Relocating the BSM to Tail Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by buntcake, Jun 13, 2022.
  1. Apr 15, 2025 at 10:23 PM
    #121
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    I would be interested in testing. I have a 3D printer and access to Techstream as well if it helps.
  2. Apr 15, 2025 at 10:43 PM
    #122
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
  3. Jun 7, 2025 at 7:27 AM
    #123
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    Sub'd. I am really hoping for success here. It sounds like the sensor is close to zero hemispheric interference other than ground. That's pretty wide.
    Fireball 00 likes this.
  4. Jun 9, 2025 at 10:41 AM
    #124
    Toycoma2021
    For our ignorant minds would you like to elaborate? I ask because I wish to figure out just how these things (BSM modules) function.
    The right and left are identical units and mounted upside down from one another depending upon what side they are on, i.e. ground and the sky swap with location. Pin out functions differ (IO) depending upon which side they are mounted on as well. Must be software controlled?
    This thread is so old I don't know if it contains the schematic and pictures of the internals of the BSM Modules. If needed I can (re)post.
  5. Jul 3, 2025 at 12:08 PM
    #125
    CemenTRDgen
    CemenTRDgen Stay Flexible!
    Joshua
    Concord, CA
    2019 DCLB TRDOR Cement
    Bilstein 6112/5160, Icon RXT, BAMF Sliders, Skids, & Hybrid Front Bumper, Warfab Phantom Rear Bumper, & Hitch Skid
    Is it possible that another Toyota BSM sensor from another model could work? Specifically a sensor with a smaller form factor? Or even one from a different manufacturer if the signal they send is the same or could be made to be the same?
