Remote Start Wiring Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stutely, Jun 2, 2017.
  1. Jun 2, 2017 at 5:09 PM
    Stutely
    Stutely [OP] Well-Known Member
    Jonathan
    Central IL
    99 Xtra/3.4/5 speed/SR5/TRD/4x4 Burgundy "Ron"
    Preparing to install a remote start/keyless entry system on my 99. I have the basic wiring legend for the 99 and I have the detailed instructions for my system (Viper 4806v), so for the most part I know what I'm going to be doing. I was wondering though what the second ignition wire is. According to the wiring description I've got there are two ignition wires...anyone know what they are for?
    Is the first for the key on/engine off, and the second actually starts the car?
    Thanks
  2. Jun 2, 2017 at 10:11 PM
    Stutely
    Jonathan
    Central IL
    Here's the legend I was referring to:
    So I'm curious if anyone knows what the two ignition wires do, and then also what the accessory wire does.
  3. Jun 2, 2017 at 10:25 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    you have to have both ignition wires getting 12 volts for it to crank. my guess is it makes it harder to hotwire
  4. Jun 2, 2017 at 11:50 PM
    Stutely
    Jonathan
    Central IL
    Found this...it's from a 2001 wiring manual put out by Toyota. I assume the basics are the same for the 99. Wire coloring is the same anyway...
    It seems to indicate that Ignition 1 is for things like wipers, the gauges, turn signals, the ECU, etc. Then Ignition 2 is actually cranking the engine via the starter...
    cruiserguy likes this.
  5. Jun 3, 2017 at 1:30 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    They run 2 wires to spread the amp load out. the black wire is the starter on a 2000 the ign2 go's to the igniter and coils.
  6. Jun 3, 2017 at 1:32 AM
    Stutely
    Jonathan
    Central IL
    So then for a remote start would I connect to both wires or just ignition 2?
  7. Jun 3, 2017 at 1:36 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    The ACC powers gauges, radio, cig, power outlets, lights just about everything in the integration relay.
  8. Jun 3, 2017 at 1:36 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    both
    Stutely[OP] likes this.
  9. Jun 3, 2017 at 1:38 AM
    Stutely
    Jonathan
    Central IL
    It's gonna be a few weeks to a month before I get to this. Thanks for the help.
  10. Jun 4, 2017 at 2:31 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I'm planning on getting the same system as you. Where did you find the Viper instructions and schematics? You can usually only get them if you're a certified installer or google hard enough. If you could send me a copy I'd really appreciate it!
  11. Jun 4, 2017 at 7:26 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Try www.the12volt.com
  12. Jun 4, 2017 at 8:06 AM
    Stutely
    Jonathan
    Central IL
    There are several places, including the12volt.com that have basic legends for the wiring harnesses you'd need to tap into...took me a few minutes to find the one I needed for my year. I didn't create a login on there to get download access for manuals, which they apparently have, but I managed to find it here:
    http://www.directeddealers.com/manuals/IG/Viper/N4X06 2015-12 web.pdf
    I figure coupling that with several youtube videos of installs of this system such as:
    https://youtu.be/hM6yVjvPlhU
    ...that I should be able to figure it out. Lots of helpful folks here, too.
    I need to wrap up the practical stuff on my truck before I can get into the fun stuff, so it might be a month or more before i can do it.
    BartMaster1234 likes this.
