Remote start in manual vehicles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ccrames2018, Jan 11, 2020.
  1. Jan 12, 2020 at 4:58 AM
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    The truck doesn't have any prox sensors (or other positive indication of being in gear) in the transmission, so it really isn't a fool proof system.
  2. Jan 12, 2020 at 5:02 AM
    Ccrames2018
    Ccrames2018 [OP] Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    Yeah that's what's making me start to reconsider... My roommate just got a remote starter in his Infiniti and it got me thinking about how cool it would be, but I'm a bit scared I'd somehow start it in gear or have it run away on me if an e brake cable broke.
  3. Jan 12, 2020 at 5:11 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I’m interested in one as well for my ‘13. I’ve never heard or read of a manual remote start on our trucks taking off. Can you post a link to those that have?
  4. Jan 12, 2020 at 5:12 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    The ones that have were on other make/model cars, but just knowing we don't have any sensors that tell the ECU the truck is in gear worries me a bit.
  5. Jan 12, 2020 at 5:13 AM
    evanwile
    evanwile Canadian Pomp
    Evan
    Canada
    2018 TRD Sport 6M
    Trust me. You CANNOT leave it in gear with the N2 system. There is no way. Its not like a remote start system on an automatic. If you dont leave it in ready mode it won't start, if you leave it in gear then it CANT be in ready mode.
    As far as the ebrake cable snapping... i trust that mechanical connection much more than the electronically controlled automatic transmissions on most vehicles today.
    If you have any concerns message or call @N2DesignsInc
    He was fantastic when i was purchasing and talked to me on the phone for 20 minutes explaining how the system works and fielding my questions. Fantastic customer service.
  6. Jan 12, 2020 at 5:13 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Do they make a kit for 05+ Tacoma's? I only saw the 16-19 one.
  7. Jan 12, 2020 at 5:14 AM
    evanwile
    Evan
    Canada
    2018 TRD Sport 6M
    This actually made me lol
    TuRDLYFE[QUOTED] likes this.
  8. Jan 12, 2020 at 5:15 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    With the procedure that’s required to put it in ready mode, I figure the only way it would take off in gear would be if someone reached in through an open window after it’s off and put the truck in gear.
  9. Jan 12, 2020 at 5:17 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Yeah, and I never leave my windows down anyways. Just wondering if they make one for our trucks or not, not seeing one.
    vssman[QUOTED] likes this.
  10. Jan 12, 2020 at 5:53 AM
    LVYOTA
    LVYOTA Well-Known Member
    2014 TRD Sport MT
    Anyone know if they make the N2 for a 2014? I can only find one for 2016-2020.
  11. Jan 12, 2020 at 6:53 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I’d say no.
    I wanted tires the Wife got the remote done, it was a gift.
    But it seems the setup would be similar?
    This would mean you having the truck in gear running and getting out.
    I worry more about me hitting the brake pedal or not shutting door tight or forgetting something inside.
    And it isn’t set up anymore.
  12. Jan 12, 2020 at 6:54 AM
    AdamM
    AdamM Semi-pro aardvark wrangler
    Adam
    Edmonton, AB
    14 DCSB base 6MT 4x4
    I have an Astrostart two way starter in my truck. I had it installed before i brought the truck home when I bought it. There's no way it could start in gear, as you can't arm the starter with the truck in gear. If you leave the truck in gear when you shut it off, you can't use the auto starter.
    Ccrames2018[OP] likes this.
  13. Jan 12, 2020 at 7:13 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    After reading the manual for the one that I would want, I'm thinking I might get this one. I like that it comes with a master switch to turn off the starting feature when you don't want it to be able to remote start, and the safety sequence isn't overly complicated.
    Why did you disconnect it, and did you like it when you still had it?
  14. Jan 12, 2020 at 7:15 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Does yours also stay running while you exit the vehicle then shut off after shutting the door?
  15. Jan 12, 2020 at 8:09 AM
    #35
    AdamM
    Adam
    Edmonton, AB
    Yes, it keeps running until the last door is shut.
  16. Jan 12, 2020 at 8:11 AM
    #36
    AdamM
    Adam
    Edmonton, AB
    I still have it, it works great, I use it all the time. It's especially great on days like today when it's - 30°C.
  17. Jan 12, 2020 at 8:56 AM
    #37
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    So I figured out which one I want, but the only place near me that can install it is Best Buy, and I'm pretty sure they won't do it on manual transmission vehicles. I need to call them and ask.
  18. Jan 12, 2020 at 9:25 AM
    #38
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    It's awesome for living in Canada. The shutdown sequence is involved so no risk of starting accidentally. If anything changes out of the norm after the sequence (shifting with clutch in, activating parking brake before truck is in neutral, etc.) the truck will shut down as soon as key is removed and not remote start. Truck doesn't stop running until you lock doors after you leave the truck.
    When remote starting the truck doors are locked and the truck won't drive until you unlock, get in and put the key in the run position on the ignition otherwise it just shuts down. Plus most young thieves probably can't drive stick if they somehow get around the safeties.
    Since it's a sequence I always crank the defrost and seat heaters in the winter before shutting down. Also I wouldn't trust it if I was parking on any sort of real grade but wherever I park is generally pretty flat.
    Mine was already installed when I bought the truck. Also, the remote starters for my wife's car and my truck both seem to start falling apart and breaking after a couple of years. Pain in the ass
  19. Jan 12, 2020 at 9:28 AM
    #39
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    You mean the remotes start breaking after a couple years or the actual system stops working?
  20. Jan 12, 2020 at 9:31 AM
    #40
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    The N2 kit is for a 3rd gen.....
    OP has an ‘07.....
