Remote Start Full kit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1stgen, Jan 14, 2017.
  1. Jan 14, 2017 at 11:52 AM
    1stgen
    1stgen [OP] Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
  2. Jan 14, 2017 at 10:14 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Did it come with power locks? I'm doing a conversion from manual locks to powered locks myself and I didn't wire up the lock ECU or the body ECU so I'm creating my own custom wiring harness for a Viper to control the locks themselves instead of going through the factory electronics. I'd have to swap the entire truck's wiring harness and ECU if I wanted the power doors and locks to operate the way it originally did.
  3. Jan 14, 2017 at 10:16 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
  4. Jan 14, 2017 at 10:42 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You can find them on Google, think there's even a couple on here.
  5. Jan 14, 2017 at 11:34 PM
    Speedytech7
    Good luck I tried really hard to find them. You can find the user manuals and even some of the programming ones but never the pinout and for the more advanced units they don't tell you how to set the intervals for variables like run time, turbo timer, cranking length... So on
  6. Jan 14, 2017 at 11:40 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You could easily find the hardware installation aspect instructions, but when it comes to programming I'd just bring it to a dealer and have them do it. Apparently you need a bitwriter or something?
  7. Jan 14, 2017 at 11:43 PM
    Speedytech7
    The advanced units require the Bitwriter the cheaper ones can use it but can be programmed other ways as well. The pinouts were the part I couldn't find for all but a couple very old units. At least in the case of viper and avital units and their refurbished counterparts (viper is a shit company that recycles low QC items under other brand names)
  8. Jan 15, 2017 at 12:29 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I know you didnt ask but alot of times those systems cause all sorts of crazy unwanted symptoms when they decide to stop working correctly and it can be a real bear to troubleshoot and if you do find it to be that system you then in most cases need to have someone else remove it from the truck since it pry took someone else to install it. Maybe it will never malfunction but i see from time to time on here guys having real fits from that or a similar type unit producing problems. Even finding their truck had started on its own and had been running for who knows how long, lol. Pry fairly rare occurrences how ever.... Is the key that hard to use?
    Did your truck not come with a key fob?
    Heck i figured all the later model trucks all had a factory fob...
  9. Jan 15, 2017 at 12:54 AM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    I've installed a Python keyless entry / remote start system in an old car of mine and was able to find a wiring diagram online, although from a different model.
    I recently bought a base level PreRunner that had an old unused alarm system, and had aftermarket lock actuators previously installed. I had Bestbuy install a new Viper keyless / remote start system, mainly because I learned that any eBay system available is refurbished, only dealers get new systems.
    I love the convenience off the fob. Remote start is just cool.
  10. Jan 15, 2017 at 11:58 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Remote Start with good A\C system in Phoenix AZ area is GREAT!
  11. Jan 15, 2017 at 12:02 PM
    bry838
    oregon
    I could see how remote start would be a great feature in super hot climates! Id wanna pre cool my rig as well!! Heck and easily pre heat for that matter as well...
    mechanicjon likes this.
  12. Jan 15, 2017 at 5:38 PM
    bsb120
    bsb120 Well-Known Member
    Bradley
    Easley, South Carolina
    2016 DCLB TRD SPORT
    you will probley need an immobilizer key bypass. FLCAN works the best I install them all the time. you will need to have it flashed by a dealer.
  13. Jan 15, 2017 at 7:16 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    English. ..... please.
    Explain
  14. Jan 15, 2017 at 7:42 PM
    Indy
    Indy Master of all I survey.
    If you have a chipped key a remote start wont work, unless it is bypassed. There are modules out there that mimic a chipped key in the ignition, modules that actually keep a key in place at all times, or you can domthe same with a spare key and a nickels worth of wire. If you have a plain key, nothing is needed.
    mechanicjon[QUOTED] likes this.
