Remote Start / Interior Lighting issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AkArin, Dec 17, 2014.
  1. Dec 20, 2014 at 7:44 PM
    #41
    devanb3
    devanb3 Well-Known Member
    devan
    hampstead
    run through sll of your light possibility if you installed the viper check the parking light wire you tap into trace it back and see if you can find some kind of split from itself because it sounds like your only getting power to it when your viper is on meaning the viper is providing the power not the typical power source. if you cant try to tap into another 12v remote wire to see if they come on then. it seems like a simple yet frustrating fix
    EDIT: just thought of this when most installers install they will either use a clamp style wire tap which no one recommends or splice the wire and wrap the new around the existing... with some of the stock wires being really thin (have silver bands) this makes them easier to split upon install or even just heavy movement so again test check your viper wires where they are run to..
    i have this setup and have installed these multiple times in various vehicles so i kinda know what im saying but again as stated above it could be something you physically messed up when your install and radio work
  2. Dec 20, 2014 at 10:50 PM
    #42
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Do you think it could be a blown tail light fuse?
    :D
  3. Dec 20, 2014 at 10:57 PM
    #43
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    you won't be disapointed. I did the CST leather at the start of the group buy. I'm happy with what I got but most people weren't. the katzkin seems like a superior quality. if it gets cold where you live I'd recommend installing heat seaters while you're in there. I love mine... use it most of the time except summer.
    its not thicker skin. plenty of people on here have called me an asshole or worse for my responses. thick skin doesn't do anything but make you even more pissed off when you are suggesting something that's not only is the BASIS for checking electrical circuits, but is also what would've FOUND THE PROBLEM.
    You blatantly called me out saying that there is no way it could be a fuse... and yet thats what it was....
    show a little respect for people that have been on this site longer than you.
    thanks for trying to help the OP, but try to change your attitude next time.
    me too. 5 minutes and you know for sure if your fuses are good or not. also helps when installing new shit to know if the ground youre trying to use is good or not.
    thanks for trying to help. OP already found the problem though.
    props for trying to help anyway though
    :thumbsup:
    :cheers:
  4. Dec 21, 2014 at 6:56 AM
    #44
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    PM sent.
