Remote Start - FOB to work after Remote Connect ends
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gutentight, Jul 4, 2021.
  1. Jul 4, 2021 at 5:33 PM
    Gutentight
    Gutentight [OP] Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    There are several threads here from pissed off owners about remote start and the key FOB not working after the free remote services trial ends. I stumbled across this MFG communication on NHTSA, which seems to say remote start is still supposed to work from the key FOB after the remote connect ends.
    Here is hoping that someone verifies if key FOB remote start not working is only a bug, not a feature. Note - looks like this is likely going to need a member with TechStream, or a very cooperative dealer.
    https://static.nhtsa.gov/odi/tsbs/2020/MC-10190459-9999.pdf
    Tech TipT-TT-0599-20
    NOTE: Network/cellular coverage may influence response time from each command. Sending multiple commands in a short period of time is not recommended. The remote start by key FOB is only possible (authorized) after the first successful start using the phone app.
    4.Key FOB Remote Start Operation:Once the remote start from the key FOB is functioning after telematics enrollment and remote authorization, it should continue to operate even if the customer allows the remote services trial to lapse and not renew. If the key FOB remote start function no longer works after the trial has lapsed, check the Telematics Datalist items below.
    • Remote Operation: Enabled (functioning correctly), Disabled (Contact the BEC)
    • Remote A/C by Smart Key: Enabled (functioning correctly), Disabled (Contact the BEC)
    • Remote Engine Starter Registration: Registered (functioning correctly), Not Registered (See section 3. B. of this document)
    • Remote Door Lock Function: Registered (functioning correctly), Not Registered (See section 3. B. of this document)
    • Communication Pausing State: Cancel Pausing (functioning correctly), Pausing (Perform the “Cancel Communication Function Pausing” Utility in Techstream or select the “OK” button on the Service Mode Screen displayed on the Radio Screen.
    bctaco21 likes this.
  2. Jul 4, 2021 at 5:37 PM
    lylefk
    lylefk Well-Known Member
    Maui, HI
    '21 4wd Cement Sport DCSB
    Nothing major
    I do not have the Remote Connect, it's not an option on my truck here in Hawaii. Fob works fine. Don't understand why it would possibly stop working.
  3. Jul 5, 2021 at 3:00 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I have remote connect but do not use it. The FOB works fine with no problems.
  4. Jul 6, 2021 at 10:00 AM
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    I remeber reading one if the post about this topic. A few member said that the remote start thru the app will stop working. But the key fob will still work.
    PilotguyPA28 likes this.
  5. Jul 7, 2021 at 6:54 AM
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    So other than remote start with the app what else does it give you ??
  6. Jul 7, 2021 at 7:35 AM
    DNguyen1033
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    I dont use the app, but I remember people were saying it can start/stop ur car, lock door, roll up your window, remember where you last park. All from a very far distance. Not sure what else it can do. Maybe someone here who uses the app can confirm?
  7. Jul 7, 2021 at 7:56 AM
    Blauman
    Blauman Well-Known Member
    San Diego
    2020 MGM DCSB 4x4 OR
    I used it for the trial period and you could remote lock and start/stop the truck, dont think you could control the windows though. It would also alert you if you forgot to lock the doors and would keep the location it was left at. Other than that though it was pretty useless IMO and not worth the 8 bucks a month to continue using it. And since the trial ended I have used my FOB to remote start the truck several times with no problems.
    PilotguyPA28, sporin and DNguyen1033 like this.
  8. Jul 7, 2021 at 8:17 AM
    Steve Armstrong
    Steve Armstrong Well-Known Member
    SoCal
    2021 TRD Sport DCSB
    From the App Store:
    Toyota app was developed to provide a convenient way to stay connected and informed about your vehicle.
    The Toyota app supports 2010 or newer Toyota vehicles and for Hawaii customers, 2018 or newer Toyota vehicles.
    • Owner’s Manual & Warranty Guides
    Access to your owner’s manual and warranty guides at your fingertips.
    • Dealer Locator
    Login to the app and search for the closest Toyota Dealer and save your preferred dealer for future reference.
    • Service Scheduling
    When it is time to schedule your next service appointment, the app can assist.
    • Roadside Assistance
    In the event you need Roadside Assistance, login to the app for Roadside Assistance contact information.
    Toyota app also supports Connected Services on select 2010 or newer, for Hawaii customers 2018 or newer capable vehicles. Sign up to activate, or manage your vehicles Connected Services.
    • Remotely start/stop your vehicle.
    This feature lets you remotely start your vehicle to warm or cool the interior based on the last climate-control settings.
    • Lock/Unlock your doors
    Not sure if you remembered to lock your vehicle? Now you can remotely lock and unlock your doors and receive confirmation.
    • Find your parked vehicle
    Locating your parked vehicle just got easier. Vehicle Finder uses the map on your smartphone to guide you to your vehicle's last known parked location.
    • Guest Drivers Alerts and Notifications
    You can set predetermined driver privileges by activating the Guest Driver Profile in your app.
    • Vehicle maintenance alerts and health reports
    You can now check your maintenance alerts and see your vehicle’s health status with the touch of a button.
    • Drive Pulse
    Drive Pulse encourages you to improve your driving habits.
    (1) Available services vary by vehicle and subscription type.
    (2) Remote services: Be aware of vehicle surroundings. Operate when legal and safe (e.g., do not start engine in enclosed space or if occupied by a child). See Owner’s Manual for limitations.
  9. Jul 7, 2021 at 8:32 AM
    Grindstone
    Grindstone Requires Adult Supervision
    I let the free service expire. Remote fob still works.
    If your fob doesn't work, you're probably doing it wrong.
    Chucky888_2021_TRD_OR likes this.
  10. Jul 7, 2021 at 8:40 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Everything listed except roll up windows in my ‘21.
    DNguyen1033[QUOTED] likes this.
  11. Jul 7, 2021 at 10:07 AM
    DNguyen1033
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    Ah, thanks for confirming. I don't use the app and I guess my memory isn't that good lol.
    In that case, Toyota ain't getting a single penny from me just for that.
  12. Jul 7, 2021 at 11:41 AM
    Wicker24
    Wicker24 Well-Known Member
    2018 TRD Off Road
    Just went and checked mine (2021) with current connected services. Cannot remote start from my fob, assuming it is 3x lock button like my 2018 plug and play remote start was?
  13. Jul 7, 2021 at 11:42 AM
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    You have to press and hold for 3 seconds on the third press.
    HP11 and Wicker24[QUOTED] like this.
  14. Jul 7, 2021 at 11:53 AM
    Wicker24
    2018 TRD Off Road
    That worked! Thank you, the press and hold part had escaped me.
    mlr69[QUOTED] likes this.
  15. Jul 7, 2021 at 1:48 PM
    mlr69
    South Carolina
    I only knew because my wife has a new RAV4. My Taco is like your old 2018, just a 3x lock button press.
  16. Jul 7, 2021 at 1:50 PM
    Wicker24
    2018 TRD Off Road
    Fair enough, I'm just glad you knew! I had tried it in the past as well and just figured it would only work with smart connect and when that was up I would just order a new PNP system for $150 and move on. Glad it is integrated tho!
  17. Jul 11, 2021 at 12:47 PM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    It USED to be that once the app expired and not renewed, they would disable it all over the air. Once they realized that (or heard us/other complain) that the fob is free airwaves, things changed silently. They initially disabled it all to grab your attention on renewing your subscription (money grab) but that's not right. I said it the whole time, its like not paying your TV cable bill, and instead of just taking away your channels/service, also disabling your volume up/down functions on your TV remote...that was wrong and should be illegal frankly.
    The other drawback is that by subscribing to the remote connect service, the fine print terms state that you allow Toyota to monitor your driving habits for statistical and analytical improvements...and access to the your mic...just saying. Some have a problem with that as it infringes on privacy. Just don't use a remote connected vehicle to traffic for the cartel or discuss how to evade the IRS...:D:p
    Gutentight[OP] and sporin like this.
  18. Jul 11, 2021 at 1:36 PM
    Nirango kid
    Gilles
    Ontario
    I was told that you can open and close windows with your FOB only if you take it to your dealer they can program it. Not sure about the apps cause I do not use them.
  19. Jul 11, 2021 at 2:43 PM
    DNguyen1033
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    I hope the window part is true. I'ma stop by Toyota next week and ask them.
  20. Jul 12, 2021 at 3:45 AM
    Nirango kid
    Gilles
    Ontario
    Only one way to find out is to go to the dealer let me know if is true.
