Remote start alternatives
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tac0_2sday, Jun 20, 2023.
  1. Jun 20, 2023 at 12:33 PM
    Tac0_2sday
    Tac0_2sday [OP] Active Member
    Eric
    ‘23 Tacoma TRD OR 4x4
    Has anyone tried installing an aftermarket remote start system on their 3rd gen that works better than the stock one?
    I know I have the stock one that turns on when you press lock button 3 times but my main issues with this is that it only stays on for about 10 min, and it’s dumb that the truck turns off when you open the door.
    I live in SoCal, so honestly my main reason for wanting this feature is so I can leave my dog in the car with the AC on while I run in the store lol
  2. Jun 20, 2023 at 12:40 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I don’t think anyone has found a reasonable way to override the door open shutoff, I could be wrong though.
  3. Jun 20, 2023 at 1:21 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    why would you need a remote start if you are leaving the truck running?
    in some states you might get in trouble with the law if you leave a child or dog in an unattended car running or not
    RedWings44 and ToyoTaco25 like this.
  4. Jun 20, 2023 at 1:26 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    No way around letting it run longer, or not to turn off door opens. Toyota safety. No has cracked that override.
    gsubioguy likes this.
  5. Jun 20, 2023 at 1:29 PM
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    My suggestion would be to look at the systems run by law enforcement k9 teams. They have a large array of systems that can be customized and will also monitor any heat issues. I cannot think of anyone else outside of that industry. Even my viper system shuts off when opening a door. plus its important to have some sort of heat alarm if you are going to leave your dog in the truck any longer than 15 mins on a hot day.
    RedWings44 likes this.
  6. Jun 20, 2023 at 1:58 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    N2 Designs.
  7. Jun 20, 2023 at 2:01 PM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Still shuts off when door is opened (if you don't have an H key) and has a duration timer
    drizzoh and Chew like this.
  8. Jun 20, 2023 at 2:02 PM
    oconnor
    oconnor Where am I?
    Midwest
    Ah, mine is a MT so doesn't shut off...
    gsubioguy[QUOTED] likes this.
  9. Jun 20, 2023 at 2:04 PM
    gsubioguy
    Evan
    Maine
    '21 TRD OR
    With a physical key?
    RIX TUX likes this.
  10. Jun 20, 2023 at 2:05 PM
    oconnor
    oconnor Where am I?
    Midwest
    Correct.
  11. Jun 20, 2023 at 2:07 PM
    gsubioguy
    Evan
    Maine
    '21 TRD OR
    Thats the key (pun not intended) not the tranny type. With a physical key, it won't shut off when opening door but it requires the key put in the ignition. The push button start models all shut off when door is opened, regardless of transmission.
    drizzoh likes this.
  12. Jun 20, 2023 at 2:09 PM
    oconnor
    oconnor Where am I?
    Midwest
    That sucks. I guess I like my truck even more now.
    Sorry OP.
  13. Jun 20, 2023 at 2:10 PM
    2020TacomaGuy
    2020TacomaGuy Well-Known Member
    2020 4x4 DCSB SR5
    What's an H key?
  14. Jun 20, 2023 at 2:10 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    What I used to do was start it as normal and made sure all the doors were locked. The driver's door obviously wouldn't be and the key fob won't allow you to lock it while running. How I got around this was using the physical key to manually lock the door. It'll run as long as you like. Someone can break in and take your truck, but it'll work.
  15. Jun 20, 2023 at 2:13 PM
    RedWings44
    Michigan
    The name for the physical key for trucks that don't have push button start
  16. Jun 20, 2023 at 2:39 PM
    RIX TUX
    maybe op should take his poodle into starbucks with him or keep it at the trailer
    na8rboy likes this.
  17. Jun 20, 2023 at 5:57 PM
    Tac0_2sday
    Eric
    This is the only solution I thought of too lol except I have to go around and manually lock each of the 4 doors. And like you said, the major down side is it can be broken into and stolen.
    Edit: spelling
  18. Jun 20, 2023 at 6:03 PM
    Tac0_2sday
    Eric
    Interesting i never thought of law enforcement equipment. And yeah, I guess you’re right about the heat alarm. In my old truck I had a 1 hour runtime on the remote start and never had to worry about my truck shutting off too quickly. I never left my dog in there that long, but with this new tacoma I already know that 10 minutes isn’t enough to run into the store to buy a few things for example. I used to take her on errands with me all the time, but now she has to wait at home if I need to run errands.
  19. Jun 20, 2023 at 6:06 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Why do you need to take your dog with you to run errands?
    RIX TUX likes this.
  20. Jun 20, 2023 at 6:15 PM
    Honest Abe
    Honest Abe Active Member
    2023 Tacoma MGM
    Stock
    If you don’t like it when the engine shuts off when you open the door, leave the window rolled down and jump in like a man.
