Remote Start - No Door Shutdown - Feedback Needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Accessorides, Jul 3, 2023.
  1. Jul 4, 2023 at 6:31 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    I know Orbit makes a remote start for 3rd gen tacomas that doesn't turn off when you open the door. It also let's you take the key out of the ignition and keep the car parked and running
  2. Jul 4, 2023 at 7:57 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Will you have a cell package for this proposed door-defeat system? I most often start my truck at a distance greater than remote range. At home, it’s in the garage and I don’t need to remote start. At work or out on the town, it’s distant. In Texas, I need more than 50 yards range otherwise there’s really not much benefit.
  3. Jul 4, 2023 at 8:53 AM
    Slurmin Furrmen
    Slurmin Furrmen Welder / Fabricator
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    I have factory remote start and it works well enough.
    I would only upgrade to a standalone if it had app control and defeated the door shutdown, otherwise I would be paying more for what I already have. Increased install time would not deter me.
  4. Jul 4, 2023 at 8:57 AM
    Jaycen
    Jaycen Well-Known Member
    Jay
    Worcester, MA
    2022 TRD PRO...the ugly Electric Lime color
    get your head out of the 90's....85% of new vehicles have a auto start/stop function. Technology is way beyond that.
  5. Jul 4, 2023 at 9:06 AM
    Potamus
    Potamus Well-Known Member
    Keith
    Oregon
    2022 Limited Blue Crush Metalic
    2.75 lift on 33s
    Would I still be able to use the OEM app, would it use its own app, or would it only be from the fob?
    If there is a way to mod my OEM remote start so that it acted like every other modern remote start then I’m all-in, and I would drop some dime on it. Would it require me to depress the brake and push the start button to move the vehicle? Will it still shut off if someone tries to engage the vehicle without the key in hand?
    DES2009 likes this.
  6. Jul 4, 2023 at 9:14 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    My 2020 Armada works as you describe. Far superior to the Tacoma method.
  7. Jul 4, 2023 at 4:18 PM
    LeakyAC
    ......the Tacoma don't fall inside your imaginary 85% dude
    KSchoppers and hotrod 15 like this.
  8. Jul 5, 2023 at 8:26 AM
    Accessorides
    Accessorides [OP] Well-Known Member
    There is no workaround what you see there is simply opening the door pin which does nothing to allow a normal takeover of the vehicle. We aren't releasing a "hack" to the current system as there isn't one. This is a complete new setup to allow full normal safe takeover. Thanks!
  9. Jul 5, 2023 at 9:43 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    That's not the impression I had, but you'd probably have to ask Jimmy or one of the guys at @N2DesignsInc to know for sure?
    VB25 and ktbell444 like this.
  10. Jul 5, 2023 at 11:20 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I disagree as well. The map lights are on, so unless they specifically turned them on to give the false impression, then the door switch is operable. I also don't think it would be smart, however not impossible I suppose, for a well-known brand like N2 to make claims as substantial as that without having some theory or idea of their path forward.
    VB25, musicisevil and DES2009 like this.
  11. Jul 5, 2023 at 11:50 AM
    Accessorides
    Sorry not familiar with the video, but there are a lot of ways we can keep the current remote start working with the door open/closed etc - the door pin is just one of them. We can program the door pin out completely and the remote start won't care in the least if it's opened or closed. The door being open/closed is fairly irrelevant to the "takeover" process as a whole and doesn't get you any closer to driving off without the vehicle shutting down for the current options out there. There is no "path forward" with the current remote starts on the market if that makes sense - it's a take or leave it with the vehicle shutting down and no way around it. Sorry if that wasn't clear but stay tuned :)
    LeakyAC likes this.
  12. Jul 5, 2023 at 11:58 AM
    Aval1996
    Aval1996 Active Member
    Andres
    2017 White Toyota Tacoma TRD sport LB
    Rancho leveling kit K&n intakr Pedal commader Meso customs chrome delete Red top optima battery Ripp performance coil packs
    RushT likes this.
  13. Jul 6, 2023 at 6:15 PM
    Potamus
    Keith
    Oregon
    2.75 lift on 33s
    almost every manufacturer works that way.
    I know why Toyota decided to go this route though. Most people that use remote start, let the car/truck idle in the driveway, then get in and take off.
    When I do that in my Subaru it affects my total MPG. I’m averaging 18.7 MPG in my wife’s Outback because of it idling in the driveway for freaking ever. But it is accurate. On Toyota, you can leave it running in your driveway, then when you open the doors, the car/truck shuts off. More importantly your trip MPG resets. Now Toyota doesn’t get a bunch of calls wondering why their trip MPG is like 11 MPG every time they take their kid to school. They probably get a 1/4 of the complaints or less now. And that is only from people that know how remote start is supposed to work.
  14. Jul 7, 2023 at 6:03 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Keyed versions don't have this issue
    drizzoh likes this.
  15. Jul 7, 2023 at 6:06 AM
    #35
    RedWings44
    Michigan
    Would I upgrade? Probably not. The N2 does what I need it to and the shut down is more of a minor annoyance which I only notice when I want to warm up the truck in the winter and load items at the same time.
    Would I have purchased one that doesn't shut down had it been available? Absolutely.
  16. Jul 31, 2023 at 11:28 AM
    #36
    Aval1996
    Andres
    Any news?
  17. Jul 31, 2023 at 1:44 PM
    #37
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    You obviously don't live where it gets to -20 to -30 for days on end and is below zero for months. You don't "just get in, drive, and wait for the ac or heat to do its thing..." when all the windows have heavy ice and snow on them and the tranny will barely get in to gear. The engine barely gets to running temperature after 15 minutes. Maybe you don't need a remote start but there are millions that do.
    TacoTime55 and Spadi_5 like this.
  18. Jul 31, 2023 at 4:20 PM
    #38
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    if i couldnt get in it i would use remote start but otherwise i just sit in it or scrape the windshield till its warm......what did people do before remote start? stay home?
  19. Jul 31, 2023 at 6:44 PM
    #39
    canuck guy
    Alberta
    23TRDOR
    Around here people would start the vehicle, scrape all the windows then go inside til it warmed up. Usually +- 15 minutes. Remote starters make life more bearable in cold climates.
    TacoTime55 likes this.
  20. Jul 31, 2023 at 9:05 PM
    #40
    RushT
    North Texas
    Yeah, it’s a luxury for sure. And one I paid for. But I doubt anybody would accept if Toyota told them they could save $250 if they disable the quick heat/cool option on the truck and your climate control wouldn’t work for the first 15 minutes after you started it.
