Remote air coupler
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Southwest Tacoma, May 26, 2024.
  1. May 26, 2024 at 2:46 PM
    Southwest Tacoma
    Southwest Tacoma [OP] Well-Known Member
    Southwest
    2020 Super White SR DCSB
    I'm installing a remote coupler from my on board air compressor to my back bumper. The compressor has a 1/4 NPT threaded port for the air line to come out. Will this require the use of a 1/4" ID hose to provide the best performance from the compressor? Or is it recommended to go with a larger ID hose size?
    If anyone has photos of their remote coupler install, that would be appreciated too.
  2. May 26, 2024 at 2:58 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You are fine keeping with the 1/4". You compressor does not supply enough cfm for there would be noticable difference.
    Really is no benefit to going up a size with this unit. 1/4" is a very common pipe size, the next size bigger is 3/8. Lots of hardware suppliers don't stock 3/8" because it's used so rare.
  3. May 26, 2024 at 3:02 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    1/4” ID hose is fine, you're not restricting anything, and it’ll be more flexible and lighter. You could even run a 3/8” OD nylon tubing.
  4. May 27, 2024 at 4:55 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    As others have stated, you really don’t need a larger line. With that being said, a larger line will increase The capacity in your system a small amount.
  5. May 27, 2024 at 6:50 AM
    Southwest Tacoma
    Southwest
    Thanks for all the replies. Should have it all buttoned up today.
    BabyBilly and koditten like this.
