Reloading Info and B.S. Thread
Discussion in 'Guns & Hunting' started by ArcherTaco, Feb 1, 2017.
  1. Jul 7, 2017 at 6:31 PM
    #241
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Sure. Why not. I can use more 9mm
    Really need .223 if ya come across anything good
  2. Jul 7, 2017 at 7:05 PM
    #242
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    If anyone is looking for some 7mm Remington Magnum brass or bullets, I have some I am willing to part with real reasonable. Also have some 155 gr 308. Got them in a batch of stuff and I do not reload any of these calibers. Also have 250 brand new Remington nickel 45 ACP brass.
  3. Jul 10, 2017 at 9:45 AM
    #243
    ArcherTaco
    ArcherTaco [OP] Well-Known Member
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Toy-Tec Kit, Tool box fit to bed, Dipped badges, cab lights, running boards, Flowmaster exhaust
    Just for plinking or for long range use? I put a bunch of Nosler 67gr together a while back that I'm quite fond of for mid-long range shooting. Not cheap but they perform when you need it.
  4. Jul 10, 2017 at 10:34 AM
    #244
    YamaDirtrider
    Josh
    Elizabeth CO
    I've just been plinking and stockpiling, I want the get at least 1k in every caliper I have.
    Right now I've used 55gr fmj
  5. Jul 11, 2017 at 11:45 AM
    #245
    YamaDirtrider
    Josh
    Elizabeth CO
  6. Jul 11, 2017 at 11:52 AM
    #246
    ArcherTaco
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Do they want to get rid of any of it individually?
  7. Jul 11, 2017 at 12:17 PM
    #247
    YamaDirtrider
    Josh
    Elizabeth CO
    They said they would like to sell it as a kit and they do have brass
  8. Jul 12, 2017 at 9:51 AM
    #248
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    @ArcherTaco @YamaDirtrider or @3378jakesr5
    I am guessing I need both .223 and 5.56 Dies, that there is no "universal" one for both?
    Want to start picking up stuff before I blaze through all my current ammo.
  9. Jul 12, 2017 at 9:52 AM
    #249
    YamaDirtrider
    Josh
    Elizabeth CO
    There the same.
  10. Jul 12, 2017 at 9:53 AM
    #250
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    its the same die you load it to the spec you want by bullet type and powder.
    CO MTN Steve[QUOTED] likes this.
  11. Jul 12, 2017 at 9:54 AM
    #251
    ArcherTaco
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    He is absolutely correct. Depending on what press you have I'm quite fond of the RCBS competition .223 die set. It's a little pricey but the adjustability for multiple rounds makes it super nice
    CO MTN Steve likes this.
  12. Jul 12, 2017 at 9:57 AM
    #252
    ArcherTaco
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
  13. Jul 12, 2017 at 10:02 AM
    #253
    YamaDirtrider
    Josh
    Elizabeth CO
  14. Jul 12, 2017 at 10:07 AM
    #254
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
  15. Jul 12, 2017 at 11:18 AM
    #255
    ArcherTaco
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    It's definitely overkill...but so far it's been really nice for changing from JHP to ballistic tip and back. makes die adjustments super quick and easy. I'll take a pic of mine. It's covered in adjustment markings for different loads...
    I believe that is correct. I'm sure Hornady makes something similar as well. But to Josh's point it's really more than you need...I just like all of my rounds to be as close to identical as my pea brain can manage :D
  16. Jul 12, 2017 at 1:39 PM
    #256
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Get the ar small base dies for 223 if you are running them in an ar15 :burp:
  17. Jul 12, 2017 at 1:42 PM
    #257
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    I need a link please, no clue what this means.
  18. Jul 12, 2017 at 2:02 PM
    #258
    YamaDirtrider
    Josh
    Elizabeth CO
  19. Jul 12, 2017 at 2:12 PM
    #259
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
  20. Jul 12, 2017 at 2:19 PM
    #260
    ArcherTaco
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    It should all work. I have the small base die as well. I just like the quick adjustability of the competition die. (I also change varieties of bullet quite frequently with .223)
    If you don't plan on trying to shoot extreme range or changing your loads every time you pull the die out the comp. die is probably overkill...but I still like it. It's a personal decision. I had a giftcard and wanted to try it so that's how I ended up with the comp dies...
