Remote start question?
Discussion in 'Technical Chat' started by Caleb Smith, Dec 14, 2019.
  1. Dec 14, 2019 at 6:42 PM
    Caleb Smith
    Caleb Smith [OP] Well-Known Member
    2020 Magnetic Grey TRD Off Road Premium.
    Hello,
    Just bought a 2020 TRD Off Road Premium. Is there any way to stop the truck from shutting down once I open the door after it’s been started remotely? Very frustrating to start it, get it warmed up, then I open the door and it turns off.
  2. Dec 14, 2019 at 10:47 PM
    sooners71
    sooners71 Active Member
    13 PreRunner
  3. Dec 16, 2019 at 1:59 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    The Push To Start Toyotas are very well known for this. Even the Toyotas that have Key Start, you still have to get in and turn the key. If you think about it long enough, it's really no big deal.
  4. Dec 16, 2019 at 2:00 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    leave your door open and remote start it?
  5. Dec 16, 2019 at 2:02 PM
    PhenixFord
    Randy
    Arkansas
    Naaa - Doors have to be locked or it will not remote start. Guess you could always tape down the door switch with duct-tape?
    wheeliest[QUOTED] likes this.
  6. Dec 16, 2019 at 2:04 PM
    wheeliest
    Json
    TMPE AZ
    Use a self-tapping screw to increase longevity of a temp fix :D
  7. Dec 16, 2019 at 2:06 PM
    PhenixFord
    Randy
    Arkansas
    I think there is still one other problem with the brake. You can't put your foot on the brake or the engine will stop. Soooo - No Brakes. :annoyed:
  8. Dec 16, 2019 at 2:07 PM
    wheeliest
    Json
    TMPE AZ
    even after the key is in the correct position?
  9. Dec 16, 2019 at 2:11 PM
    PhenixFord
    Randy
    Arkansas
    Only on PST ignitions. - Key Start Ignitions will not shut OFF when you open the door. And stepping on the brake is part of the Take-Over Procedure. I don't have a system installed on mine yet. But doing research.
    Caleb Smith[OP] likes this.
