Remote Start Kit for 2016 - 2017 Tacoma's IN STOCK
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by KB Voodoo, Dec 8, 2016.
  1. Feb 11, 2017 at 10:46 AM
    #281
    RNtaco
    RNtaco Well-Known Member
    Rob
    Atlanta, Ga
    2016 White DCOR 4x4
    Front window tint match and windshield strip. Rubber bed mat. Running boards. Console insert. Husky floor liners. Exterior LED conversion with Diode Dynamic and Opt7. Low profile window visors.
    Got my kit from Voodoo (very fast shipping!) and my Smart Start add-on from Amazon. Sitting here waiting for stupid posi-taps to arrive on the 13th :( The wait is killing me! :annoyed:
    I feel like waiting is the best thing and not risking a "sub-par" install.
  2. Feb 15, 2017 at 10:47 AM
    #282
    RNtaco
    Rob
    Atlanta, Ga
    2016 White DCOR 4x4
    So I got my DBALL and DSM300 installed. I installed DBALL, reconnected battery terminal, verified functionality. Then disconnected battery again, installed DSM300 in the location you recommended above gauge cluster. Everything works well except: lock feature from the viper app does not lock truck. Lights blink once signaling what I assume is a successful command received, but the doors do not lock. Unlock feature works fine. Could it be my posi-tap did not make good connection on the OSB? Before I took things apart again I wanted to make sure you didn't have any other ideas. Thanks!
  3. Feb 15, 2017 at 10:51 AM
    #283
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The posi-taps aren't always very positive.
  4. Feb 15, 2017 at 10:54 AM
    #284
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Yes, a problem with the Lock wire connection from the DBALL2 would be my primary suspect. Your testing shows that the data connection between the DSM300 and DBALL2 seems to be okay, which then suggests looking at the DBALL2 connections to the truck.
  5. Feb 15, 2017 at 11:00 AM
    #285
    RNtaco
    Rob
    Atlanta, Ga
    2016 White DCOR 4x4
    Kind of ironic about the posi taps :crazy: I'll go trouble shoot and see what I can figure out. Thanks for the input
  6. Feb 15, 2017 at 11:07 AM
    #286
    gpb
    Atlanta
    Yeah, well, nature of the beast. :D I think positaps are the best of the vampire taps on the market, but they're still taps.
    You did use a 24-26 gauge positap, yes? Especially with tiny wires it's important to use the properly sized taps.
  7. Feb 15, 2017 at 12:03 PM
    #287
    RNtaco
    Rob
    Atlanta, Ga
    2016 White DCOR 4x4
    I'm embarrassed to admit this in "public" but I posi-tapped the wrong blue. I jumped for the obvious blue and not the light blue as specified and according to the PIN out. Rechecked my work and realized what I had done. I guess this is the benefit of Positap bc I just used e-tape to cover the small holes and spliced the correct wire. Viper command works fine now. On the original install I took double the time rechecking everything too. Surprised this slipped by me. I was convinced that the correct wire (which I did not originally splice) was green. When it in fact is light blue.
    May this be a warning to all.....the PIN out is your friend if you are color blind like me. :facepalm:
  8. Feb 15, 2017 at 12:30 PM
    #288
    gpb
    Atlanta
    @RNtaco good to know you got it working, and you bring up an excellent point. Wire colors are a great guide, but can be subjective even if you aren't color blind. Is it beige or is it tan? I always verify the wire goes to the correct pin.
  9. Feb 15, 2017 at 4:04 PM
    #289
    PJnc284
    PJnc284 Well-Known Member
    Garner, NC
    2016 Tacoma TRD Off Road 4x4
    @gpb's thread also helps with all the pretty pictures. ;)
    gpb likes this.
  10. Feb 16, 2017 at 4:37 AM
    #290
    gpb
    Atlanta
    Thanks, though you contributed a good bit of info to the thread as well. :thumbsup:
  11. Feb 23, 2017 at 7:28 PM
    #291
    Gravybird
    Gravybird Active Member
    Central MN
    17 Black TRD Sport DCSB
    Predator tube steps, mud guards, Tonneau cover, TRD exhaust
    Just ordered mine, can't wait. Do I need to get my own posi-taps, or do they come with?
  12. Feb 23, 2017 at 8:04 PM
    #292
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We recommend splicing.
    Gravybird[QUOTED] likes this.
  13. Feb 23, 2017 at 8:12 PM
    #293
    Gravybird
    Central MN
    Ok I see that now. I'm kinda working backwards through the thread. Read the first couple pages a while back then read the last page and ordered today.... Thanks for putting this stuff together!
    KB Voodoo[OP] likes this.
  14. Feb 24, 2017 at 8:14 AM
    #294
    gpb
    Atlanta
    To add on -- it's really easy to buy a spool of 24ga wire to practice on until you're confident. Radio Shack or other places carry it.
    Soldering, with a decent low-power butane iron, is pretty easy as well. Key thing there is low power.
    Gravybird likes this.
  15. Mar 5, 2017 at 5:44 AM
    #295
    kxed
    kxed Well-Known Member
    pittsburgh
    2017 DCLB TRD Sport Inferno
    Is there a way to extend the range or use an aftermarket remote?
  16. Mar 5, 2017 at 8:04 AM
    #296
    Gravybird
    Central MN
    So I have it all installed and I can't get the light to go from red to green in the programming phase... Any ideas where to look?
  17. Mar 5, 2017 at 9:05 AM
    #297
    Gravybird
    Central MN
    If anyone is wondering, I actually selected the wrong white wire on the back of the obd plug. There's a white across, and beside my blue. I picked the wrong one first.... KB was awesome to help me out!!
  18. Mar 7, 2017 at 8:13 AM
    #298
    gpb
    Atlanta
    Glad you got it sorted, @Gravybird -- good reminder to folks to check both color and pin for every wire they're touching.
    @kxed Yes, you can add on a longer range RF remote, though my only experience is with adding the SmartStart cellular setup (see my signature). If you want to carry a second remote you'd use the XL202 RFTD interface mentioned elsewhere in the thread; you'll want to make sure with @KB Voodoo that your DBALL2 is coded to use one (or just code it that way yourself if you rolled your own setup)
  19. Mar 13, 2017 at 6:41 PM
    #299
    Korndog1284
    Korndog1284 Well-Known Member
    J03l
    Washington
    2016 Off Road DCLB MGM
    All-Pro Raack Pack, Tepui Tent and Awning, ARB BP-51, K02 275/65/17, 4Runner Pro Wheels
    Installed mine, Great purchase... Easy Install!
  20. Mar 13, 2017 at 6:55 PM
    #300
    vprgts
    vprgts Well-Known Member
    Walter
    Centreville, VA
    Tacoma TRD Off Road Hybrid
    285/70/17 Nitto Ridge Grapplers, RRW wheels 17 x 8.5, Wescott designs pre collar lift, rough country power side steps, Truxedo pro x15 soft roll up bed cover, OEM bed mat, OEM bed swing out box, OEM Trd pro front skid plate, aftermarket pro grill, diode dynamics led fog lights, OEM sport hood, PPF and tint,
    What is the distance range that you can start vehicle from?
    KB Voodoo[QUOTED][OP] likes this.
