Remote Connect
Discussion in '3rd Gen. Tacomas (2016-2023)' started by npego, Nov 12, 2019.
  1. Nov 13, 2019 at 8:27 PM
    #61
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Depends on the distributor of the cellular dongle. And the supplier of the APP software.
  2. Nov 13, 2019 at 8:30 PM
    #62
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    12volt and N2 use Car Link
    TRD2010SpeedwayBlue likes this.
  3. Nov 13, 2019 at 8:33 PM
    #63
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    ohh okay. good to know.
    beergeek[QUOTED] likes this.
  4. Nov 13, 2019 at 8:38 PM
    #64
    Vo0Do0
    Vo0Do0 Well-Known Member
    2020 VooDoo Blue Tacoma TRD Off-Road
    I really like Compustar, they are just down the road from me also. Every time I get a new truck I swing by and get a system direct from them.
  5. Nov 14, 2019 at 3:59 PM
    #65
    Rockslide
    Rockslide Well-Known Member
    2019 Cement Tacoma Off Road
    Exactly, overpriced, and then an annual service fee to boot - no thanks!
  6. Nov 24, 2019 at 12:03 AM
    #66
    blitzkrieg69
    blitzkrieg69 Well-Known Member
    Bryan
    Maricopa, AZ
    07 DCLB
    Sir, you need to spend a summer or two in Arizona. When you get off work and it's 118 degrees out (yes, literally) and your vehicle has been sitting there baking in the parking lot all day, you don't want to get in to turn on the AC, or roll down the windows. You don't want to get in at all. And you certainly don't want to stand outside waiting for it to cool down. My last Benz had stainless steel door lock pins, and I have scars on my arm from where I accidentally bumped the driver's door lock pin while reaching out my window to swipe my security card at the gate. In cold climates, you can always climb into your car with your parka, mucklucks, and gloves keeping you warm, but unless you want to get escorted off property, you can't start taking clothes off to get into your sweltering ride.
  7. Nov 24, 2019 at 12:06 AM
    #67
    blitzkrieg69
    Bryan
    Maricopa, AZ
    07 DCLB
    When it's 118 out and your car has been parked outside, it's significantly hotter inside the car. Even with a great AC system, you'd be surprised how long it can take to cool down the interior of a vehicle to where it's tolerable to drive.
  8. Nov 24, 2019 at 4:57 AM
    #68
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    In Arizona it's a dry heat. Here in the south the humidity is the real killer. I'll take a dry heat any day.
  9. Nov 24, 2019 at 10:04 AM
    #69
    TRD2010SpeedwayBlue
    Brandon
    well that’s much different as it never gets that hot here in NYS
  10. Nov 24, 2019 at 10:13 AM
    #70
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I'm in PA and use it every day except Sept, Oct, and April.
  11. Nov 24, 2019 at 7:49 PM
    #71
    blitzkrieg69
    Bryan
    Maricopa, AZ
    07 DCLB
    When it's 100-110 the dry heat is much nicer. Once you pass 110, it doesn't matter how dry it is, it's damn hot.
  12. Nov 24, 2019 at 10:49 PM
    #72
    Lemmy68
    Lemmy68 Well-Known Member
    Dude, correct me if I’m wrong but remote start does not roll down your windows to vent hot air before starting your AC..Efficiency fail.. open windows and start AC. More efficient to warm a cold car than hot one with windows closed.
    Lived in Jersey with 110 plus degree weather..yawn.. negative zero to 100 plus.
    Yes, you can’t peel off your skin to get cool... You have burn scars? I suggest wearing baker’s mitts ,protective UVF sleeves, face shield and sun hat and if you’re that sensitive to heat.
    Have kin in AZ...smh...
  13. Aug 19, 2020 at 9:28 PM
    #73
    fryrice
    fryrice Well-Known Member
    MA
    2020 MG Access Cab SR w/ SX pkg
    Sorry to bring back an old thread but what’s the difference between n2 and 12v?
    other than n2 is $24 less and need to cut the tpms wire on my 2020
  14. Aug 20, 2020 at 1:24 AM
    #74
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Nothing. Same hardware. It's our customer support that's incomparable. Check your PM.
  15. Nov 18, 2020 at 3:15 AM
    #75
    Synomenon
    Synomenon Member
    You sure about that? I've asked questions on your Facebook page and received no response...
  16. Nov 18, 2020 at 9:55 AM
    #76
    N2DesignsInc
    Los Angeles, CA
    110% Sure. Our apologies but our social media accounts aren't the fastest way to get a response unfortunately as we check and respond to those when we can, but you can always reach out in the many other ways available like calling us, emailing us, or messaging us here if you want a fast response.
    We can't tell who you are on FB, mind asking us again here?
  17. Nov 18, 2020 at 1:40 PM
    #77
    Synomenon
    Synomenon Member
    Just wanted to know which iOS app. specifically your system uses. Thanks.
  18. Nov 18, 2020 at 3:42 PM
    #78
    N2DesignsInc
    Los Angeles, CA
    I believe we emailed you the response...and document guides you asked for earlier. Did you receive it?
  19. Nov 18, 2020 at 3:51 PM
    #79
    Synomenon
    Synomenon Member
    Yes, I checked my email after replying here and saw it. Thanks!
    I'm comparing your system now to the Compustar kit my local dealership offers.
  20. Nov 18, 2020 at 4:29 PM
    #80
    N2DesignsInc
    Los Angeles, CA
    Compustar's telematic (smart phone) add on is DroneMobile. Their basic plan per year costs $60/yr or $143 for 3 years, which is $20/yr and $43/per 3 years more than ours, AND YOU DON'T GET GPS tracking unless you bump up your plan from Basic to the Premium plan, which then gives you GPS for $120/yr or $287 for 3 years, which is $80/yr and $187/per 3 years more than ours...not to mention, thier trial/free period is ONLY 30 days. Ours is 1 year.
    fryrice and Synomenon[QUOTED] like this.
