Reloading BS thread
Discussion in 'Guns & Hunting' started by 95 taco, Jan 4, 2013.
  1. Dec 19, 2023 at 6:20 AM
    #1461
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Thanks. I just finished turning the 30-06 brass I had into 35 Whelen so I'm out.
    I thought I was the only person on earth who reloaded 762x39! Hard to come across brass cases for that in any quantity. Most people shoot steel.
    I have a truckload of 223 sorted into various headstamps. I also have massive quantities of 9, 40, 45.
  2. Dec 19, 2023 at 6:45 AM
    #1462
    Bill0351
    Bill0351 Well-Known Member
    Bill
    2023 SR V6 4x4
    Tires/Cap
    A little late on my reply, but it’s my go-to for .357 magnum and .357 maximum. I can’t find it locally lately, so I’ve been using H110.
  3. Dec 23, 2023 at 6:34 AM
    #1463
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Would like y'alls input. I have ejector marks regardless of how hot or cold i load the rounds. I'm debating polishing the face of the ejector on the bolt. Thoughts?
  4. Dec 23, 2023 at 6:53 AM
    #1464
    Bill0351
    Bill
    2023 SR V6 4x4
    Tires/Cap
    I would use something like a drill press to fully compress it and see if it’s protruding. Then I’d inspect/clean and check again. Zero major risk for taking a few thousanths off. No real risk in leaving it alone. Perfect winter weekend project.
  5. Dec 24, 2023 at 1:42 AM
    #1465
    Ivanimal
    Ivanimal Well-Known Member
    Ivan
    San Francisco Bay Area
    2005 Tacoma
    Front hitch receiver HID light package Aftermarket stereo with backup camera Roof bars with storage options for fishing and canoe Class A receiver for towing quad and junk.
    This
    if it bugs you too much take a stone to it and remove the excess then reblue it with cold blue.
    It wouldn’t bug me. YMMV.
    Bill0351[QUOTED] likes this.
  6. Dec 24, 2023 at 5:58 AM
    #1466
    Bill0351
    Bill
    2023 SR V6 4x4
    Tires/Cap
    Depending on how it interfaces with the spring, you could also remove material from the bottom and leave an invisible repair.
  7. Dec 24, 2023 at 3:07 PM
    #1467
    Bill0351
    Bill
    2023 SR V6 4x4
    Tires/Cap
  8. Dec 27, 2023 at 1:52 PM
    #1468
    mightytacoman
    Kel
    4.5L 1grfe
    308 loaded up today. I did shave the face off of that ejector like @Bill0351 suggested. Thank you for that. Will post back when it makes its way back to the range.
    azshooter40, Bill0351 and wilcam47 like this.
  9. Dec 27, 2023 at 2:28 PM
    #1469
    Bill0351
    Bill
    2023 SR V6 4x4
    Tires/Cap
    Cool press! I was just looking at one at Sheels.
    I tried a combination of H110/240 grain XTP in today’s .44 Magnum load. It’s right on the edge between fun and punishing, which was the goal. After 50 rounds I was ready for some .38 Specials. It’s not usually 50 degrees this time of year in Wisconsin. Great day for some shooting. IMG_1029.jpg
  10. Dec 28, 2023 at 10:51 AM
    #1470
    golfindia
    Yes.
    pickup truck
    Has anyone here ever used Shooters World Blackout for 762x39? (123gFMJ)
    The jugs says 28 grains, start by reducing 10%.
    Shooters World website says 19-23.8 grains.
    The jug also says it's the same as Lovex D063, Lovex data shows 23-25.5 grains.
    I've used a lot of this powder for 300blk subs, I just used my same 1680 recipes.
    However this is a pretty big variance, and not subsonic, where I'm usually working down, not up.
  11. Dec 28, 2023 at 6:28 PM
    #1471
    mightytacoman
    Kel
    4.5L 1grfe
    So do a ladder working up. Safe bet is the 19gr starting load. It's your face over the action after all
  12. Dec 29, 2023 at 4:33 AM
    #1472
    golfindia
    Yes.
    pickup truck
    Certainly.
    Are you familiar with load density and SEE?
  13. Dec 29, 2023 at 7:17 AM
    #1473
    mightytacoman
    Kel
    4.5L 1grfe
    Familiar with load density. Don't know what SEE stands for.
  14. Jan 1, 2024 at 2:47 PM
    #1474
    golfindia
    Yes.
    pickup truck
    "Secondary explosion effect".
    Purportedly bad things can happen when small amounts of faster burning powders are placed in large cases. One of the reasons why many powders have a " don't go below minimum" warning.
    Holloman and TartanEagle like this.
  15. Jan 2, 2024 at 5:24 AM
    #1475
    mightytacoman
    Kel
    4.5L 1grfe
    So reflecting on this for a while. My thoughts moving fwd would be to go with what the jug says as shooters world is user reported loads (i think) and therefor less trust worthy of a load than a company selling the powder.
    I have a 375 cheytac and there is little to no published load data for it. So I've had to extrapolate from various online sources and weigh the reliability of each source. Newest test load for it should be pushing 352gr projectiles at ~3100fps. Trying to create a 4000yrd capable load.
  16. Jan 2, 2024 at 6:15 AM
    #1476
    golfindia
    Yes.
    pickup truck
    That's pretty much what I did. SW Blackout is very similar to 1680, so I ballparked a load range window by cross referencing a few published 1680 loads.
    I think the difference between what Shooters World and Lovex published may be due to CIP (europe) VS SAAMI (USA). Their max pressures for 762x39 are much different.
  17. Jan 2, 2024 at 11:30 AM
    #1477
    Ivanimal
    Ivan
    2005 Tacoma
    I have 12LBs of their D036-03 clean compared to American powders, 60% of the cost, I bought before the world went upside down. $10 a pound. We did a group buy on calguns.
    I stay right in the middle of the load rates and have been very happy. I am only loading for 9MM at the moment.
    golfindia[QUOTED] likes this.
  18. Jan 7, 2024 at 12:56 PM
    #1478
    Bill0351
    Bill
    2023 SR V6 4x4
    Tires/Cap
    Load testing light .38 Specials for an old Single Action K-38 Target Masterpiece. IMG_1101.jpg
  19. Jan 16, 2024 at 3:08 PM
    #1479
    Skawdee
    Skawdee SKOL Vikings!
    Star Valley, Wyoming
    2009 Tacoma TRD-Offroad, 6-spd Man.
    Old Man Emu 2.5” Full Suspension Lift w/ Wheeler's Off-Road Progressive Leaf Pack JBA Upper Control Arms Moog Lower Control Arms Victory4x4 Strike Front Bumper w/ Grill Tubing Morimoto XB Headlights Baja Designs Squadron Sport Amber Fog LED’s Baja Designs 20” White LED Light Bar Over-sized BFG All-Terrain Tires K&N Stock Replacement Air Filter Pioneer AVIC-W8400 Head Unit Apple TV Wireless Phone Charging Pad Bed rail mounting with ax, shovel, MaxTrax Bed Extender
    Didn't realize TW had a handloading forum. Cool... I'm in! I'm not a seasoned vet by any means, but I've been at it for about 10 years or so. I originally bought the Hornady kit but added to it over the years. Hope to get some good info and help others on here! Have a good day.
    CowboyTaco, TartanEagle and golfindia like this.
  20. Jan 16, 2024 at 5:32 PM
    #1480
    Bill0351
    Bill
    2023 SR V6 4x4
    Tires/Cap
    What cartridges do you reload for? After I wrap up my current project, I’m going to start working up a .308 cast load for some coated 150g SNS that have been sitting unused for a few years. I have a vintage FN Mauser sporter I want to use them in.
