Remote Car Starter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mirage2009, Sep 12, 2011.
  1. Sep 12, 2011 at 10:56 PM
    mirage2009
    mirage2009 [OP] Active Member
    Alberta, Canada
    Tacoma 2009 TRD SR5
    This has probably been asked a thousand times but is it possible to get a remote car starter installed for a manual transmission 2009 Tacoma?
    I got my Taco this March and haven't had to deal with a real Canadian winter with it yet. So I'd like to get a remote car starter installed before this November.
    Also, what is the general price range I should expect, including labour?
  2. Sep 12, 2011 at 11:17 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    yes you can. viper has the 5901.
  3. Sep 13, 2011 at 4:56 AM
    kb1jop
    kb1jop Well-Known Member
    Rick
    Springfield, MA
    2010 Barcelona Red 4WD DCSB 6-Speed SR5
    Factory Towing Package Factory Roof Rack OEM Bed Mat Trifecta Tri-Fold Tonneau SeatSaver Custom-Fit Seatcovers WeatherTech Custom-Fit Floor Mats Block Heater: http://www.metrotpn.com/ProductDetails.aspx?CollectionID=13&ProductID=191&SortIndex=9
    You still must have to park it in Neutral, correct? :confused:
  4. Sep 13, 2011 at 6:25 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    I'd recommend it, unless you want your truck taking off when you start it with the remote ;) :thumbsup:
  5. Sep 13, 2011 at 6:29 AM
    kb1jop
    Rick
    Springfield, MA
    My driveway is sloped so I'll brave the elements and forego the remote starter. :rain:
  6. Sep 13, 2011 at 8:56 AM
    mirage2009
    Alberta, Canada
    Tacoma 2009 TRD SR5
    I always leave my truck in neutral when parked.
  7. Sep 13, 2011 at 11:12 AM
    rossk35
    hawaii
    you have to do a sequence before you shut the truck off, so that way it'll know that its in neutral.
  8. Sep 13, 2011 at 2:48 PM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
    I did a self install on mine using an Autopage System.
    Sequence is:
    1. Truck is running in neutral with you in it.
    2. Pull parking brake, release parking brake, pull parking brake.
    3. Hazards flash to acknowledge that you want Autostart
    4. Turn key to off position, truck will continue to run.
    5. Get out of the truck and close your door, lock with fob.
    6. Truck will shut off and parking lights will flash twice to confirm autostart is set.
    System is obviously foolproof because if the truck is running and you are outside of it, it isn't in gear. The only pain is remembering to do that routine, otherwise the remote start won't function the next time you go to use the truck.
  9. Sep 13, 2011 at 9:32 PM
    mirage2009
    Alberta, Canada
    Tacoma 2009 TRD SR5
    So this sequence is simply to make sure the truck doesn't start when in gear?
    Also, will normal dealerships and/or electronic suppliers install for manual tacomas? Can someone give me an idea of how much this all costed?
    I am NOT proficient with meddling with my truck to install this myself, so I'd like professionals to handle it.
  10. Sep 14, 2011 at 8:32 AM
    Navigator
    Ontario, Canada
    05 DC Sport 6spd
    Yes, you don't want to be able to start the truck while it's in gear....bad things will happen.
    I paid $129 for the autostart itself, and invested 10 hours of my own labor to install, and countless hours of research leading up to the install.
    Yes, dealers will install on a manual vehicle.
