Reloading BS thread
Discussion in 'Guns & Hunting' started by 95 taco, Jan 4, 2013.
  1. Jan 18, 2018 at 7:32 PM
    #841
    95 taco
    95 taco [OP] Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I’m thinking 10.5” barrel with a 3 lug attachment for the suppressor, barrel + suppressor should be 17.1”
  2. Jan 18, 2018 at 7:41 PM
    #842
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    300blk is awfully fun suppressed. Especially for fun, closer range plinking. plus theres quite an offering these days of cheapish 200-220gr 308 bullets.
    I have heard the 277 wolverine can be suppressed. And its pretty quiet. But performance by the numbers isnt quite as good as a 300blk in subsonic form. For an all-in-one caliber though it is quite a decent option though. Good medium range but can also go subsonic for the fun there. ALmost feell ike it was developed in the opposite of the 300blk which performs good subsonic and is decent for supersonic
  3. Jan 18, 2018 at 7:50 PM
    #843
    95 taco
    Soapbox :anonymous:
    The .277 wolverine was designed to have the positive characteristics of the 300 BLK, 6.8 SPC, and 5.56.
    It has good subsonic performance, good supersonic performance for medium game, and is inexpensive while maintaining parts compatibility with 556 guns (sans barrel).
    I’m hesitating because I want to go short but I want it to be a multi-role gun, or I could build a 12.5” 6.8 upper and also build a 9” 300 blk....
  4. Jan 19, 2018 at 6:25 AM
    #844
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Everything Ive heard on it so far has said it isn't as good as 300blk in subsonic. That might have change as Im not really actively following it anymore. Maybe once it gets SAAMI I'll look into it more.
    That and I kind of just got out of the "all-in-one" calibers. Ive got the 233 for the ranom, cheap, fun plinking. The 300blk for the suppressed fun. 458 socom for the big bore fun. Then the AR-10 (still only 308 for it) for longer range
  5. Jan 20, 2018 at 5:20 AM
    #845
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    There's no such thing as an "all in one" AR caliber.
    If I could only keep one AR on a deserted island, It would be my 10.5" 6.8 SPC. If I could take two - i'd also Bring an 8.5" 300blackout.
  6. Jan 20, 2018 at 7:04 AM
    #846
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    It's a reloading thread, so anything can be suppressed. My 7-08 is a ton of fun suppressed. Get whatever gives you the upper range of what you need because us reloaders can suppress anything. Just make sure it has a fast twist.
  7. Jan 28, 2018 at 4:19 PM
    #847
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    Got a question for you guys. I am new to reloading so forgive my newb questions. I just got a Lee loader set in .303. When I bought the gun I got a bunch of Wolf .303 with it as well. As far as i can tell the primers on these rounds are crap. Maybe 1 out of 10 will actually fire the rest just get light strikes. I believe I have ruled out the gun as the issue by testing it with different ammo and every one of those went bang. My question is: Is it possible for me to pull the bullets from the Wolf ammo and also use the power from them to load into the brass that I have? If this is stupid feel free to set me straight, but I think if I could do this the money I spent on the Wolf ammo wouldn't be as huge of a waste.
    wilcam47 likes this.
  8. Jan 28, 2018 at 4:24 PM
    #848
    NMroamer
    NMroamer Well-Known Member
    Fred
    Albuquerque
    2015 TRD OR
    Just a wild ass guess but one of two things are causing your problem.
    Primers not fully seated or dirty primer pockets.
  9. Jan 28, 2018 at 4:25 PM
    #849
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    I got tired of the 300 blackout debate; I just built AR15 chambered in 7.62x39. Just test fired it yesterday to make sure everything is in working order, and it shot beautifully.
    YamaDirtrider and wilcam47 like this.
  10. Jan 28, 2018 at 5:13 PM
    #850
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    I believe some of those ammo brands have very hard primers. If possible find someone with a 303 and have them fire a few rounds to compare. Could be a weak spring in the bolt as well. Just my 2 cents
    wilcam47 and 95 taco[OP] like this.
  11. Jan 28, 2018 at 5:15 PM
    #851
    95 taco
    Thats what I was thinking.
  12. Jan 28, 2018 at 6:00 PM
    #852
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    wolf usually is berdan primed. But if you can salvage the bullets and powder it prob would be ok.
    could also be a gummy firing pin/bolt assembly.
  13. Jan 28, 2018 at 6:25 PM
    #853
    gmr102
    Utah County
    That is what I thought originally. I replaced the firing pin spring and cleaned all the cosmo out of there to make sure it wasn't that. I was thinking of doing what wilcam47 said. Just pulling the bullets reusing them and the powder then tossing the rest.
  14. Jan 28, 2018 at 6:27 PM
    #854
    wilcam47
    Will
    Bourbon state
    also wolf powder is typically corrosive IIRC...
  15. Jan 28, 2018 at 6:37 PM
    #855
    gmr102
    Utah County
    I don't think I have heard of corrosive powder. Only primers. Either way it says no corrosive on the box and I clean my rifles pretty well after firing them.
    wilcam47[QUOTED] likes this.
  16. Jan 29, 2018 at 10:25 AM
    #856
    wilcam47
    Will
    Bourbon state
    some of it is, It may be older stuff though..
  17. Jun 29, 2018 at 10:39 AM
    #857
    wilcam47
    Will
    Bourbon state
    Any pistol cartridge reloaders here? Im going to reload some of my .480 ruger. Just wondered what would be a good powder to use? it will be for hunting purposes.
  18. Jun 29, 2018 at 6:05 PM
    #858
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I don't load .480 Ruger, but I do load .38 and .357. I use a lot of Unique.
    My books list 7 or 8 other powders also.
    Start with what you have on the shelf, and go from there.
  19. Jun 29, 2018 at 6:52 PM
    #859
    elmontemike
    elmontemike Well-Known Member
    This ^^^
    Good advice.
  20. Jun 30, 2018 at 3:13 AM
    #860
    golfindia
    Yes.
    pickup truck
    http://www.hodgdonreloading.com/data/pistol
