Remote start on 2007 TRD 4x4 remote start turns engine over but won't start.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sddman57, Apr 2, 2016.
  1. Apr 2, 2016 at 11:11 AM
    Sddman57
    Sddman57 [OP] New Member
    Can anyone help me on 2007 Tacoma 4x4 TRD? My remote start turns engine over but does not start. It was working. if I put key in it starts without turning.
  2. Apr 2, 2016 at 11:18 AM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    you didn't install one of the anti-theft bypass kits
    http://www.amazon.com/Directed-Electronics-PKALL-Xpress-Transponder/dp/B001N7RE44
    If I remember correctly from my install some 5 yrs ago, there's three wires that tie into the alarm (power, ground, and a negative out while starting) and three wires that tie into the factory key cylinder (one that ties into a signal wire, and the other two split another), and there's a little bit of archaic programming (ignition on/off with key in and button pushing kind of thing).
    It's really no worse than installing the remote start itself
  3. Apr 2, 2016 at 12:28 PM
    Sddman57
    It was installed at dealer or came from factory. It has worked until last year,I think it may be a switch or programming.
  4. Apr 4, 2016 at 7:27 AM
    TurboGT
    Gabe
    Portland
    Then my suggestion is to take it back to the dealer, or at least to a reputable car stereo installation shop and ask them to dig into it... that's assuming you lack the skills and knowledge to troubleshoot it yourself.
