Relocating stock air box
Discussion in 'Performance and Tuning' started by SilverSeven, Feb 7, 2011.
  1. Feb 7, 2011 at 11:09 AM
    SilverSeven
    SilverSeven [OP] Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    Is it possible? I am talking the box itself, I understand different tubing would need to be used to connect the box to the manifold, but is that even possible?
    Thanks, pics appreciated
  2. Feb 7, 2011 at 11:15 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    What the hell are you trying to do this time?
  3. Feb 7, 2011 at 11:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Why would it not be possible? With enough tubing, you could mount the airbox in your living room.
  4. Feb 7, 2011 at 11:18 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Are you talking about the intake box on the fender, or the air filter box before the TB? Would also help to understand what you're trying to get done since theoretically it's definitely possible.
  5. Feb 7, 2011 at 11:26 AM
    SilverSeven
    Jordon
    South Jurzee
    This is my problem:
    I want to relocate the air box the the passenger side fender area where there is room, and connect my soon to be snorkel to it. Right now my strut tower brace blocks the possibility of connecting tube to my factory intake.
  6. Feb 7, 2011 at 11:33 AM
    mjp2
    NJ
    That'd do it. :p
    Have you considered using one of the cold air intake setups? The TRD one replaces a lot of the stuff under your brace and could address the clearance issues without having to really mess with stuff.
    (found that pic through GIS)
    Pricey option but it's a possibility.
  7. Feb 7, 2011 at 11:35 AM
    SilverSeven
    Jordon
    South Jurzee
    Unless the box is in a different location than the AFE, it wont fit because of my CO tower. So my options are, built a custom watertight box for the filter and run custom tubing with a CAI, or relocate factory box.
    I am fine with both, whichever works best is what I will go with. If I could find a box that fit there I would bite in a heartbeat
  8. Feb 7, 2011 at 11:37 AM
    SilverSeven
    Jordon
    South Jurzee
    this is the new TRD box
    35350d1271903658-new-trd-cai-ptr03-35090_2d064fdd0a4355776cb2d281db8578751cced077.jpg
    But no pix of it installed on a taco, not positive it will fit
  9. Feb 7, 2011 at 11:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If your worried about water, you may want to take a URD set up, enclose it, run it to the fender, and attach a norkle. Easy peasy!
  10. Feb 7, 2011 at 11:39 AM
    SilverSeven
    Jordon
    South Jurzee
    pics or I dont believe you. The URD I know of sits like in the grill, wide open.
  11. Feb 7, 2011 at 11:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your not gonna be able to fit an airbox in that locartion with your current set up. Your gonna need to fab something up. Its not gonna be hard, as the shit is plastic. Take a day off of crack, and sit down with some tubing, a small hack saw, and a knife, and get it done! :cool:
  12. Feb 7, 2011 at 11:45 AM
    SilverSeven
    Jordon
    South Jurzee
    heres what I am working with for space
    I am ok with fabbing a box for a CAI filter setup, but I would be just as happy putting the stock air box in that space and running new tubing to it...
  13. Feb 7, 2011 at 11:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Send a PM to the engineers at NASA that got the air filter from one craft, to fit in the other one. THey may know somthin....
  14. Feb 7, 2011 at 11:50 AM
    SilverSeven
    Jordon
    South Jurzee
    ok, do you have their number? I tried google, but nothing
  15. Feb 7, 2011 at 11:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    (202) 358-0000
    Or
    (256) 721-4292
  16. Feb 7, 2011 at 11:57 AM
    SilverSeven
    Jordon
    South Jurzee
    hahahahahah I hate you!!!!!!!
  17. Feb 7, 2011 at 11:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :D
  18. Feb 7, 2011 at 12:23 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Is boxing out that strut brace an option? You could use welded plate to make a box around the tubing and retain the stock set-up. Maybe an option if you're more comfortable working with metal than plastic but you'd have to cut up that brace.
  19. Feb 7, 2011 at 12:34 PM
    s10nick
    s10nick Well-Known Member
    nick
    Greeley, CO
    base mod. debaged
    3inch hbs lift toytec diff drop grillcraft grill hella 500s conv. to 8k hids xentec hid head light conv. 5% tint more to come
    id say take out that top brace and make one outa tubing and then u should have more than enough room for it to be in the stock location
  20. Feb 7, 2011 at 12:37 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    That's an awesome looking brace. Why didn't you route it angled forward some? Technical issue? Strength? It seems most have it angled forward.
