Remote Entry Beeps have Changed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by motoyoyo, Jan 28, 2013.
  1. Jan 28, 2013 at 10:38 AM
    motoyoyo
    motoyoyo [OP] Member
    Ok, this may be a stupid question, but I couldn't find any info on it. My daughter's 2008 Sport TRD has had the remote entry horn beeps turned on. It has always beeped once for opening doors and twice for locking doors. Now, the horn beeps only once for both opening and locking. She wants Dad to fix it, but I can't find any info on why it changed.
  2. Jan 28, 2013 at 4:28 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    You have got to feel good that she wants Dad to fix it ... other than that I've got nothing ...;).
  3. Jan 29, 2013 at 5:57 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Battery?
  4. Jan 29, 2013 at 6:06 AM
    Large
    Large Red
    Mine is the opposite, once for lock, twice for unlock. I wouldn't mind it beeping once for everything though.
  5. Jan 29, 2013 at 10:28 AM
    motoyoyo
    It's odd that there isn't just a standard configuration. This truck has the factory security (alarm?) which is just a blinking red led light in the block off cover where the differential lock button would be. One factory manual shows an led that can be switched in or out for valet or programing mode.
    This one is just an led but no switch. It is a factory or dealer installed option for this truck and was purchased this way from the dealer. It uses a standard three button Toyota remote key fob. The red led is flashing all the time now with two quick flashes and a brief pause. I believe it used to turn off when the truck was started, but now is on all the time. The alarm/horn beeps must be related somehow.
    I have searched for info on this but I have not found this particular situation come up before. At least I was able to impress my daughter by fixing her overhead console with info I found here. The dredded "510" solder fix solution.
  6. Feb 25, 2013 at 5:21 PM
    JCruiser
    JCruiser Well-Known Member
    Master Chief (E-9) USN (Ret)
    Georgia
    '23 Tacoma SR5 4WD 4D "Ice Cap" w/ XP Package
    Upcoming...... Pro grille and driving lights
    Look and see if there is a Valet override button somewhere that has the circuit closed. Several years ago I bumped mine in another vehicle and it took me a month then one day I was running the vacuum and found it under the console on the left, somewhat hidden. Just an idea!
  7. Feb 25, 2013 at 8:58 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The push button is built into the LED.
    If you have the ignition on and press it in, the car is in valet mode and the LED Light should stay lit because it is in Valet Mode.
    Depressing it will turn off valet mode and turn off the LED.
    There should have been a small booklet in the glove box with this information.
  8. Mar 17, 2013 at 4:19 PM
    ptree801
    ptree801 Newbie
    Peter
    Tucson, AZ
    08 4x4 quad cab Tacoma,10 Ltd CrewMax Tundra
    I recently had the same problem and read this post. My LED was flashing constantly with the ignition on or off and even unplugging the battery it still stayed on. After reading this I held the button in on the back while turning the ignition on and after a few seconds of holding it down the truck made 4 short honks and then the light went out. Nice. However it doesn't give me the one short honk after arming it. It usually did after a minute. I didn't have a book on the alarm so any ideas?
