should be pretty flat shooting at 3500+ fps, so I dialed it down to 1" high and the next two were touching at 150 yds. Called it good.
    I can't wait to see what these do to deer.
    3DBEB398-34A9-4385-88CD-E0D823485127_zps_0a6ba7567129084c0b408f166f41871556bb8769.jpg
  14. Nov 9, 2014 at 2:04 PM
    #534
    2000GTacoma
    Snow Hill NC
    Awesome. I wish I had time to go shoot my rifle more.
  15. Nov 9, 2014 at 2:05 PM
    #535
    2000GTacoma
    Snow Hill NC
    Found 2 lbs of Unique about a week ago. Found a new store that had all the 296, Lil Gun and several others you would want. Broke my handles for my casting molds so I need some new handles.
  16. Dec 2, 2014 at 6:30 AM
    #536
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Just started on the reloading, using a Lee breech lock system. I don't like the powder measure that came with it though.... Doesn't seem accurate enough....any other recommendations?
  17. Dec 2, 2014 at 9:46 AM
    #537
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I'm using Lee's perfect powder measure dispenser with Hodgdon H335 on my .223s and it is dead nuts on. The instructions noted to fill the hopper with powder and run it through prior to using it for reloading. That would remove suface tension static and allow for a uniform dispensing.
  18. Dec 2, 2014 at 12:02 PM
    #538
    KodiakToyTRD
    CO
    Might help if I read rather than looked at the pics and practiced the math...
    Derp
  19. Dec 2, 2014 at 2:57 PM
    #539
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Anything other than Lee. I have a digital scale that came with my kit. It is by no means high end but it is consistant. The only issue to concider with digital scales is if you have a fluorescent light over it, it can cause variations in weights. (So I have been told). Lots of other good scales out there, your budget is the biggest factor of what you end up with.
  20. Dec 2, 2014 at 2:59 PM
    #540
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    I dont know why I thought you were talking about scales. My appology. I weigh every powder charge. Only use the powder drop for flake or ball with the pistols.
