remote res vs non res
Discussion in 'Suspension' started by cdnbanker, Jul 23, 2009.
  1. Jul 23, 2009 at 8:30 AM
    cdnbanker
    cdnbanker [OP] Well-Known Member
    hey guys, looking for some opinions: at what point does one need to get a remote res?
    for your average, maybe even below average, weekend warrior, would non-res shocks/coilover be sufficient.
    just looking to save money and not regret it in the future.
    thx
  2. Jul 23, 2009 at 8:31 AM
    98tacoma27
    Ben
    Not Beech Creek
    For weekend warrior and budgetary constraints, yes coilovers would be sufficient.
  3. Jul 23, 2009 at 8:31 AM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2018 Tacoma TRD PRO
    non res, you aint racing or beating the snot out of it you wont need the extra res IMO.
  4. Jul 23, 2009 at 8:32 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Desert running and high-speed stuff where the shocks would tend to overheat necessitates reservoirs. Crawling, trails, etc. not so much.
  5. Jul 23, 2009 at 2:43 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    as ^^^^^^ he said.i got the resis but ONLY because of the deal i got on them.
  6. Jul 23, 2009 at 11:25 PM
    icon2
    icon2 ICON VEHICLE DYNAMICS Vendor
    Corona
    In most cases the resi is absolutely overkill and I would recommend against them. With the Tacoma we actually do a rear resi because we can get more travel out of the shock than a non-resi. Because of this, the shock we offer has the most travel of any Tacoma shock on the market utilizing the stock mounting points. In this case adding a resi is much more than heat disapation.
  7. Jul 24, 2009 at 7:37 AM
    mjp2
    NJ
    Icon is here? :yay:
  8. Jul 24, 2009 at 2:55 PM
    DylanICON
    DylanICON Suspension Guy
    Dylan
    Corona, CA
    07 Tundra, 02 Tacoma
    Long travel, coilover, 2.5" ICON piggy backs, SC, Glass, 35", 4.88, HID's, ect.
    For the front coil-overs you also have the option of converting them to remote reservoir at a later date. Just send them in and we change out the top cap, upper mount and add the hose reservoir and bracket plus rebuild them.
    In addition to heat capacity and “Cool Factor” like Mike stated we often need to go remote reservoir for the increased down travel. By moving the nitrogen/oil dividing piston and the nitrogen chamber out of the upper part of the main cylinder in to the reservoir cylinder we then have more room in the main cylinder for a longer shaft. Most of our reservoir rear applications are primarily for this reason; the front coil-overs do not need the reservoir for shaft length so it is an option for heat and bling. The coil-overs we make for the Chaos long travel kits are all reservoir for travel and harder use.
