Remote door unit problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DocD, Mar 9, 2016.
  1. Mar 9, 2016 at 4:09 PM
    DocD
    DocD [OP] Well-Known Member
    Mn./SoCal
    09 access cab
    When I use the remote to lock the doors the sound that the unit omits keeps omitting, when I push the unlock everything is normal, any ideas as to why, Thanks
  2. Mar 9, 2016 at 5:07 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Do you mean the truck continues to emit a constant beeeeeeeeep ?
    If so make sure the doors are actually shut completely. That will cause it. If the doors are completely shut and it still does it it is probably one of the door switches.
  3. Mar 9, 2016 at 5:31 PM
    DocD
    Mn./SoCal
    09 access cab
    Jimmyh, You "Nailed" it. it appeared that all the doors were closed, but one of the access door wasn't quite there, close enough where it would lock, but not closed enough. Thanks!!!
  4. Mar 9, 2016 at 7:34 PM
    Jimmyh
    SC
    2012 Prerunner SR5
