Reloading BS thread
Discussion in 'Guns & Hunting' started by 95 taco, Jan 4, 2013.
  1. Mar 11, 2017 at 12:35 PM
    #761
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    Powder / Charge on the 44s
    Are those mags or Elmer Keith specials?
  2. Mar 11, 2017 at 2:16 PM
    #762
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    44 mag. Still working up on H110, these are 21 grs seated to 1.666 is giving be just a bit of compression. I'm only a bit over some published max loads yet. No gas checks so I can't push much more.
  3. Mar 11, 2017 at 4:52 PM
    #763
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    What is the current velocity? What are you trying to work up to if you are already over published loads?
  4. Mar 11, 2017 at 6:07 PM
    #764
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Haven't got these to the chronograph yet. My goal is just a hot heavy load. I have a favorite load from 180 gr up through 310
  5. Mar 11, 2017 at 6:28 PM
    #765
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Just asking, but if you are over book loads and haven't run them across a chrono, what you are working up to? Hard extraction? Extruded primers?
  6. Mar 11, 2017 at 7:25 PM
    #766
    corprin
    corprin Well-Known Member
    corprin
    .38 SPL
    9x19mm
    .45 ACP
    .30-30
    .30 carbine
    6mm br
    .260 AI
    6.5x55
    7.92x57
    Don't bother with the .223 or .308, rounds are cheap enough and the accuracy of those rifles can't touch the 6mm and 6.5's in my herd.
    elmontemike likes this.
  7. Mar 12, 2017 at 6:33 AM
    #767
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    To the point of showing flatter primers or leading the barrel, whichever happens first. I have never had a hard extraction, with any hot load.
  8. Mar 12, 2017 at 8:50 AM
    #768
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Now you made me curious myself. Despite the weather ( 20's and 30 mph wind gusts) I ran a cylinder thru the gun. 1189-1218 fps with 21 grs of H110, 310 gr flatnose cast and a tight crimp shot out of my 7.5" Ruger SBH. Primers still not flattened fully and cases drop out.
  9. Mar 12, 2017 at 4:11 PM
    #769
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Sounds good. I run 325gr at 1200fps through my 7.5in RBH 45 colt. That should be a very effective load.
  10. Mar 12, 2017 at 4:23 PM
    #770
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    By looks and feel, I can keep going, but there comes a point if diminishing returns where more powder doesn't make any more velocity. With a good grip, they are still quite manageable.
    kodiakisland[QUOTED] likes this.
  11. Mar 12, 2017 at 4:27 PM
    #771
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    I find a max of 1200-1250fps to be shootable but still have max terminal performance. Anything else is just noise and recoil. I'd much rather have the heaviest bullet I can get to 1200fps than velocity in a handgun. I've used up to the .475 Linebaugh but just don't see the need for it any more. Your 310gr loads should shoot through anything you encounter.
  12. Mar 12, 2017 at 5:23 PM
    #772
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Which is all I want.
  13. Mar 13, 2017 at 8:49 PM
    #773
    TangoKilo
    TangoKilo Well-Known Member
    Republic of Alberta
    2007 TRD 300,000Km
    Annealed some 22 K Hornet brass!
    AK 08TACO likes this.
  14. Mar 13, 2017 at 9:30 PM
    #774
    AK 08TACO
    AK 08TACO Well-Known Member
    Kyle
    Wasilla, AK
    Ha i'm hard on K-hornet brass, that stuff is paper thin!
    What bullets and powder you shoot in yours?
    Mine likes the 35gr V-max and 296
  15. Mar 13, 2017 at 9:36 PM
    #775
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    I reload the following cartridges on a Redding big boss 2.
    45acp
    10mm
    9x25 dillion
    458 socom, my favorite to shoot on an ar platform
    308
    223
    3378jakesr5 likes this.
  16. Mar 13, 2017 at 9:36 PM
    #776
    TangoKilo
    Republic of Alberta
    2007 TRD 300,000Km
    30gr Barnes Varmint Granade over 13gr of lil gun.
    Do you use rifle of pistol primers in yours?
  17. Mar 13, 2017 at 9:39 PM
    #777
    AK 08TACO
    Kyle
    Wasilla, AK
    I'm not at home and haven't loaded for a while... iirc I used CCI 400s
  18. Mar 14, 2017 at 5:59 AM
    #778
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    A small bag of M856 tracers to mess around with. If I have a gun that will stabilize them.
    wilcam47 likes this.
  19. Apr 13, 2017 at 6:36 PM
    #779
    JohnLin15
    JohnLin15 The Slower DC
    Johnny
    Alabama/Mississippi
    2015 MGM DCSB Prerunner
    Where did you get those bullets?
  20. Apr 14, 2017 at 6:31 AM
    #780
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    I cast the 44. The tracers were part of a group buy.
    JohnLin15[QUOTED] likes this.
