Reloading BS thread
Discussion in 'Guns & Hunting' started by 95 taco, Jan 4, 2013.
  1. Oct 21, 2020 at 6:22 PM
    #1001
    95 taco
    95 taco [OP] Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Interesting, thanks for all the info, I still have a lot to learn.
    I would love to wet tumble one day, the goal with the ultrasonic cleaner was the most versatility with the least overall cost, at 150 for the ultrasonic or 110-120 for vibratory tumbler and media the ability to clean my suppressors and other gun parts won the extra 30 bucks from my wallet.
    Interesting, thanks for the heads up, I’ll have to make a data sheet for using the proper additives with different metals and finishes.
  2. Oct 21, 2020 at 6:48 PM
    #1002
    Martyinco
    Martyinco Well-Known Member
    Love my wet tumbler
  3. Oct 24, 2020 at 7:47 PM
    #1003
    95 taco
    I broke in the sonic cleaner by cleaning my .22 can.
    BCD130D6-7676-4AA6-8A2B-3159B75214A6.jpg 4FB6FA6A-B510-408C-869E-961301EA86CB.jpg
    And then I cleaned some 9mm brass, baking it to dry, and I found the vibratory tumbler so they’ll get a short tumble for polish.
    Holloman and elmontemike like this.
  4. Oct 25, 2020 at 4:27 PM
    #1004
    95 taco
    We ended up finding quite a few reloading items, I found about 1800 primers (no small rifle though), projectiles, powder (it wasn’t good anymore), case lube kit, Lee safety scale, Lee press prime, Lee hand primer, a decent bit of brass, some organizers, and a few other small things including deburring tool, case trimmer, and 2 die sets.
    I just need to get some media for the vibratory tumbler to be able to use it, and I need to build more bench/shelf area for the tumbler and sonic cleaner.
    Holloman, elmontemike and Martyinco like this.
  5. Oct 27, 2020 at 5:31 PM
    #1005
    95 taco
    Assuming I don’t get blown away or struck by lightning during the upcoming hurricane I should be organized enough to do some loading.
    My brownells order finally made it despite a week long delay courtesy of fedex so now I have some 6mm projectiles and a more trustworthy set of calipers.
    I also built a shelf for the sonic cleaner and vibratory tumbler today after work.
    My bench from left to right.
    649D7C29-BC58-4790-8A9E-8937EDAA605D.jpg 10885680-54F5-4ACB-A9EA-5A72E3115622.jpg 661682EC-E82B-461A-B283-A4A02E2AD015.jpg
  6. Oct 27, 2020 at 5:48 PM
    #1006
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Just a thought...I don't know the climate of where you're at, nor exactly the type of building your set up is in (a shed?), but keep an eye on the temp and humidity in the room. Those dies and other metal things like the powder drop will rust quickly. My setup is in my temp/humidity controlled basement and I get light blooms on random stuff once in a while. Keep the metal protected with dry lube or CLP.
    Armed in Utah and 95 taco[OP] like this.
  7. Oct 27, 2020 at 6:10 PM
    #1007
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Yep.
    Mine is in my war room. I have to shut off all the vents in there and close the door to block any air currents when using any electronic powder meter. Something else to consider too.
    95 taco[OP] likes this.
  8. Oct 27, 2020 at 6:36 PM
    #1008
    95 taco
    Hot and humid south Ms, as of now there’s no climate control in the shed but before next summer it’ll have power and AC. I’ll definitely have to use some sort of dry lube on both the press and dies, the powder dispenser is plastic except for the base and screws so I’m not terribly concerned about it.
    Before it was in the shed the press and bench were underneath a mobile home in similar conditions but near the gulf (closer than I am now) and it had rust on it after about 18 months, I had to take steel wool to the shaft, repaint the handle (that’s where the Cat yellow handle came from) and the 38/357 dies are still a bit rusty.
    I noticed that if I have the box fan pointed straight at me from the side it doesn’t mess with the Lee safety beam scale but if it’s pointed at the bench at all it gives a slight wobble. I’ll see how much of an issue it is once I get the AC hooked up.
    Hopefully by the middle of next year I’ll have it insulated.
  9. Oct 30, 2020 at 5:16 PM
    #1009
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Back in 1989 a co-worker got me started into reloading, as I was shooting more than he wanted to load. Started with and still use a Lee single stage press, in 9mm at first. Later I got a 357, so I got dies for same. Then lately got some 380acp dies and ran a few just to try. Have a little old powder left, need to shoot it before it goes bad. All my stuff stays in the house, I can watch TV while loading, no wife is the secret.
  10. Oct 31, 2020 at 8:38 PM
    #1010
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    A friend has some reloading dies for sale if interested...Rcbs.445 super mag, rcbs 44mag, 6mm hornady(NIB).
  11. Nov 8, 2020 at 7:34 PM
    #1011
    95 taco
    I’m going to pick up this shotshell press tomorrow after work, I happened to tell our concealed carry class instructor that I was getting back into reloading and she wanted to know if I wanted a shotshell press because a friend of hers was getting out of it due to age and was giving his press away.
    Also, I haven’t had a chance to load .243 or 6.8 because we had to move my shed during hurricane cleanup, once we get the fence rebuilt I’m going to build a lean to shed for the mower, generator, chainsaw, and fuel and then my shed will be reloading only, I’m also going to run power and Ethernet to it so I have permanent lights, AC, and cameras on the shed. (Yellow is lean to, purple is shed)
  12. Nov 9, 2020 at 7:52 PM
    #1012
    95 taco
    Do you fine folks in here know the differentiating factors concerning the MEC shotshell loaders? I picked up the mec after work today but there are no markings on it, I think it’s either a versamec or pre-82 mec jr, based on the story I was told I don’t think it’s likely to be pre-82, I think it was bought new sometime in the early/mid 90’s.
    3161EE26-7C12-4A5F-9F63-68D8E06E8D8F.jpg EB8C523F-E57A-4290-A5F1-F67B51383CFF.jpg 1A00E492-9C21-4844-A597-A70113B090D8.jpg
  13. Nov 10, 2020 at 9:00 AM
    #1013
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    I agree, looks like a JR. Definitely not a size master since it doesn’t have the resizing collet.
    95 taco[QUOTED][OP] likes this.
  14. Nov 10, 2020 at 9:09 AM
    #1014
    95 taco
    I emailed Mec with photos this morning, it’s a pre-82 (early 70’s) 600 Jr.
    Now I need to do more research, can I reload high brass shells with it? 3”? I have another loader that I’ll be getting in a few months, it’s currently setup for 28 gauge but I want to convert it to 16 gauge.
  15. Nov 13, 2020 at 7:25 AM
    #1015
    wilcam47
    Will
    Bourbon state
    What are you guys seeing on powders? I know primers are unicorn right now..
    Talked with one gunshop, and they are low stock he said the powder companys are buying back powder trying to fill ammo orders
  16. Nov 13, 2020 at 7:41 AM
    #1016
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    I've been an avid reloader for 40+ years
    If UR loading semi pistols...you need this Lee factory crimp die
    Seat in your #3 die...this will factory crimp in the 4th step...along with resizing the case
    If you have issues..this die may correct any problems...try one !
    https://www.midwayusa.com/product/1011209519?pid=716704
    golfindia, Tom0662 and Gyrkin like this.
  17. Nov 13, 2020 at 7:46 AM
    #1017
    Armed in Utah
    2003 Lexus LX 470
    Seems most popular powders are gone....
    Recently bought some H4198 retail...some Win 231 from Midway
    Watch for Midway's free shipping days...haz mat was on $12 extra
    https://www.midwayusa.com/product/2900372783?pid=372783
    wilcam47[QUOTED] likes this.
  18. Nov 13, 2020 at 2:46 PM
    #1018
    95 taco
    I can get most powders through a local supplier, his prices are on par with online, he supplies the local shops with their reloading orders.
    I’ve decided that my next investment in reloading needs to be another powder dispenser, the current Lee perfect powder measure will get setup for 9mm and stay the same setting because it’s difficult to adjust the charge (plastic is in bad shape) so with a budget of about a hundred should I get the deluxe Lee powder measure and a set of drums for other charges?
  19. Nov 13, 2020 at 2:59 PM
    #1019
    Armed in Utah
    2003 Lexus LX 470
    Just ordered a 4# jug of 'TiteGroup'
    Natchez had it in stock....
    $117 total....delivered
    $29/pound.....oh well right ?
  20. Nov 13, 2020 at 5:45 PM
    #1020
    95 taco
    147 grain round nose projectiles cost 3.50/500 more than 115 grain round nose, I’ll be shooting some suppressed but is it worth the negligible price difference to have 147’s vs the 115’s?
    Armed in Utah likes this.
