Remote Start expiring?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by turboks, Jan 6, 2024.
  1. Jan 8, 2024 at 2:33 PM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Sub = phone app to start etc
    No Sub = start with keyfob
    Dump the app = smart cookie
  2. Jan 8, 2024 at 2:54 PM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    My plan expired over 2 years ago and my truck still remote starts with the fob.
    Kolohe07, JG1980 and TacoTime55 like this.
  3. Jan 8, 2024 at 3:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It might set an engine light and a code.
    Apparently the charging system “self adjusted” the charge rate as the battery ages.
    If you install a new battery the self check will see the battery changed state “suddenly” and on some cars, it will put you in limp mode.
    It’s BS. But that’s the way it is.
    I understand the reasoning, but not why it was “needed”.
    I don’t look forward to the future of car repairs.
    Not sure it will be worth the cost to DIY.
    You need a scan tool with a secure gateway pass just to reset things.
  4. Jan 8, 2024 at 4:07 PM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    If it puts the car in limp mode I'll deal with it but if it just throws some codes then I don't care.
    The service engine soon light has been on for quite some time; O2 sensors by the cat. Car runs fine, same MPG so I have zero interest in fixing it.
    I miss my 97 328is - none of this nonsense!
  5. Jan 8, 2024 at 6:05 PM
    TnShooter
    Deogee
    STOCK
    You sound a lot like me.
    My TPMS light has been on for years. I didn't even bother to replace them when I did my tires.
    If they look "full" then they can't be low on air, Right?
    Seriously though, I check them a few times a year. Or after I think I might have run over something.
    The engine light, I would probably check.
    And like you, If it's not crucial to engine performance. I'll "get to it eventually". (maybe) :rofl:
    The light in the old 96' Ranger went out years ago. As in, it don't work any more. EVAP code......
    amyracecar[QUOTED] likes this.
  6. Jan 8, 2024 at 6:20 PM
    amyracecar
    Virginia Applejack
    SouthEast USA
    I check the tire pressure every month or so on both the car + truck.
    I can feel when they are down more than a few PSI so I'm mostly on top of that one.
    I catch it way before the TPMS would anyways..
    The CEL light - I'll pull the codes and see what is up but if performance/fuel consumption is the same then :notsure:
    My old BMW had the CEL light permanently on at some point; cheap aftermarket cats failed and threw O2 codes for the next 100K miles..
    When the service engine soon light came on, I knew that was BS but I pulled the codes just in case.
    Not crucial and not causing harm then I don't consider it broken and sure as shit ain't gonna fix it!
    TnShooter[QUOTED] likes this.
  7. Jan 9, 2024 at 1:40 AM
    pMill
    pMill Well-Known Member
    2023 TRD OR
    Is there any consensus on this remote start issue? I am currently looking at 2022 and 2023 Tacomas and either remote start or heated seats are factor in quite heavily in my decision. Is it that if you have keys that CAN remote start the engine, you can use them without the subscription. However, if you don't have the remote start built into the keys you need a subscription to remote start from the app?
    Thanks all, Pete
  8. Jan 9, 2024 at 2:32 AM
    Doc62
    Dave
    SE Pennsylvania
    It seems that the consensus is that the vehicle had to have had the subscription activated at some point (I cancelled it after the free period ended) for the remote start to work with the fob. Both my 21 and my son's 23 TRD OR can both start with the fob. He is still in his free period with the subscription, but the fob starts his as well as via the app.
    JG1980 likes this.
  9. Jan 9, 2024 at 6:09 AM
    pMill
    2023 TRD OR
    Thank you for the response @Doc62. So, I guess that leaves me with if I want remote start after the initial subscription, I will need to have it extended in order to continue to have remote start regardless.
    Pete
  10. Jan 9, 2024 at 8:05 AM
    Doc62
    Dave
    SE Pennsylvania
    Not sure you understood what I was saying. Correct me if I'm wrong. I was saying that is if the truck ever had a subscription plan activated, then it should start with the fob even without the subscription.
    Kolohe07 and TacoTime55 like this.
  11. Jan 9, 2024 at 11:19 AM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    I bought a Drone Mobile remote start on my 2016 Taco when I first purchased it new.
    It uses either their mobile device app or the OEM key fob. IIRC, it's about $30 for a full year.
    There was no Toyota option for remote start back in 2016. Glad to see they have it, but bummed that it's subscription based.
  12. Jan 9, 2024 at 11:30 AM
    jemorgan
    jemorgan Member
    Joseph
    2022 Army Green Tacoma TRD OR
    I’ve got a 22 TRD OR with the premium interior (leather trimmed seats, JBL audio, etc).
    Remote start with the FOB 100% works for me, my connected services are 100% expired.
    it’s relatively finicky, you have to get the timing right. Too fast or too slow and it won’t start, but once you get the timing it’s easy.
    its “press press hold”, as people here are saying.
  13. Jan 9, 2024 at 11:43 AM
    AK Dudeman
    AK Dudeman Well-Known Member
    DCBLB OR MGM 22
    It’s 8.00$ a month & 80.00$ a year jus delt with this. I had let mine expire, & when walking around store. The Miss’s asked me did You start the truck.. it was -14° Outside.. I was like Snap. called Toyota app people set up 1 month, cause was jus gonna do 1 year First of the Year. The other day I call to set up & she’s like You already have it.. im like ah what? First app. person put me on “Autopay” 8.00$ a month. GrumbleGrumble. I definitely like it & I know truck is on. From Long away.
  14. Jan 9, 2024 at 11:58 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Lots of folks say they’re being deleted so people won’t use the wrong fluids. How do you know it’s for compliance / reduced displacement? The removal of the dipstick and tube must be super minimal. Like CCs, not like liters?
  15. Jan 9, 2024 at 12:14 PM
    #35
    amyracecar
    Virginia Applejack
    SouthEast USA
    How the f*ck you put a fluid down the dipstick?
    Plenty of places for stupid people to put the wrong fluids under the hood - the dipstick is the last place I would think someone would try to pour fluid down..
    I did see this as a common google answer though.
    I also saw that manufacturers did this because apparently laypeople have no business checking their own fluid levels.
    Aka f*ck you/pay me and I'll check that sh*t for you - and pad the dealership bottom line.
    I know it is a tiny amount but when I got the car 10yr ago, and was pissed about the no/dipstick, I asked a mechanic friend of mine.
    He told me it was the manufacturer not wasting precious displacement on a dipstick - they are tryin to squeeze every last cc they can into making power. Makes sense.
  16. Jan 9, 2024 at 12:18 PM
    #36
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I hang around young people a lot. Cars are mystery boxes to so many of them. Sigh. Okay, sorry OP! Not meaning to derail the thread with nonsense about dipstickery. Back to remote start, that thing kids did to their Civics in 1999 so they could show off in the Del Taco parking lot on Thursday nights.
  17. Jan 9, 2024 at 12:59 PM
    #37
    CSVT
    CSVT Well-Known Member
    Ohio
    2021 TRD Pro
    Once my initial subscription expired, I elected to pay for the remote start services but only for a few months in the winter where its actually useful ($8/mo). To my surprise, I can still remote start even when my subscription is INACTIVE, but only from the FOB.
    The benefit from the app is range is unlimited, with FOB remote start being line of sight within a 100 feet or so.
  18. Jan 9, 2024 at 4:02 PM
    #38
    pMill
    2023 TRD OR
    Thank you @Doc62! Makes sense now.
    Pete
  19. Jan 9, 2024 at 4:20 PM
    #39
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I had Remote Subscription plan activated before I drove away from the dealership with my new 2021 Sport...
    that should count as activated plan even though it was included service for 1yr, right?
    Then, when the free subscription expired, I declined continued service.
    Remote Start still works on my truck using FOB.
  20. Jan 10, 2024 at 7:47 AM
    #40
    Doc62
    Dave
    SE Pennsylvania
    That seems to be the sequence. Get the free service for a year and not renew it. Then the truck will be able to be remote started from the fob. Just wish it wouldn’t turn off when the doors are unlocked. I have remote start on all my other vehicles and this is the only one to do that. Of course none of the others are Toyotas.
    TacoTime55[QUOTED] likes this.
