Reloading BS thread
Discussion in 'Guns & Hunting' started by 95 taco, Jan 4, 2013.
  1. Oct 3, 2020 at 4:30 PM
    #981
    Tom0662
    Tom0662 Well-Known Member
    Tom
    Iowa
    2016 TRDORSB
    I have a Dillon progressive with the strong mount. Decided I also wanted a
    single stage for larger calibers and bought one of the RCBS Rockchucker's.
    Bought one of the Dillon strong mounts for it, just had to modify it a little bit.
    Don't really care for the press sitting so low. Worked out really well.
    elmontemike likes this.
  2. Oct 3, 2020 at 4:45 PM
    #982
    Martyinco
    Martyinco Well-Known Member
    I just have a lock-n-load classic at the moment and bought one of the Inline fab mounts, I thought my friend was kidding about moving it higher, what a huge difference
    elmontemike and Tom0662[QUOTED] like this.
  3. Oct 3, 2020 at 4:56 PM
    #983
    Tom0662
    Tom
    Iowa
    2016 TRDORSB
    100% agree. :thumbsup:
    Martyinco[QUOTED] likes this.
  4. Oct 6, 2020 at 5:42 AM
    #984
    95 taco
    95 taco [OP] Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Does anybody have a used priming tool and powder scale that they would want to sell?
    Somehow I have miss placed my priming tool and powder scale and those are the only tools that I need to finish loading.
    Edit: I think I got what I need
    Holloman and elmontemike like this.
  5. Oct 9, 2020 at 8:20 PM
    #985
    Holloman
    Holloman Well-Known Member
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    Met an old guy that was selling all his reloading stuff today and picked up some goodies
  6. Oct 12, 2020 at 7:56 PM
    #986
    95 taco
    I’m just missing powder, some primers (I have every type but small rifle), calipers, and dies (223 and 243 are next).
    My sister has said that if I cook some light shooting loads for the 243 she would like to use it as a step up from the .22 that she shoots now.
  7. Oct 13, 2020 at 5:34 PM
    #987
    Martyinco
    Order came from AmmoBrass.com
    A0D17888-63A4-4F70-BE49-5AA98D86FB2F.jpg 727D898A-BA9D-47C9-A7F9-D9C16C80D39D.jpg DFC26BFA-5D6A-4791-82AB-A6F549E35FFA.jpg
    nagorb, Holloman, elmontemike and 2 others like this.
  8. Oct 16, 2020 at 12:21 PM
    #988
    95 taco
    Ok gentlemen, I’m looking for a sonic cleaner, will mainly be used for brass but will also see suppressors and other gun parts as well as the occasional household item/jewelry, recommendations for a $150 budget?
    wilcam47 likes this.
  9. Oct 19, 2020 at 6:48 PM
    #989
    95 taco
    I built a little shelf in the wall this evening after work, I think I’m going to find some insulation board and put between the siding and shelf just to keep radiant heat down.
    Sometime this week I want to make a wall mounted holder that I can just drop the die/bushing combo into and have them sorted by caliber since the bushings don’t fit in the die boxes.
  10. Oct 20, 2020 at 2:48 PM
    #990
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2025 gx550 overtrail. 2025 limited off-road tundra.
    60376D73-1826-4245-A36A-9F056C4BCEBB.jpg 04C151E5-06C1-47E0-9749-3901A23848AB.jpg
    I have so much 556,9mm and 308 brass it’s just stupid. Now if only I could find as many primers....
  11. Oct 20, 2020 at 6:24 PM
    #991
    95 taco
    I started mocking up a die holder system tonight, I think I want to put the dies, shellholder, and load data on a 2x4 for that caliber and then just have a rack system between the studs to slide the die holder onto.
  12. Oct 20, 2020 at 7:32 PM
    #992
    95 taco
    A quick data sheet using load info from Nosler for the 100 grain accubond bullet, assuming I can get 2660 FPS (or close to it) with the IMR4198 powder and 100 grain accubond I should have more than adequate velocity for expansion out to 200 yards.
    Side note: this calculator from Hornady is pretty cool and easy to use. https://www.hornady.com/team-hornady/ballistic-calculators/#!/standard
  13. Oct 20, 2020 at 7:38 PM
    #993
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Same. I had 75 lbs of 9mm brass that I sorted and cleaned this summer and I managed to collect about 35 more lbs before the snow hit. I have some primers but nowhere near enough to plug all the brass.
  14. Oct 20, 2020 at 7:41 PM
    #994
    Notoneiota
    Oakdale, MN
    I have the little Hornady sonic cleaner but it doesn't even come close to cleaning brass like my stainless tumbler. I haven't used it in a few years. No idea how it would be for parts.
    95 taco[QUOTED][OP] likes this.
  15. Oct 20, 2020 at 7:42 PM
    #995
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    It won’t effect what you’re looking at but your BC is actually the G1.
  16. Oct 20, 2020 at 7:43 PM
    #996
    Notoneiota
    Oakdale, MN
    Lucky bastard. That's pure gold right there.
  17. Oct 20, 2020 at 8:09 PM
    #997
    95 taco
    Polish wise or carbon removal? Or both? From the videos I’ve watched the ultrasonic doesn’t clean to a polish like tumbling media but seems to be pretty good at cleaning the carbon,
    Thanks for the heads up, I’ll have to read up on G1 vs G7, I did a quick search and saw an image representing G1 as a round nose flat base bullet whereas the G7 was represented as more of a spitzer with a boat tail.
    I still have a lot to learn about ballistics.
  18. Oct 20, 2020 at 8:32 PM
    #998
    dfanonymous
    All the G’s are “models”. G1 doesn’t represent anything, it’s ballistic characteristics are referenced and quantified to a model that is of a round nosed, non-boat tailed bullet.
    G7 model is that of a boat tail, secant ogive bullet, which is closer to what we in the long range shooting community more often use.
    Closer....but still not as correct as say a custom drag model. You really don’t see any huge difference of G1 vs G7 until you shoot into subsonic assuming scaled averages exist for both models based on speed of the projectile in question. This would be why you might see slightly different BCs for the same bullet amongst different shooters in their solvers.
  19. Oct 21, 2020 at 3:36 AM
    #999
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Ive had the Harbor Freight one for ~8 years now and it works fine. I dont use it for brass but use it for cleaning other gun parts. I do wish I had a bigger unit though as the small ones dont hold all that much (and with some gun parts being awkward shapes they dont always fit)
    For brass though....wet tumbling is pretty much all I do now.. Some times just walnut media then resize then wet tumbling. But more often than not just wet.
  20. Oct 21, 2020 at 4:08 PM
    #1000
    Notoneiota
    Oakdale, MN
    It probably does clean carbon well, but I really only used it for brass and the results were kinda meh. The wet tumbling is magnificent. I will say that I tried cleaning some small parts and a magazine in the sonic cleaner once using the brass cleaning chemical (because that was all I had) and it took the bluing off everything. So make sure you use the right chems.
