Remote start - how to get in without shutting off engine?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by robfrye, Apr 25, 2021.
  1. Apr 25, 2021 at 10:50 AM
    robfrye
    robfrye [OP] Active Member
    Rob
    2021 Black Tacoma TRD Off Road
    Just curious - when I use factory remote start on my TRD OR via the key fob (lock - lock - hold lock), the truck remote starts just fine. However, when I unlock the truck to actually get in a couple minutes later, the engine always shuts off and I have to start it again. Is there a secret way to get in without killing the engine? Seems silly to shut it off right when you’re ready to drive away...
    Scottt1961 likes this.
  2. Apr 25, 2021 at 10:52 AM
    Kilo Charlie
    Kilo Charlie I have lost my way
    Iowa
    2017 Inferno Off Road
    No.. it will always shut off
    GarlicFarts and ORtoCOTaco like this.
  3. Apr 25, 2021 at 10:54 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    If you're referring to the shutoff when you open the door, no you cannot disable it. It's a Toyota safety feature and does not matter what type of remote start you install. The only way you can get around it is if you have a version with a key and not push button start.
  4. Apr 25, 2021 at 10:55 AM
    Bishop84
    Bishop84 Well-Known Member
    It has to switch over to the smart key for authentication, theres no solution for this.
  5. Apr 25, 2021 at 12:09 PM
    robfrye
    Rob
    bummer... oh well
  6. Apr 25, 2021 at 12:14 PM
    ugawino
    ugawino Well-Known Member
    Bill
    Paola, KS
    2021 TRD Off-Road, Silver Sky Metallic
    Mods? We don't need no stinking mods.
    Pretty sure every manufacturer has something similar built into their remote starter feature.
    Before my Tacoma, I had a Subaru Tribeca and a Ford Explorer with remote starts. And both of them turned off when you opened the door. It's to keep someone from being able to steal your car while you're warming it up.
  7. Apr 25, 2021 at 12:40 PM
    robi0024
    robi0024 Well-Known Member
    WA
    21 Double Cab TRD Off-Road
    My wife’s 2021 Subaru Ascent allows us to get in the car after remote start has been initiated. We unlock the car, get in, then press the break and start button simultaneously. Engine stays on and we drive away.
    So the engine cutoff is a Toyota thing.
  8. Apr 25, 2021 at 12:47 PM
    Uscolt45
    Uscolt45 Member
    Bryan
    Denver
    2021 TRD Pro Mag Gray
    My wife’s wrangler lets you get in and mess with stuff, but you have to hit the brake and the start button before getting out of park.
    On a side note I cannot for the life of me start my 2021 pro with the fob. Only with Toyota connect and my phone. Is it possible my truck doesn’t have the remote start that the fob uses, and only the app version?
    Go_Outside and jjbeenken like this.
  9. Apr 25, 2021 at 12:47 PM
    CassND
    CassND Well-Known Member
    Cass
    North Dakota
    2020 Tacoma DCLB
    Stock
    Also, the Toyota app sucks. It won’t keep me logged in. I have to log in every time I use it.
  10. Apr 25, 2021 at 12:49 PM
    RedWings44
    Michigan
    Most have something. But a lot of them are much more streamlined. RAM has to detect the key and requires you to push the button, if I remember correctly.
    That being said, many also haven't seemed to figure out a way to not allow the vehicle drive away without the key as long as you can get into the truck. I saw this happen on a Silverado and tested it on my Tacoma to find the same results.
  11. Apr 25, 2021 at 12:51 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    Start it with the door open
  12. Apr 25, 2021 at 1:19 PM
    robfrye
    Rob
    Not helpful when it’s raining and cold (normal use case 6 months of the year in Seattle)
    jjbeenken likes this.
  13. Apr 25, 2021 at 1:21 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Have you tried lock-lock-lock(hold)?
  14. Apr 25, 2021 at 1:21 PM
    robfrye
    Rob
    It’s definitely not industry standard - I’ve had other cars and trucks that allowed remote start with the key fob and then drive off without shutting down. They just wouldn’t shift out of park without the key fob being close by to prevent theft. I’ll chock it up to a slightly annoying idiosyncrasy of this truck.
    TRDPRO68 and drvn like this.
  15. Apr 25, 2021 at 1:25 PM
    Watkinseli91
    Watkinseli91 Well-Known Member
    Eli
    Greenville, SC
    2021 LR PRO
    Funny you say that. I installed the accessorides remote start on my wife’s 2019 4Runner and once it’s running, you just get in and put your key in, turn it to “on” and put it in gear and go…
    robfrye[OP] and CassND like this.
  16. Apr 25, 2021 at 2:12 PM
    Uscolt45
    Uscolt45 Member
    Bryan
    Denver
    Yep. In lots of different variations. None have worked for me. But the app fires it right up.
  17. Apr 25, 2021 at 2:14 PM
    robfrye
    Rob
    this might have something to do with your other lock-related settings. I think I remember messing with those at some point and one of the settings seemed to prevent remote start from working
  18. Apr 25, 2021 at 2:15 PM
    Uscolt45
    Uscolt45 Member
    Bryan
    Denver
    Settings I access through the radio? I’ll check that out but don’t remember anything about remote start.
  19. Apr 25, 2021 at 2:18 PM
    jamesfishn09
    jamesfishn09 Well-Known Member
    2003 Tundra
    Pretty easy stuff. Just remember to keep rear slider open. Open shell door, tear up knees on tailgate and you slide across bed. Pass arms and head first through open slider window and plop yourself down into back seat. From here it pretty easy to wrangle oneself into the driver seat. Assuming this process didn’t take more than 15 minutes you can now sit there with your truck running (you still can’t go anywhere but you will be in your truck with it running).
  20. Apr 25, 2021 at 2:18 PM
    ryan20021982
    ryan20021982 Monochrome Tacoma
    Illinois
    2020 Tacoma TRD Off Road
    Icon Stage 3 Fuel D726 17x9 -12 Falcon Wildpeak M/T's 285/70/17 Pro style headlights Auxbeam high and low beams Morimoto xb fogs Pro grill Smoked raptor grill lights w/ drl harness from r4t Hidden grill lightbar Anytime camera kit w/ front camera AVS bug deflector AVS window visors Meso ultimate turn signals Winjet smoked tail lights OEM tailgate lock kit Tinted windows APS iArmor Side steps Taco tunes 4ch and subwoofer amp All Kicker speakers Fox acoustics dual 10" box w/ Kicker subs All Meso interior lights Meso chrome interior delete kit Meso door handle covers Meso Stealth Pro shift knob Trd black exhaust tip Demon front hook mounts with hooks Spotter mirror glass Wheelers superbumbs w/ ubolt flip kit Durobumps in the front
    This would not work, truck would shut off as soon as you hit a pedal
