remote start reprogramming
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dq30, Oct 29, 2022.
  1. Oct 29, 2022 at 7:19 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Ok, well get used to it or let us know your fix please.
  2. Oct 29, 2022 at 7:26 PM
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    I see the dilemma. The issue is the brake. It must be applied to start the motor. Shift the transmission. Anything associated with driving the brake must be applied. So soon as you somehow get in the truck without it turning off. Guess what it’s shutting off soon as you hit the brakes anyways. Eh, I had a push button start. So did every car in the 30’s……There’s a reason they went with key starts. Lol.
  3. Oct 29, 2022 at 7:30 PM
    Bishop84
    Bishop84 Well-Known Member
    It has to switch authentication, on a physical key it interrupts, but immediately stays in "on" mode.
    With smart key, you can't simulate that with out turning it off. Plus the steering lock has to cycle.
    There's ways around it (non-oem starters), but I find most to be sketchy, the steering lock is a big concern.
    Just gotta deal with it.
    Rocket23 likes this.
  4. Oct 29, 2022 at 7:40 PM
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Agreed. I was kinda bummed when I was handed the keys at first.
    Having a push button stinger but with no remote start I had gotten use to getting in an going.
    Now I’m not so bummed.
  5. Oct 29, 2022 at 8:46 PM
    Bigmatt503
    Bigmatt503 Well-Known Member
    I don't get it either
  6. Oct 30, 2022 at 3:14 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    How does Nissan do it? In my 2020 Armada after a remote start you get in the vehicle with the Smart Key in your pocket, and press the Start button while the engine continues to run. Then you can put it in Drive and go about your business. If you shift into drive WITHOUT pressing the Start button first, the engine kills and must be restarted.
    HUTCHRED likes this.
  7. Oct 30, 2022 at 4:17 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I have the start x remote kit I installed and also have push button start.
    I can use the fob to unlock it while running but if you open a door it shuts off.
    Range on the remote sucks but it is better than going out in the cold to start it.
  8. Oct 30, 2022 at 5:09 AM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
  9. Oct 30, 2022 at 12:51 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    :facepalm:I gave up watching after the 3rd fail. You gotta leave a little more time between pushes:rolleyes: Also you have a key.
    Edit: okay so sat thru that again. Can you get in and turn the key and drive or it shuts off when you insert the key? Don't step on the brake just turn the key to on?
  10. Oct 30, 2022 at 2:32 PM
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    I’m pretty sure I can turn the key to the run position and drive away. The truck will shut off by either the brake or depressing the lock button three times. Lol reminds me of this for some reason.
    https://youtu.be/SNTzOBKs1bA
  11. Nov 1, 2022 at 3:52 AM
    Fatback17
    Fatback17 Masshole
    Billy
    2020 TRD Pro MGM
    Pretty sure? Dude go try it & let us know. I'd ask for a vid but the last one was to painful. :D
    Starting to think you've not used it much, if at all.
    JJ Diablo and Rocket23[QUOTED] like this.
  12. Nov 1, 2022 at 5:31 AM
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    I tried it last night. Unlocks I get in turn the key past acc to on. Drove away. Because the kit taps into the tpms for the unlock. That idiot light was flashing all the time until the key was turned.
  13. Nov 1, 2022 at 5:32 AM
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    It isn’t cold enough to use it that much. Yet.
  14. Nov 1, 2022 at 6:34 AM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    I know it may not add much, but on my SR I have an aftermarket remote start. With the truck started, I can unlock the door (via the Toyota fob, or the alarm fob), get in and put the key in, turn it to the on position, and drive away. If I touch the brake before the key is in the on position, then the truck shuts down. But mine is not PTS, nor am I using a factory remote start.
    Fatback17 likes this.
  15. Nov 1, 2022 at 6:51 AM
    #35
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    What is this pts you speak of.
  16. Nov 1, 2022 at 6:53 AM
    #36
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Push to start
    Rocket23[QUOTED] and Puppypunter like this.
  17. Nov 1, 2022 at 7:07 AM
    #37
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    I dont think its 20' and later. Mine is a 2017 and it has it. Just a factory fob on a sport, nothing added.
  18. Nov 1, 2022 at 7:09 AM
    #38
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Then you have an aftermarket Remote Start added. Have you owned the 2017 since new?
  19. Nov 1, 2022 at 7:19 AM
    #39
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Definitely aftermarket if its 2017. My Father has one on his ‘17 that can use either the factory fob as well as the remote that came with it.
  20. Nov 1, 2022 at 7:24 AM
    #40
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    D’oh! Head slap!! Lmao.
    ktbell444[QUOTED] likes this.
