Reloading BS thread
Discussion in 'Guns & Hunting' started by 95 taco, Jan 4, 2013.
  1. Nov 8, 2021 at 5:29 PM
    #1281
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Whats your OAL? What load data you using?
  2. Nov 8, 2021 at 5:34 PM
    #1282
    MNFinn7300
    MNFinn7300 Well-Known Member
    Erik
    2021 Tacoma SR DCSBV6
    Softopper, Diode Dynamics Fog lights, BD Spot lights
    OAL was 2.8 Didn't get a base to ogive on it though, comparator insert is missing. worked up from Berger load data. Their data is pretty conservative.
  3. Nov 8, 2021 at 5:43 PM
    #1283
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    No worries. I fixed some grammar and some broken sentences on that last post, but it looks like you picked up what I was saying.
    I would need what the jam is with the same bullet brass combo on that barrel. That’s the only helpful starting point when talking about oal. This is because your issue is at seating depth.
    You’ll need something like a hornady oal gauge with a modified case. Once you do that, you can see if manufactures have sample bullets, so you can do some experimenting. Personally I think SMK are a little outdated but they sometimes have a shorter base to ogive.
  4. Nov 8, 2021 at 5:47 PM
    #1284
    MNFinn7300
    Erik
    I've got the OAL gauge just need to get a modified 6.5 case or make one. 6.5 is my fun rifle so I don't have as much set for it like I do for my competition rifle.
    dfanonymous[QUOTED] likes this.
  5. Nov 8, 2021 at 5:56 PM
    #1285
    wilcam47
    Will
    Bourbon state
  6. Nov 8, 2021 at 6:13 PM
    #1286
    MNFinn7300
    Erik
    made up a shell that would work. base to ogive jammed was 2.154. will have to get a true dummy case to be sure. this was quick general reference stuff
  7. Nov 8, 2021 at 6:24 PM
    #1287
    dfanonymous
    It should be workable. The coal, measured from base to ogive with a 130 Berger VLD for your cartridge in question is somewhere at 2.080 on average…obviously that’s an average, and not data, but it tells me you’re in the ballpark..
    wilcam47 likes this.
  8. Nov 12, 2021 at 6:53 AM
    #1288
    Holloman
    Holloman Well-Known Member
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    PintSize likes this.
  9. Nov 18, 2021 at 12:16 PM
    #1289
    elmontemike
    elmontemike Well-Known Member
    Does anyone have any experience reloading for the 30 carbine? Just wondering if there’s any tricks or suggestions. I think I’m going to load some up this weekend.
  10. Nov 18, 2021 at 1:21 PM
    #1290
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    I have done a few of them. If you have loaded pistol rounds before it is pretty much just the same thing with a little longer shell casing. Size the brass, give it just enough of a belling to prevent shaving of the bullet jacket, primer and powder, then seat the bullet with just a slight bit of crimp to snug the belled end back against the bullet.
    elmontemike[QUOTED] likes this.
  11. Nov 18, 2021 at 1:33 PM
    #1291
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Headspacing off the mouth sucks. Trim length is critical.
    tacotoe and elmontemike[QUOTED] like this.
  12. Nov 18, 2021 at 6:15 PM
    #1292
    elmontemike
    Thanks guys
    tacotoe likes this.
  13. Nov 20, 2021 at 5:21 PM
    #1293
    95 taco
    95 taco [OP] Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Finally got my reloading shed set on a foundation and got a Lee Loadmaster in .223 ordered through work so I decided to get some stuff from in-line fabrication.
    I’m pretty excited to get everything going, pretty happy with my 6.8 loads and .223 62 grain gold dot loads, I need to get more powder so I can do some pistol loading and experiment with 9mm subs.
    tacotoe, PintSize, token3495 and 3 others like this.
  14. Nov 22, 2021 at 8:53 PM
    #1294
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    Having any luck finding powder? I love the in-line fabrication stuff too. I have a riser with the quick change mount. I recently got another press and loving the quick change system.
    elmontemike and tacotoe like this.
  15. Nov 22, 2021 at 9:46 PM
    #1295
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I thought primers were the hardest component to find. at least around where I live, there as scarce as hens teeth. I've held off reloading until I see if the manufacturers are going to catch up with demand.Once my primers are gone, that's it, no more reloading. If I would have known things were going to get this bad, I would have purchased 10k of each small and large pistol primers.
    tacotoe likes this.
  16. Nov 22, 2021 at 10:04 PM
    #1296
    dfanonymous
    Depends.
    If you’re looking for just reloading components to make round go boom, then yes primers are harder to come by. The guy you quoted, I'm not sure his situation…but life is easier if you know a guy or 3.
    If you hand load to a very tight recipe and for maximum precision then certain powders like varget and h1000 and a few other were hard to get well before covid. So, in that sense, specific powders are hard to find. Somethings just work.
    elmontemike and PintSize like this.
  17. Nov 23, 2021 at 10:56 AM
    #1297
    JeffRoyJenkins
    Jeff
    Lake Stevens, WA
    Primers have been almost impossible for me to find locally. They are out there online but they are at premium pricing on top of the hazmat fee I always hate paying when I do break down and order them or powder.
    Magnum small rifle primers have been popping up on Brownell's site every couple days lately, I've made it as far as putting them in my cart but haven't been willing to pay the price on them yet hoping I might score some locally with a better price and no Hazmat. I'm sure once I work through all the .223 brass I have on my bench and deplete my current supply a bit more I will be a bit more than willing to open my wallet though.
  18. Nov 23, 2021 at 8:28 PM
    #1298
    dfanonymous
    Speaking of supplies,
    I talked with some people I know at Hodgdon, and the price is expected to go up more or less 15% around 2022. As a result of inflation estimation. Just in case anyone is confused on the situation, or expecting it to “get better.”
    You might be waiting a while.
    tacotoe and elmontemike like this.
  19. Dec 13, 2021 at 12:32 PM
    #1299
    Holloman
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    Just a heads up Midway has CCI 41 primers in stock right now in case anybody’s looking.
  20. Dec 13, 2021 at 1:28 PM
    #1300
    JeffRoyJenkins
    Jeff
    Lake Stevens, WA
    :pout:
